    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 1200
Zenith PRO 895x/900x
      >> Introduction
      >> Layout and Setup Tips
      >> Manuals / Downloads
 (Page 5)
Page: 1 2 3 4 5 6 7 8
This board has four diagnostic lights on it that can assist in troubleshooting.
The top light is the standby light, and should be on whenever the set has power. The H drive light indicates that horizontal drive is present on this board. The H drive feeds the horizontal output board. The H drive light simply means that the drive signal is present. A fault in the H output board can mean that the H section is still problematic.
The V drive light is similar to the H drive light. This RGB board also sends the V drive signal to the V output board.
The video enable light comes on only after the H and V drive signals and high voltage to the tubes are confirmed. It is possible for all four of these lights to be on and another fault in the set will cause a ‘no picture’ symptom, but many ‘no picture’ faults can be traced to this board. If any of these four lights are not on, chances are this board is bad.
This board also holds the EPROM and memory chips, but these have proven to be quite reliable in the past.
... Previous Page
Next Page ...
