    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Troubleshooting Tips > Barco
Back to Troubleshooting Tips Index
Select a topic:
Video Problems: General Convergence Problems
Problems can occur with the convergence circuits, however the problem may not lie in the convergence board itself. Let’s look at a few of these, starting with the obvious ones:
V shift and size: All Barcos have the V shift and size controls located on the V board, that part makes sense..:). I’ve had vertical sections of the individual tube colors decrease or increase in size, to the point where the trimpots cannot bring the correct height back. A failure has occurred in a color’s V section, send the V board in for repair.
H shift: The H shift circuitry is on the focus/H shift board. A failure of a component can offset one or more colors by a small or large amount. Send the H shift board in for repair.
No convergence controls work: A fully functioning convergence section relies on a bunch of areas of the set working in conjunction with each other. The convergence power supply must work (which is located on the G2/diagnostic board on the 808/1200/1208/1209 sets), commands must be processed from the controller board going to the convergence board, and pulses from the HV section, V board and H shift board must all be present. Problems in any of these sections can cause a complete loss of convergence, and sometimes multiple boards must be sent in for testing to confirm exactly where the problem is.
No Pincushion/Keystone: The keystone and pincushion controls come from the V board. Failure of this section of the V board will cause these controls to be inoperative. Sometimes the H direction of key and pin will work while the V direction will fail.
I2R errors: Many data grade projectors use a serial set of commands from the controller board to digitally control various set functions. Barcos can display I2R error codes right on the screen, and those will indicate what digital control chip is not functioning. The service manuals show how all of the I2R error codes map out to each chip. Now, a couple of points to do it yourselfers. The Barco chips are very, let me repeat, VERY reliable, and failure of these chips is VERY rare. Usually some other component on the board fails, and causes the I2R error. Multiple I2R errors on the screen ALWAYS indicate problems elsewhere in the set, usually in a power supply section that drives the I2R chips.
Not all I2R chips are on the convergence board. Many other boards in the set also have these chips on them, and again, failure of the chips is rare.
Or purchase from Amazon.com and a small percentage automatically goes to support this site at no extra cost to you! Visit their Blu-ray and 4K UHD stores for sales. Want to show off your home theater? See our Blu-ray Release List & Must-Have Titles. Shop at Amazon.com and support our site!
... Previous Page
Next Page ...
