![](images/spacer.gif) |
NEC PG Series
Mechanical Setup Procedure
(Page 2)
Page: 1 2
3 4
5 6
7 8 |
The Adjustments
TOP COVER
![](images/NECPG1.JPG)
Have everything plugged in, and ready to go. A source signal will be required
to give the PG
something to lock onto. The first step is to open the hood. Loosen the top 2
screws on the cover and
hinge it open to it's locked position. Remove the 2 screws on each side of the
front bezel (decorative
front panel) that surrounds the lenses, and pull the bezel off.
LENSES
![](images/NECPG2.JPG)
Now take a screwdriver and carefully remove the 4 screws that hold each lens
in position. On the
PG6000 and 9000, these are long black slotted screws that almost look like
dowels. On the
PG6100/9100 and up, these are plain brass coloured Philips head screws. A
magnetic screwdriver is
helpful here. The lenses are HEAVY, so be careful.
You should now have all 3 lenses removed, and sitting on a soft cloth. This
is a good time to look at
the tubes. In a perfect world you should see 3 clean white tube faces, devoid of
any markings.
Often however, this is not so. Most likely one or more tubes will exhibit some
sort of wear, or even
burn. If the tubes are worn, a trapezoidal shadow will be visible in one or more
tubes. It .should. be
in the center of the tube. In many cases it is not. This is a sure indication of
improper alignment. I
will not go into the details of explaining worn or burned tubes here, as there
are other good articles
and pictures to demonstrate this. For the purposes of this document, we will
assume that all 3 tubes
are good.
