just bought a barco data 500 - svideo sync problem
dobbar
Posted: Fri Apr 11, 2008 2:55 pm    Post subject: just bought a barco data 500 - svideo sync problem
Finally upgraded my old vph-100 to a bd 500, initial reactions are good (especially putting the computer through port 5) , still confused about the usage of the memory banks even after reading everything I could get my hands on.
I've cleared most of the memory blocks in an attempt to get my PAL skybox working correctly, the picture rolls slightly such
that the bottom is at the top and vice versa. An NTSC signal syncs fine. The box displays the correct frequency in the bottom right of the screen (15.6 khz at 50) but will not sync - Anybody got any ideas ?
Thanks in advance.
Posted: Fri Apr 11, 2008 3:48 pm    Post subject:
Tweak the V hold pots on the V board slightly (see the tips section for the bArco 800 on the main site for pot locations)
dobbar
Posted: Fri Apr 11, 2008 4:01 pm    Post subject:
Many thanks. Dan.
