1080i/720p72hz on a Seleco SVD800 Millennium
Pulse1
Posted: Sun Apr 06, 2008 7:43 am    Post subject: 1080i/720p72hz on a Seleco SVD800 Millennium
Hi Smile,
I can use both these resolutions at 72hz on my 800 via a lumagen HDP then to an HD Fury but was wondering which would be the best to use?1080i looks sharper to my eyes but would a progressive image like 720p be the all round better choice?I also have my Toshiba HD Dvd HD XE1/Panasonic DMP-BD30 both outputting 1080i is this the best resolution or would 720p output be better?I tried outputting 1080p60/24 into the the lumagen but got no picture from the BD30 Confused The 800 can't do 1080p only 1080i or 720p so i'm just trying to get the best from it Thumbs Up
Many thanks
Brian
Posted: Sun Apr 06, 2008 5:57 pm    Post subject:
If you're in the UK (50Hz land) wouldn't you want to use 75Hz instead instead of 72?
Pulse1
Posted: Sun Apr 06, 2008 11:02 pm    Post subject:
Not for HD DVD and BD as they don't output 50hz for HD discs Rolling Eyes
Ile
Posted: Mon Apr 07, 2008 9:55 am    Post subject:
1080i would be better with HD discs, since 720p need to be scaled down. That soften fine details little.
1080i have also lower BW that makes image sharper.
Use 1080i, if you don't find interlacing fluttering annoying.
It's annoying with still picture, but video looks fine to me.
Pulse1
Posted: Mon Apr 07, 2008 10:49 am    Post subject:
Thank's for the reply Thumbs Up So you reckon i should have 1080i going into the HDP and 1080i coming out of the HDP for a better sharper image for HD discs.The great thing about the HDP is it has great tweeks for crt projectors as well.
Brian
Ile
Posted: Mon Apr 07, 2008 11:57 am    Post subject:
Yep, that was what I meant. You can also test 1080i 96Hz, to see if you like it better than 72Hz.
Even you don't use HDP for scaling or deinterlacing with 1080i, it's still needed for chancing 24Hz to 72Hz and porch setting tweaking. Many times porches from hd players aren't best for your crt projector without tweaking.
Posted: Mon Apr 07, 2008 7:21 pm    Post subject:
Really?? Are you saying that you buy a region B (or "2") Blu-ray player where TV is normally 50Hz, the Blu-ray player and region B discs will output 60Hz? How does it work on TVs that only do 50Hz? I'm missing something here...
More info on Blu-ray region coding: https://www.curtpalme.com/forum_archived/viewtopic.php@t=9923.html
Person99
Posted: Mon Apr 07, 2008 7:39 pm    Post subject:
OP, see my response in your other thread about this.
Ile
Posted: Mon Apr 07, 2008 8:16 pm    Post subject:
Yep, all our HD discs are 24Hz/60Hz like yours, same thing with French Canal releases. All our tv's that can show HD resolutions can also take least 60Hz (lcd, plasma). All those 50Hz only crt tv's are 576i only.
For some reason those few satellite HD channels use 50Hz.
Pulse1
Posted: Tue Apr 08, 2008 6:58 am    Post subject:
I have the region A BD30 the reason being that you's guys get the film titles released before the UK Thumbs Down Lol
Pulse1
Posted: Tue Apr 08, 2008 6:59 am    Post subject:
Ok thanks alot mate Thumbs Up
Posted: Tue Apr 08, 2008 8:51 pm    Post subject:
Interesting. I learn something new every day... I suppose at higher resolutions there's no reason to stick to the old 50Hz standard... Thanks!
