Zenith PRO 841x/851x
Focus Block Replacement
(Page 4)
Page: 1 2
3 4 5
Mount the new HV divider section to the set frame, insert the 4 HV leads (the
order of the red CRT HV leads is not important). Connect the focus modulation
wire if applicable, and route and connect the 2 pin connector to the deflection
board.
![](images/Zenith851_FocusBlock_image004.jpg)
A ‘Z’ shape bracket is included with the new focus block to mount the control
section to the one side of the top of the chassis. Use the two longer screws
located in a baggie to mount the bracket to the control block. Use the two other
supplied hex screws to mount the control section to the chassis.
