Problem with a Barco Convergence Output, 708/Cine7
front_range
Posted: Sun Apr 13, 2008 6:39 pm    Post subject: Problem with a Barco Convergence Output, 708/Cine7
Thought I'd try here before giving up on this one. It keeps blowing the +/- conv fuses in the power supply. I can't find a short anywhere, the +/- conv supply inputs read over 10 k resistance between themselves and between each and ground. Pull the board, fuses don't blow. Check again for shorts, find none, reinstall, fuses blow. I can't think of anything else to try.
