D50 vs XG75 - Big difference?
StuntDummy
Posted: Wed Apr 09, 2008 6:16 pm    Post subject: D50 vs XG75 - Big difference?
I own a Sony D50 that I am pretty happy with at the moment, but I may have a chance to get a NEC XG75. Anyone have an opinion on on how much better the NEC will perform over the Sony? Just trying to figure out weather I will see a big enough improvement in pq to make the switch worthwhile.
Thanks!
MikeEby
Posted: Wed Apr 09, 2008 6:38 pm    Post subject:
Yes it should be better. How much better thats is a good question, probably its based on the condition of the tubes in both sets. If the XG has good tubes IMO it should blow away the D50.
dropzone7
Posted: Wed Apr 09, 2008 6:41 pm    Post subject:
It all depends on the setup. If you are careful and exacting in your physical setup and then in your geometry then the XG should really be a step up. Like Mike said, good tubes are a must but if the price is right then you can always look for better tubes. You would of course be going from 7" to 8" tubes and from 800 lumens to about 1100 and a higher max resolution so that helps.
Person99
Posted: Wed Apr 09, 2008 7:11 pm    Post subject:
127.894456% improvement in picture.
2004.6% decrease in user friendliness.
312.84% increase in fan noise.
Or something around those numbers Mr. Green
MikeEby
Posted: Wed Apr 09, 2008 7:26 pm    Post subject:
Dave, did you have your picture improvement meter calibrated lately? Mine is showing 127.89448% Mr. Green
My fan noise number did agree with yours.
A hush box is a good idea to have with an XG it's almost a requirement.
dropzone7
Posted: Wed Apr 09, 2008 7:28 pm    Post subject:
I'm interested in adding one if and when I'm up and running again. Did I read somewhere that it's better to leave the case intact on XG's rather than stripping them down before building the hush box around it?
MikeEby
Posted: Wed Apr 09, 2008 7:37 pm    Post subject:
dropzone7 wrote:
Interesting, mine has been naked for 6 years without incident.
dropzone7
Posted: Wed Apr 09, 2008 7:47 pm    Post subject:
Naked with hush box or just totally naked? I think it had something to do with how the fans exhaust and movement of air through the projector. With the right amount of exhausting airflow and a proper plenum I don't know why it would matter. Have any pics of your hush box Mike?
"Coffee is for Closers."
whats6x7
Posted: Wed Apr 09, 2008 8:42 pm    Post subject:
No, much closer to 3065.23%. NECs are a bitch.
IMHO
Posted: Wed Apr 09, 2008 9:23 pm    Post subject:
Quite literally with the 13 or so fans in the XG... (they're friggin' loud!)
Posted: Thu Apr 10, 2008 3:59 am    Post subject:
Sorry Kal, what was that? I couldn't hear you....Very Happy
MikeEby
Posted: Thu Apr 10, 2008 4:06 am    Post subject:
I didn't know you were an XG owner? Smile
Posted: Thu Apr 10, 2008 4:11 am    Post subject:
Note:
VENTILATED hush box.
I've seen convergence drift with a 3 sided hushbox with the front and back completely open. Solid as a rock by itself, convergence drift as soon as the hush box was put around it.
Fan noise never bugs me, if the D50 has>3000 hours on it, the XG will smoke it.
MikeEby
Posted: Thu Apr 10, 2008 4:16 am    Post subject:
Note:
Absolutely! If the hush box is not ventilated the XG will smoke. But your right I would never consider a non-ventilated box
dropzone7
Posted: Thu Apr 10, 2008 12:15 pm    Post subject:
MikeEby wrote:
Note:
Ventilated how? Does that not defeat the purpose of "hushing" the projector? I know the front needs to be open around the lenses for some air intake but do the sides need louver type openings as well?
MikeEby
Posted: Thu Apr 10, 2008 2:21 pm    Post subject:
dropzone7 wrote:
MikeEby wrote:
Note:
Ventilated either by connecting into the home’s HVAC or some type of ductwork with an inlet and outlet, in my case it is connected to the return air in the HVAC system. I run my furnace fan 24/7 so it moves enough air to not be a problem also since it’s recessed into the soffit it has about 20 cubic feet of free air space around it and this also helps.
Posted: Thu Apr 10, 2008 2:30 pm    Post subject:
That's true for *every* projector, not just the XG. I don't care if you box it up without ventilation and it's still running and stable a few months later, you're frying the thing and severly killing its lifespan.
See my hushox building instructions for info on ventilation: http://www.curtpalme.com/Hushbox1.shtm
