![](images/spacer.gif) |
CRT Primer
Updated: April 2006 |
CRT vs Digital: Strengths and Weaknesses
To summarize the strengths and weaknesses of each type of projector:
CRT Positives:
Excellent image
quality |
No pixelation |
Excellent
black levels
(outperforming digitals
by a minimum of 10:1) |
Excellent
fleshtones |
Long
tube life: as
much as 15:1
over digital
sets depending
on operating
conditions |
Best
$/hour
performance
ratio |
Relatively
inexpensive
to
purchase
used |
Most
models
are
at
about
the
same
fan
noise
level
as
LCD
or
DLP
sets |
CRT Negatives:
Large |
Heavy |
Tubes are expensive to replace when
they wear out |
Not as bright as some current LCD or DLP
models |
Older models require ‘tweaking’
from time to time |
Not ‘plug and play’ |
Require a complete set up for a
change in screen size |
LCD/DLP Positives:
Small and light |
Simple 2 adjustment set up (focus and
zoom - making them more or less plug-and-play) |
No drifting or alignment of projector |
Decent fleshtones on DLP |
Less
pixelation on DLP than LCD |
Easy to change bulbs |
Recent models are significantly
brighter than CRT |
LCD/DLP Negatives:
Some non-HT units are objectionably noisy for home
theater use |
Short bulb life (1000-2000 hours
typically) |
Expensive bulbs ($300-$500 USD)
Noticeable pixelation |
Poor fleshtones on LCD (in my
opinion) |
Poor black levels |
Edge artifacting on most images |
Built as disposable units.
You’re not likely to get these repaired out of
warranty |
Many bulbs are not available 5-6 years after the model has been discontinued |
Rainbow effects from DLP’s can give some people headaches. About 30% of viewers
can see rainbows on single chip DLP units. You either get used to this or you get rid of the projector |
