The following Electrohome Marquee teardown procedure was graciously provided
by forum member CZ Eddie. Thanks Eddie!
The following procedure describes how to disassemble an Electrohome Marquee
chassis. Useful if you need to repair or replace some boards and don't want to
risk breaking something in the process!
STEP 1: Removing the LVPS unit
Remove the four screws. Two on the bottom front, and one on either side (as
show in pictures below).
![](images/MarqueeTeardown_01.jpg)
![](images/MarqueeTeardown_02.jpg)
![](images/MarqueeTeardown_03.jpg)
Great, now gently lift one end of the Marquee so it's resting on its side. Then,
remove the panel by pulling it down and towards you.
![](images/MarqueeTeardown_04.jpg)
Then, remove the TWO screws shown in the picture below.
![](images/MarqueeTeardown_05.jpg)
Now, pull the LVPS out of the Marquee. It may be slightly stuck, so you might
have to wiggle it left & right, as you're pulling it out.
![](images/MarqueeTeardown_06.jpg)
