Spyder2 colorimeter - how low can it go?
studio
Posted: Fri Apr 11, 2008 5:36 pm    Post subject:
Andrew Low wrote:
Kal - care to document exactly how you've got HCFR setup?
I plan on (hopefully) putting together some step by step instructions on how to do use HCFR with a Spyder2 sensor now that they're under $60 new! I've heard that the Spyder3 ($165) is even more sensitive so it may be a better option for someone buying new.
I suggest people use those links to buy their sensor - by the time it arrives I'll have instuctions as to how to use it with HCFR. Smile
To read as low as 10IRE, you just need to extend the time to 1000ms. I don't suggest you set it like that to take continuous readings when first playing with the gains/cuttoffs between say 30 and 70IRE, just set it there when you do the final 0-100IRE readings. 10 seconds per reading only takes about 2 minutes total.
Hey Kal
How is this coming, the step by step guide?
Steve
Posted: Wed Apr 30, 2008 7:40 pm    Post subject:
Ok, for those that aren't aware, my new GREYSCALE CALIBRATION FOR DUMMIES guide is now up for those that haven't seen it already!
Person99
Posted: Wed Apr 30, 2008 10:10 pm    Post subject:
EDIT: I'm getting really consistent readings as low as 10IRE using S2Fly and the Spyder2 sensor pointed at the screen, even if I change the angle a bit. I've got the read time set to 1000 (seems like 10 seconds).
Consistent does not mean accurate. Smile Everything I've ever seen says they cheapies are not really accurate below 30 IRE.
Posted: Thu May 01, 2008 12:52 am    Post subject:
That's true. Consistent does not mean accurate. But then, no projector seems to do well under 30 and even the pro's say to set the 10/20 IRE level by eye instead of with a sensor as none of the sensors (even the $1K ones) seem that accurate at low levels.
