    Site Map
Home Products
For Sale
Referral
List
Gallery
Links Contact
Us
CRT Primer
Troubleshooting Tips
Mounting Methods
Definitive CRT
Projector Setup Guide
Tube/Raster Setup
Tube Condition (Wear)
Projector
Specifications
Projector Rankings
Video Processors
Ampro 1500/2000
Ampro 2300/2600
Ampro 3600/4600
Barco (Older Analog)
Barco 70x/Cine7
Barco 500/800/801
Barco 808/Cine8
Barco 120x/Cine9
Dwin 500/700
Electrohome ECP
Electrohome Marquee
Mitsubishi
NEC PG
NEC XG
Panasonic 108x
Runco
Seleco
Sony 10xx
Sony 125x/127x
Sony 1292
Sony D50
Sony G70
Sony G90
Zenith 841/851
Zenith 895/900
Zenith 1200
CRT Projector Focus & Mechanical Aim
 (Page 2)
Page: 1 2 3 4 5 6 7
Raster, Image Area, and Internal Test Pattern Centering on Tube Faces
Centering of the image on the tube phosphor surface is done by centering the raster on tube phosphor and then centering of the actual image within the raster. You should begin by hooking up and displaying a video source.
Raster: The area of the tube phosphor that is painted by the electron beam.
Normally, only part of the raster is actually used to produce the image. The raster can be seen by peering through the lens after turning down contrast nearly all the way and then raising brightness to make the normally black raster light up. This makes the entire raster light up dimly. It may be necessary to open the left, right, top, and bottom blanking controls to allow visualization of the entire raster. Size of the raster is adjusted using vertical and horizontal size (aka amplitude) controls. The rasters are best kept small enough to ensure active video image is never extended beyond or near the phosphor edges. Keeping at least 7 to 10 millimeters of unused phosphor on all edges helps prevent the catastrophic tube failure that will occur if active image is projected beyond or too close to the phosphor edges. Since the raster is usually larger than the actual image area and it is actually the energy of the image area that can cause damage, some installers will allow the raster to extend beyond the edges while still maintaining image area within the safe portion of the phosphor.
When viewed on screen, the leftmost portion of the raster is drawn first after the electron beam completes horizontal retrace. Looking into the projection lens the orientation is backwards. During the first portion of the horizontal movement the beam has not settled completely and one may see some waviness in the image if the extreme left edge of the raster is used. Some installers will intentionally displace the raster slightly leftward so the active image is displayed on the later, more stable portion of the raster.
Centering the raster is performed by use of centering magnets on the CRT necks just behind the deflection yokes. The centering magnets are a pair of rings with small tab handles. By rotating the rings relative to each other and also around the neck of the tube one can shift the raster about the phosphor surface. Most projectors also have electronic static position controls for fine adjustment of the raster centering. It is best to use minimal electronic correction to reduce strain on the convergence circuitry. One can do so by centering the electronic controls prior to centering the raster with the centering magnets. On some projectors (such as NEC XG's), there are no centering magnets and raster centering is carried out purely with electronic controls for raster centering hidden in a service menu. Even on such machines it is reasonable to first center the user centering controls prior to setting the service menu raster centering controls.
Image Area: The portion of the raster which is actually used to display the video image
Within the raster, the active video image is displayed. The projector often has "position" or "image shift" controls which allow movement of the image within the raster. The name of this control varies from brand to brand. You can verify you have the correct control by making the raster visible and seeing if the image is moving about within the raster but the raster is not moving as you use the control. If raster moves as well as the picture, you are adjusting the raster position and not the image position within the raster.
Ideally, the image area is centered both vertically and horizontally on the phosphor surface. You can achieve this by first neutralizing the linearity controls and then centering the raster relative to the phosphor edges. Then center the image area within the raster edges. Once both are done, display a white field pattern from a calibration disc (AVIA, S&V Home Theater Tune-Up) and verify that the active is centered in the phosphor. We'll cover this in greater detail later.
BTW, Don't use an internal test pattern for checking centering as they are often not themselves centered relative to external signals unless you have also taken the steps described next in this note.
Built in test pattern generators do not necessarily coincide with actual video signals in timing. They tend to be off center and not exactly scan locked to match a real signal. This means that making an internal test pattern look correct does not necessarily optimize the machine for a real signal. However, internal test patterns are handy and some machines like NEC's actually require you to set their timing relative to the video signal and convergence systems to prior to other geometry and convergence adjustments. If you have a machine which allows adjustment of internal test pattern timing, it is possible to center the internal test patterns to coincide with the center of actual video signals. This is much easier to do if mechanical gun aim has already been accomplished. In the next section, mechanical gun aim will be covered so skip forward and do that. Then set internal test pattern centering (phase) as described below.
For example, the phase control of NEC projectors MUST be set before geometry and convergence adjustments when creating a new input memory. The phase control changes the timing of the internal test pattern generator and also timing of the convergence system relative to the video signal. Since you have already centered the gun mechanical aim and centered the image on the screen and phosphor surfaces, adjusting phase to make the internal generator centered on screen also centers it with the video image center. Adjust phase to make the center vertical line of the internal generator centered left/right on screen. Then adjust phase to make the deflection blip centered around the center vertical line. The blip shows the centering of the convergence system. If it makes it easier for you, display the internal center cross pattern rather than the crosshatch while adjusting phase. Ignore the odd shape of the lines, just concentrate on the position of the middle of the center vertical line and the blip.
Since there is no control to shift the internal test pattern vertically, the only way to achieve vertical coincidence of the image and internal pattern centers is the image position control. Once that is done, you may need to readjust projector tilt to get things centered on screen. Going through all gains you the option of using either internal or external test patterns with good accuracy.
One should strive to keep the image centered within the phosphor surface and leave at least 7 to 10 mm of unused phosphor all around the active image. Mechanical aim of the guns is easier to do when the image and rasters are vertically and horizontally centered on the tube faces. Further fine tuning of raster and image centering can be performed as well as centering of the internal test pattern generator once gun aim is accomplished.
... Previous Page
Next Page ...
