OT: green CRT monitor going soft
StuntDummy
Posted: Mon Apr 14, 2008 5:46 am    Post subject: OT: green CRT monitor going soft
I own a 6" green crt monitor that I use on a Steadicam. The picture on it is not as sharp as it used to be, and in fact is down right soft when I set the brightness and contrast fairly high (when using outdoors). I know this is no projector and probably completely different, but maybe someone can help me troubleshoot the problem, I'm not really sure where to start. Ideas?
Posted: Mon Apr 14, 2008 5:48 am    Post subject:
Could be simply tube wear, or could be the capacitor's are getting old and dryed out and are starting to leak.
Can you open it up an dpost a few close up's of the circuit board(s)?
