    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Troubleshooting Tips > Barco
Back to Troubleshooting Tips Index
Select a topic:
Video Problems: RGB Switcher Card
I’ll assume for now that most of you are running an RGB input to your Barco projector.
All signals run through the RGB switcher card, the BNC input connectors feed directly to the input of the RGB switcher card via the motherboard. This makes the switcher board somewhat susceptible to static electricity and power surges. It’s not uncommon to have one color to go dead due to static electricity damage to this board. If the H or V sync components get damaged, the RGB input will go dead as the Barcos will not display a picture if the sync signals are not present within the projector. As stated above, if the RGB input goes dead, the video and Svideo inputs most likely will still work.
There is a green LED that lights up if a signal with sync is present and that specific input is selected on the keypad. If there is no input signal present, the LED usually will light for a second or two when that input is selected, but then it will go out as no signal is detected.
Or purchase from Amazon.com and a small percentage automatically goes to support this site at no extra cost to you! Visit their Blu-ray and 4K UHD stores for sales. Want to show off your home theater? See our Blu-ray Release List & Must-Have Titles. Shop at Amazon.com and support our site!
... Previous Page
Next Page ...
