Electrohome Marquee
Series
Rear Heatsink
Below is the view of the inside of the heatsink assembly. It shows the three
individual boards (note that the convergence output and V output boards are
connected together, but a sharp X-acto knife will cut the joining areas). Two
screws form the hinge points for this large heatsink, and one outer plastic case
side has to be removed to access those screws. Once one of the screws is
loosened, the heatsink will slide off the hinge screw on the other end of the
heatsink. Note to use caution if removing the heatsink while the set is on the
ceiling. The assembly weighs about 10 lbs and if you’re not ready for the
weight, it can fall to the ground, not to mention the possibility of giving you
a good size cut on your noggin.
![](images/Marquee_image03.jpg)
The astig and convergence connectors can only be plugged in one way, the V
output connectors however can be inserted either way on the board pins. This
allows you to flip the image depending on how the projector is mounted.
There are two flat ribbon cables connecting the V and convergence boards to
the motherboard in the set. Make sure that the right ribbon cable is used for
the right board as the two ribbon cable ends that plug into the motherboard are
different. Fortunately the motherboard connector is stamped as to whether it’s
for the C or V board!
There are no user adjustable controls on any of these boards. Failure of the
C and V boards can occur if the connecting cables get pinched in the case frame
(it can happen if you’re not careful when closing the case after a routine
service). If the V fail light comes on, there’s a good chance that the V board
section has failed. If you lose the ability to converge a color in either a N-S
or E-W direction, chances are that a section on the C board has failed.
I strongly recommend that you send the whole heatsink assembly in for
service, as the output transistors can easily be damaged in shipping if you
remove the PC boards from the heatsink.
Note also that the C board controls the various zones of convergence for all
three colors. The master H and V shift for each color (the zone in the middle of
each color) is actually controlled by the H output board. If you lose the
ability to do a master H or V shift for any or all colors, the fault is usually
on the H output board.
