![](images/spacer.gif) |
CRT Primer
Updated: April 2006 |
CRT Basics
A CRT projector works on the same principles as your home TV does, with a few
differences. Most video projectors do not have a TV tuner built in, so you need
a VCR or satellite dish as your channel selector and tuner.
The sound is routed
through your home stereo or surround sound system rather than through the
speakers built into the projector.
The video image is formed on three picture tubes, each of which produces one
of the primary optical colors. High voltage within the set is required to excite
the electron beam within the picture tube, which then generates light output
when the electron beam hits the phosphor surface of the tube. The red, blue and
green images are then aligned (or ‘converged’) on the screen to form one color
integrated image.
The main components of the video projector are the picture tubes. These are
three tubes that produce a high amount of light on the phosphor surface which is
then projected through lenses onto the screen. Myths surround these picture
tubes too.
In the next sections I will outline the
basic truths.
