    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Advanced Procedures
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
Troubleshooting Tips > Barco
Back to Troubleshooting Tips Index
Select a topic:
Video Problems: RGB Output Amplifiers
Each CRT has an RGB output amplifier, and with all models post 1990 (Barco 500 and 800), they are located on or near the CRT socket. The Barco 500, 800 and 801 sets have three identical RGB amplifiers screwed to the chassis with two screws, and are located directly over each CRT socket. The Barco 500 and 800 RGB amplifiers failed regularly and can cause faint diagonal lines across one tube face (called ‘retrace lines), or worse, can cause spot burn at shutoff on the tube face. Fortunately the failure of these boards occur over time, so if you notice a small dot at turnoff of a Barco 500 or 800, do not continue to use the set. Send those boards in for servicing immediately to prevent spot burn.
The Barco 801 and 808 had newer video output boards that used chips rather than transistors that overcame the spot burn and retrace line problems of the earlier models. These chips run hot however, and failure of the chips can occur. Typically the CRT tube goes dead when the chip fails.
Late model Barcos had the CRT socket and video output amplifier circuitry combined right into the CRT socket assembly. Sets with Sony tubes have a thick red focus wire that goes from each CRT socket to the G2/focus board. MEC tubes do not have this wire.
Since all three CRT output boards are identical, it’s easy to determine a potential fault with a board by swapping CRT sockets or boards with another tube. If the problem moves to another tube, the problem is in the CRT socket or board. If the problem remains with the same tube, then either the tube is at fault or the video driver circuitry is defective.
Or purchase from Amazon.com and a small percentage automatically goes to support this site at no extra cost to you! Visit their Blu-ray and 4K UHD stores for sales. Want to show off your home theater? See our Blu-ray Release List & Must-Have Titles. Shop at Amazon.com and support our site!
... Previous Page
Next Page ...
