Funny Auction
jantje112
Posted: Wed Apr 02, 2008 6:07 pm    Post subject: Funny Auction
Looks like a good deal Wink
http://cgi.ebay.de/ITT-NOVABEAM-Roehrenbeamer-mit-TV-Tuner_W0QQitemZ120240388821QQihZ002QQcategoryZ75404QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Notice the great tubes!
Posted: Wed Apr 02, 2008 6:15 pm    Post subject:
WOW,WOW,WOW ! Shocked I've seen burnt tubes before but those are like little Charcoal Brickets. Isn't CRT amazing though, can you imagine how many hours that sucker ran to burn the tubes like that. Thumbs Up
jask
Posted: Wed Apr 02, 2008 6:19 pm    Post subject:
I don't think those are burnt, that is part of the lens system.
Posted: Wed Apr 02, 2008 6:21 pm    Post subject:
That's what I was just about to post: I've seen old RPTV's that have a sqaure chunk of metal in in the lenses. Note the little diagonal bar in the top right holding them in place.
Posted: Wed Apr 02, 2008 6:47 pm    Post subject:
Those rectangles are the back sides of reflectors... If you're familiar with telescopes, it's basically a Cassegrain design, which works like this (but in reverse).
zGman
Posted: Wed Apr 02, 2008 7:03 pm    Post subject: Novabeam
Greetings,
Actually, the rectangles you see thru the lenses (with the little strip
leading off to the side) are the back side of the phosphor, which
is deposited on the front of the tube as usual, but on an opaque
aluminum substrate. The electron beam fires thru a hole in the
curved mirror, and the light from the phosphor goes back toward
the curved mirror (which is flashed with aluminum) and then once
reflected, back through the front of the tube, which (I think) is also
curved. Its been a while since I looked at one.
In the drawing from ecrabb - substitute the phosphor for the secondary
mirror, and imagine the electron beam on axis from where the
eyepiece would be, and the image light output then heads out
through the barrel, but then thru another lens for projection.
The interesting thing is that it works with so little phosphor area.
The way the optics are designed, there is only one throw distance
for which the system is in focus.
Cheers,
Galen
Brooklyn
Well it is unique at least.
Posted: Wed Apr 02, 2008 7:14 pm    Post subject:
Guys!
We sold several hundred Novabeams around Michigan; built on a Magnavox chassis. They were among the first to employ magnetic focussing. The Novabeam threw a pretty nice image on a 79" diagonal hi gain curved screen, and was easy to troubleshoot with a box of spare modules.
Posted: Wed Apr 02, 2008 7:16 pm    Post subject:
Duh. Galen's right. The little tabs are the phosphor targets, and mirrors are at the back facing the screen.
jantje112
Posted: Thu Apr 03, 2008 7:37 am    Post subject:
Well, learned something again!
The machine is probably older then I am.
