please help.busted a new retro 808
jaredjaric
Posted: Tue Apr 01, 2008 5:13 pm    Post subject: please help.busted a new retro 808
I inadvertently plugged my ac cord in the 220volt outlet.Because my ac power conditioner overheated and had to unplug the PJ,and then i plugged it straight to the wall socket(220v).The fuse on the power board shorted and the 330 mf 400 volt caps exploded.theSMPs board had a busted 100mf 400volt cap also.
Have replaced the caps of the same value from old barco boards and flipped the jumper on the power board to 220volts.But the pj will not output a video signal.
There is no hold down and no scan fail,ruled out the h shift focus board by inter swapping boards on a working 808.Both boards working fine.Ruled out h def board because there is g2,leds on neck board lights up then goes out.(180mhz neckboard)ala BG808s.
Why is there no video signal,the remote seems to be working ,as per blinking led indicates.even the red barco logo does not come out.
