    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Troubleshooting Tips > Barco
Back to Troubleshooting Tips Index
Select a topic:
Video Problems: General Info
So let’s assume that you have a picture of some sort, but the color is incorrect, one tube is not lit, or something else funky is going on.
Note to first time Barco owners: The on screen BARCO logo only projects in red and green, the blue tube will remain dark. I’ve had a number of phone calls on this. This is normal.
A lot of problems are actually caused by signal sources or cabling. Before you jump to the conclusion that the projector has a problem, try making sure that the signal source or cabling is not causing the projector to act up. You can do this via a few ways:
If you are running RGB into the projector from an HTPC, scaler, HD box or line doubler, try feeding a video or Svideo signal from a DVD player right into the projector via a short video or Svideo cable. Select input 1 or 2 depending on which input you connected to. See if that will get you a decent image. If so, recheck your line doubler, scaler and cable.
Also, you can usually connect the output of a scaler or line doubler to a regular SVGA computer monitor. That again may confirm problems with your signal source.
Note also that many early Barco models will only accept a negative sync signal from your signal source. Many video cards and some scalers/processors only output positive sync, and an external Extron box such as the 202 will be needed to convert the positive sync to negative sync that the projector will recognize.
Assuming now that your signal source is fine, let’s look at the Barco signal path that it takes in the set.
Or purchase from Amazon.com and a small percentage automatically goes to support this site at no extra cost to you! Visit their Blu-ray and 4K UHD stores for sales. Want to show off your home theater? See our Blu-ray Release List & Must-Have Titles. Shop at Amazon.com and support our site!
... Previous Page
Next Page ...
