Electrohome Marquee
Series
Back view
Here’s a shot of the back of a Marquee.
THE CLM or Control board is the microprocessor section that runs the set. It
has 6 error LEDs on it that will indicate a fault in the set, or at least give a
hint as to why your Marquee is not working properly.
Under the blank panel over the CLM board are the optional ACON board and the
CC (contrast modulation) module. Some sets will have these boards, some won’t.
![](images/Marquee_image04.jpg)
![](images/Marquee_image06.jpg)
The main VIM or video input board is on the bottom of the right side. This
picture has the blank cover removed where the secondary RGB input board slides
into. The aftermarket DVI/component input card also will fit into this slot.
The large area above the VIM board is where the optional Video/S-Video input
module goes. Again, some sets will have this card, some will have a blank cover
here as the board was an option.
![](images/Marquee_image07.jpg)
