![](images/spacer.gif) |
CRT Primer
Updated: April 2006 |
Tube Life
The life of most picture tubes is rated at 10,000 hours by the manufacturer.
It is very rare that a picture tube will fail from one use to the next, although
this is possible. Most often, the tubes will simply wear out over time, but many
tubes can still be used at the 10K hour mark. Depending on the make and model,
the blue tube usually wears first, then the green, then the red in last place.
Usually, red tubes are useable well past the 20K hour mark. I have found that in
CRT projectors rated over 800 lumens that the green wears first, then the blue,
with the red again lasting the longest.
It is my opinion that the manufacturers came up with this 10,000 hour point
due to the fact that after 10,000 hours, the picture quality will be compromised
with regards to focus (in the case of ES focusing tubes, more on ES focusing
later), picture quality and brightness. The fortunate thing is, the change in
picture quality is so gradual that many people use their projector well past the
10,000 hour mark before changing the tubes. If you have ever been into a sports
bar and seen a CRT projector that has pink hockey ice and a puck that is so out
of focus that you cannot see it, you will be watching an ES focusing projector
that has in excess of 15-20K hours on it.
The good news is, a projector tube does not really wear if no light is
projecting out of it, as it is the phosphor surface that wears generally, and
not the electron gun of the CRT. So you can have a projector running for 10,000
hours with no light output out of it, and still have the equivalent wear on the
tube of about 500 hours.
The bad news is, a tube wears faster with a higher contrast and brightness
setting, so always run a projector at as low a setting as possible.
Another negative is, CRT projectors are very susceptible to static images
that can burn themselves into the phosphor surface in as little as 1000 hours.
This is why I have to junk a lot of projectors that come out of static image
computer installations. I have had CRT projectors that came from railroad
control centers with little railroad tracks permanently burned into the face of
the tube, which are then projected along with the video image you are trying to
view. This makes a moving video image impossible to watch.
Regarding video game use and computer display projection, there is no problem
running these on a CRT projector, however it’s a good idea to avoid continuous
long term displays of the same image, such as a Windows task bar, or a ‘game
over’ message. To prevent any kind of tube wear, turn the brightness and
contrast down as low as possible while still being able to watch an image. Since
video games have very little static information on the screen, and the screens
are always changing, even hours of game play will not result in any premature
tube wear.
![](images/+CRT_tube.jpg) Sony 07MS tube
As indicated, it is the phosphor surface that wears on a CRT tube. This
phosphor is sprayed on the inside face of the tube, and cannot be repaired once
burned or damaged. Over time, the phosphor becomes discoloured and this results
in decreased focus and light output. An imbalance in light output of the three
tubes results in poor colors, and a pure white image is no longer capable of
being produced.
Fortunately, the tubes do not wear evenly. In the projectors that I have
worked on, either the green or blue tubes start to show wear first, with the red
being a distant last. Blues and greens can show slight wear at as low as 2500
hours, reds typically last at least 20,000 hours. This makes complete tube
replacement not necessary, thus lowering the overall price of overhauling a set.
The final point at which someone decides to retube a projector lies with how
picky a person is about the overall picture. To put it in perspective however, 2
hours of CRT viewing per night is equal to only 730 hours per year. At the rate
that used CRT projectors are being sold for, it is not worth retubing a
projector in my opinion, depending of course on how much you have into the set.
A ‘freebie’ can always be worth retubing.
