Questions?
Contact us.
![](images/CR-100_tiny.gif)
Colorimetry Research CR‑250RH
Reference
Spectroradiometer
Includes Colorimetery
Research software, USB
cable, and tripod
mounting bracket.
ChromaPure software not
included |
Reference
Spectroradiometer
with ChromaPure
Professional
Also includes Colorimetery
cable, and tripod
mounting bracket.
ChromaPure info |
Sign up
today to receive the latest CR-250 and ChromaPure news.
Most US orders ship USPS Priority Mail
and international orders ship USPS Express Mail. International orders may include extra import
duties and/or taxes according to the laws of the target country.
Contact us for custom shipping.
Payment methods include PayPal and all major credit cards
(PayPal account *not* needed to pay by credit card).
Our payment processor
will automatically convert the
amount
to
your local currency. Given the nature of calibration software/hardware,
all sales are final.
Orders ship directly from
the manufacturer.
New to calibration? Give our
free step by step guide a read:
![](http://www.curtpalme.com/images/chromapure_header_wide_modified285.jpg)
Confused about meters? See our
FAQ: Which meter
is right for me?
The CR-250 is one of the most affordable reference spectroradiometer available. Just
mount on a tripod, facing towards the source, connect to
ChromaPure Professional, and then use as you would
any other color analyzer.
There are two colour analyzers that professionals and dedicated enthusiasts
generally seek: A professional quality colorimeter for every day work (the
"field" meter) and a reference spectroradiometer to keep the colorimeter
accurate (the "reference" meter).
Unfortunately, such devices are not cheap. The Photo Research and Minolta
reference spectros start at about $15,000 USD and go up to near $30,000 USD. The
Klein
K-10a, previously the only professional quality colorimeter on the market,
retails at $7,000 USD.
Now there is a new entry to the referemce spectroradiometer on the market, the
Colorimetry Research CR-250.
In our testing of the CR-250 we have found that it performs as well or better
than the JETI spectros, the only other
sub-$10,000 spectros on the market. It does this at the low price point of
$6990.
The CR-250 has all of the accuracy expected of a reference device and is fast
enough with enough low-end sensitivity that it can be used as a stanalone color
analyzer, though most will probably use it to correct a colorimeter. Its speed,
low-light sensitivity, and repeatability are world-class.
Design
The all metal design is rugged and practical. What is likely to surprise most
people seeing the instrument for the first time is how small it is. Resembling a
telescopic sight, it is slightly longer than 7 inches, 1.5 inches in diameter, and weighs
approximately 1 pound. The CR-250 is almost identical in appearance to the
CR-100, the company's very nice
professional colorimeter. The only visible difference is that the CR-250 is
slightly longer.
The CR-250 connects to a PC via USB, which also provides the necessary power.
The data interface is rs-232, which operates over the USB connection using an
internal usb/serial adapter and an in-house virtual COM port driver. It also
includes a tripod mount with several mounting slots for placement flexibility.
Available separately is a dual mount that allows the user to setup the 100 and
250 side-by-side, which is an ideal arrangement when using the CR-250 to correct
the CR-100.
The FOV is quite narrow. For example, when placed one meter from the target
the spot size is only 1.8 inches (46 mm) in diameter. Since the instrument has
no aiming mechanism this is a useful design choice. Given its small size and
narrow FOV, most will find it quite easy to get a good aim point merely by line
of sight.
The instrument ships with a nice carrying case with a usb cable and the
company's own in-house software. Most will probably opt for custom software,
such as ChromaPure which now provides
support.
There are two internal operating modes related to refresh rate detection and
synchronization. The meter's sync feature can be turned off or entered manually.
Unlike the CR-100, no automatic sync detection is provided. Sync is a
particularly useful feature and no doubt contributes to the instrument's
excellent repeatability, even at very low light levels.
Performance
The performance of a reference spectroradiometer is mostly a function of two measurable
criteria:
- Low-light sensitivity
- Speed
The two other typical standards of performance, color accuracy and
repeatability, are assumed as a consequence of the instrument's design. A
properly calibrated spectro of 5nm or better optical resolution should provide
accuracy to within ±0.0015xy and repeatability to within ±0.0005 within a
specified luminance range.
We compared the CR-250 to the in-house reference spectro, a JETI 1201, and
the instruments seemed to agree to very close tolerances, so we have no doubts
about the CR-250's color accuracy. Its repeatability was even better than the
JETIs, especially on certain display types.
Speed and Low-light sensitivity
Traditionally, the biggest drawback to a spectroradiometer has been its
relatively low sensitivity. They can be quite slow at low light levels and may
not read 10% video at all. Currently, the speed champ among reference spectros
is the JETI 1211. Comparing the CR-250
to the JETI instrument is not straightforward, because the CR-250 instrument has
four different operating modes:
To complicate matters further, the CR-250 oddly measures at different speeds
depending on the display type. The manufacturer's comment on this is:
"The observations about different exposures times for
different technologies [LED and others] is correct, and this can be explained by
the fact that the exposure algorithm adjusts the exposure times relative to peak
light level on the sensor, not by the average luminance. This is to prevent
pixel saturation/overload. The green component on the CCFL [LCD] is very sharp
compared to the green component on the [LED]. Both will provide the same
Luminance level but the shape of the signal is what makes the difference in
exposure times."
For example, it can require nearly three times longer (given a fixed
operating mode) to measure an LED backlit display compared to the time required
to measure a refresh display (plasma/CRT), traditional CCFL LCD, or front
projector. With the CR-250 in Fast mode, this is how the speeds compare in
seconds:
Video |
cd/m2 |
JETI
1211 |
CR-250
LCD |
CR-250
LED |
100% |
118.9 |
3 seconds |
1.2 seconds |
5.0 seconds |
90% |
94.6 |
3 seconds |
1.5 seconds |
6.2 seconds |
80% |
73.7 |
3 seconds |
1.9 seconds |
7.5 seconds |
70% |
55.2 |
3 seconds |
2.6 seconds |
7.5 seconds |
60% |
39.7 |
3 seconds |
3.6 seconds |
7.5 seconds |
50% |
27.4 |
3 seconds |
4.9 seconds |
7.5 seconds |
40% |
17.1 |
3 seconds |
7.5 seconds |
7.5 seconds |
30% |
9.6 |
4 seconds |
7.5 seconds |
7.5 seconds |
20% |
4.1 |
5 seconds |
7.5 seconds |
7.5 seconds |
10% |
0.69 |
13 seconds |
7.5 seconds |
7.5 seconds |
When measuring LCDs or plasmas, the CR-250 is actually slightly faster than
the 1211 at the top end, but at 60% and below the 1211 gains the advantage. Note
that in the Fast mode the CR-250 never gets any slower than 7.5 seconds. This
highlights another unusual feature of this instrument. The different speed
settings of the instrument not only affect the time required to measure light
sources, but it also establishes a maximum time for any reading, regardless of
its luminance. These are fixed values at:
- Slow (60 secs.)
- Normal (15 secs.)
- Fast (7.5 secs.)
- 2x Fast (3.75 secs.)
Many spectroradiometers—even those that have different read modes—establish a
minimum level of saturation to the sensors before a reading can be successfully
taken. The read time depends on how long is required for the required sensor
saturation. The Colorimetry Research approach has one drawback here. You can
never be certain that the maximum exposure time is sufficient to saturate the
sensors to the degree required to get an accurate reading. This is only an issue
at the very low end, but it does pose a challenge to those who may wish to use
this instrument as a primary working color analyzer that must take measurements
throughout the entire video range. It may require switching the read mode at the
very low end. As a practical matter, the slow setting will only be needed for
projectors.
The bottom line that that this instrument—as we would argue with all
spectroradiometers—is best used as a reference against which a tristimulus
colorimeter (such as the CR-100) is corrected. Regardless of the attempts of
engineers to make a spectroradiometer read faster and measure lower, they are
always going to be much slower than a good colorimeter.
So, how does the CR-250's speed compare to the
JETI 1211? It is almost impossible to
answer that question. If you are measuring an LED, then the answer is "no"
(except at 10%). If you are measuring other display types, the answer is
sometimes "yes" and sometimes "no". To complicate matters even further, when
measuring at 10%, you really need to use the Normal mode for flat panel displays
and Slow for projectors. Otherwise, you lose some accuracy. In fact projectors
benefit somewhat from the Slow setting even at 20%. Thus, the 7.5 second maximum
read time above is not realistic for the entire video range. 15 to 60 seconds is
a more realistic figure.
Summary
We were quite impressed with the CR-250. It manages to provide reference
performance with good speed and low light sensitivity. It does this at a
relatively low price. The JETI spectros are the only instruments in the same
price range as the CR-250. It's closest competitor, the JETI 1201, has worse
repeatability and cannot touch the CR-250's speed or sensitivity. The JETI 1211
also shows excellent repeatability and is, all things considered, somewhat
faster in the real world than the CR-250. However, it is also about 20% more
expensive.
We do have a few minor quibbles. We have found the virtual Com port driver
for both the CR-100 and CR-250 to be a little finicky. We have found myself
reinstalling the driver a couple of times and/or rebooting the PC when the
instrument would fully respond. These measures have always fixed the problem,
but they are an annoyance.
However, when it comes to price/performance ratio of the CR-250 we cannot
find any reason for criticism. It is without a doubt the best reference spectro
on the market at its price point. It also forms half of a compelling
professional combination along with the
CR-100 colorimeter. Just a few years ago $6990 for a fast, sensitive
reference spectroradiometer would have been considered unthinkable. No longer.
Specifications
Colorimetry Research CR-250 |
Detector: |
CMOS image sensor, 256 pixels |
Spectral Range: |
380–780 nm |
Spectral Bandwidth: |
5 nm |
Spectral Accuracy: |
± 0.3 nm |
Spectral Resolution: |
1.6
nm / pixel |
Luminance Range: |
0.05 fL to 45000 fL
(Sensitivities measured for 10:1 signal to noise (RMS)) |
Luminance Accuracy: |
± 2 %
(Measured with luminance level of 0.5 fL) |
Luminance Repeatability: |
≤ 1%
Chromaticity Accuracy: |
± 0.0015 x, y
Chromaticity Repeatability: |
0.0005 x, y
Polarization error: |
≤ 0.5 % |
Digital
Resolution: |
16 bits |
Objective Lens: |
50 mm * , 60 mm, 75 mm, 100 mm |
Custom Synchronization: |
10 - 10000 Hz |
Exposure Time Range: |
0.02 to
30 seconds |
Power Requirements: |
5V, 120 mA (600 mW) via USB 2.0 |
Interface: |
USB 2.0, Ethernet |
Weight / Mass: |
1.0 pounds (0.45 kg) |
*50mm lens is the standard lens included wih the instrument. All
others are special order.
Calibrating Front Projectors
For best accuracy, we recommend calibrating front projectors by taking
readings directly off the screen.
Extras included
- Colorimetery Research software
- USB cable
- Tripod mounting bracket
Calibration DVD For your convenience our ChromaPure
partner offers a simple calibration DVD that includes all of the test patterns
that you'll need to perform a complete calibration of your display. This DVD is
offered free as a complementary download.
Click here to download the DVD
Instructions:
- Download the .zip file to your PC.
- Unzip the contents, which is an .iso DVD image file, to
your hard drive.
- Double-click the .iso file.
- If you have DVD burning software (e.g., Nero Burning
ROM), the file will open.
Set the image type to DVD (not CD) if necessary.
- Insert a blank, writable DVD into your DVD burner, and
then burn the image.
Reviews/Testimonials
For reviews/testimonials of ChromaPure calibration software & packages, see our
ChromaPure order page.
Why buy from CurtPalme.com?
CurtPalme.com are calibration experts and authors of the popular
free calibration guide:
Grayscale & Color
Calibration for Dummies. We live and breathe calibration. No matter what
your needs we can assist in choosing what's right for you. We offer products for
the budget DIY'er all the way up to the seasoned professional, all at CurtPalme.com
discounted prices.
Links
ChromaPure software
ChromaPure
Grayscale & Color Calibration for Dummies
Official Colorimetry Research CR-250 Professional Colorimeter forum thread
ChromaPure Discussion/Support Forum
FAQ: Which meter
is right for me?
Colour
Science: About Meter Accuracy
Colour Science:
Video Calibration Myths
Questions, comments or feedback should be directed to
chromapure@curtpalme.com
