how to fix pattern wear on NEC tubes!!
jask
Posted: Wed Apr 02, 2008 3:15 am    Post subject: how to fix pattern wear on NEC tubes!!
I have been trying some things to try to "save" some tubes from my PG and had a brainstorm last night.
When I was a kid one of the local kids wrecked his colour TV by sticking a magnet against the screen- the area under the magnet developed a permanent discolouration. I have a couple tubes that have lots of life left,but were set up small and burnt (lightly...) enough that the discolouration made me replace them. last night it hits me! all I need to do is hold a magnet up to the tube face and move it around to "paint" over the non-burnt area and even it out.The only problem was the damn glycol chamber, so I cut it off!! only took about 2 HOURS!! then I realize that the tube is going to explode if I fire it up without coolant.....so
( I have pictures of this, I will resize and post)
I turn the projector on its side, get a deep glass casserole dish full of water and set the tube in the pan, totally freaked about getting fried by the high voltage, I check the chasis to water with my multimeter ( nada!)and after a couple deep breaths slip my hand into the water with a 1 inch round super magnet that usually lives on the fridge( and is strong enough to hold a copy of Time magazine to the fridge!) so there I am looking up through the bottom of the pan and I can SEE the burn from the magnet and as I move it around the edge of the pattern wear (raster lit up) it is sort of hard to get right to the edge evenly so I just sort of "scrubbed" over the hard edge area, so now the transition is less obvious. it was getting late by this point so I took a few last pics and crashed. but it looks like it will work!!
I just need to resize these before and afters and I will post them. Thumbs Up
Joust
TV/Projector: Marquee 8501LC
Posted: Wed Apr 02, 2008 3:26 am    Post subject:
wanna buy a bridge?
had to get that one in just before midnight eh? Wink
jask
Posted: Wed Apr 02, 2008 3:44 am    Post subject:
files are still too big... I am just going to reshoot the after close-up at lower res. the befores look pretty grainy but you will get the idea
jask
Posted: Wed Apr 02, 2008 3:57 am    Post subject:
o.k. here you go:
green tube
 Filesize:  438 Bytes
 Viewed:  5491 Time(s)
jask
Posted: Wed Apr 02, 2008 3:58 am    Post subject:
hold on......
jask
Posted: Wed Apr 02, 2008 3:59 am    Post subject:
here we go:
 Filesize:  8.91 KB
 Viewed:  5487 Time(s)
Fujifrontier
Posted: Wed Apr 02, 2008 4:26 am    Post subject:
meh
kschmit2
Posted: Wed Apr 02, 2008 8:16 am    Post subject:
Dunno what to make of this post as the opening post says "Posted: Wed Apr 02, 2008 3:15 am" for me Shocked
Heywood Jablome
Posted: Wed Apr 02, 2008 11:25 am    Post subject:
Kamloops, BC is on the left coast. AVS' server(s) is/are on the right coast, aboot four hours in the future, eh...
--Edit... this is not AVS, this is curtpalme.com... Where ARE the servers?
dculberson
Posted: Wed Apr 02, 2008 1:53 pm    Post subject:
I think it shows your local time as of when it was posted. I could be wrong. But it asks for your time zone in your profile.
I'm GMT - 5 Hours. So for me it says "Posted: Tue Apr 01, 2008 10:15 pm." Since Jask is in BC, he'd be GMT - 7 hours = 8:15 pm..? I don't know if they do daylight savings. Whatever. My point is, it was April 1st for him when he posted it. Wink
I'm a stuffaholic.
jask
Posted: Wed Apr 02, 2008 3:46 pm    Post subject:
It was an April fools post.... and it was still before midnight locally Smile
I am not entirely sure but I thought the forum clock defaulted to GMT if you did not select local time
EDIT: on the lower right of the page...... "all posts are GMT plus....."
kschmit2
Posted: Wed Apr 02, 2008 5:28 pm    Post subject:
says "All times are GMT" here Smile
jask
Posted: Wed Apr 02, 2008 6:20 pm    Post subject:
oh yeah..... same here!!
