Goto page Previous  1, 2, 3 ... 44, 45, 46 ... 62, 63, 64  Next
dvh99
Posted: Sun Dec 18, 2011 8:45 pm    Post subject:
draganm wrote:
ok, so it looks like this is still in the R&D phase Very Happy
dvh99 wrote:
the vreg is now gone.
scott i have put 2 diodes in series now, that was a good idea.
dragan, if you are going to use the sbyv27 you`d best place the diodes not on the backside of the board as there is not enough space.
I actually purchased the small ultra fast 100V SMD diode's Scott posted.
Your talking about putting 2 of the wire leaded Diode's in series like the factory did on the video neck-boards? If so, then yes, this will need to go on the front and the small 10K resistor on the back.
nope, it`s finished.
and yes, replace all the 1n4002s on the vnb`s, i have.
Posted: Mon Dec 19, 2011 6:43 pm    Post subject:
Drags replace those diodes on the VNB with the sbyv's Wink
arggghhh, I was just using that pic as an example, I'm not working on the VNB's at the moment Surprised Scott and Dennis were discussing that configuration now on the new Cree HDM to clamp the voltage in place of the old GTO's, AFAIK?
I had some SMD's here for that purpose but Scott is saying use 2 in series now so I don't think the SMD's will work, will have to buy the SBYV's and tent-pole them like the factory did on the neck-boards. That's all I'm saying Wink
Really am looking forward to this, just wish it was about 20 degree's warmer in the garage.
dvh99
Posted: Fri Dec 30, 2011 8:12 pm    Post subject:
and, any progress?
you guys are sloooowwww Mr. Green .
Posted: Fri Dec 30, 2011 8:29 pm    Post subject:
dvh99 wrote:
and, any progress?you guys are sloooowwww Mr. Green .
Ha-ha. The SBYV wire leaded rectifiers came in just 2 days ago. Had to get those after you guys put 2 in series. Plus I had an NEC I had to learn how to set-up which is only slightly easier than brain surgery.
so this weekend for sure.
Posted: Fri Dec 30, 2011 9:04 pm    Post subject:
Yeah I haven't ordered the parts yet. Drags will definitely get to it before i do. And I still have the Banding mod to do to my own boards. Arrgggg!!!!!
I just hired a new cook so I might have some more time, hopefully business will pick up, if not, I'll have time but less $$$ because of the new hire. Wink
dvh99
Posted: Fri Dec 30, 2011 9:19 pm    Post subject:
let`s hope this 1 can keep his hands out of the till.
Bodi79
Posted: Fri Dec 30, 2011 11:56 pm    Post subject:
Hey Guys !
After a few days of holiday i assembled the marquee again today (after modding everything) and fired it up.
The good news.. no more high pitch noises etc.
The bad news.. i cannot get the Marquee sharp anymore.
Did a complete reset, tried setting everything up again from scratch without any luck.
One thing i noticed, if contrast is lower than 25 the image is somewhat sharp.
As soon as i get over 25 itīs getting unsharper and over 30 it really bleeds.
Any suggestions what of the mods could trigger something like this ?
What i modded:
-Focus Board Mod (front to back everything one thing i didnīt add were the inductors coudnīt get them in time)
-VNB (front to back everything suggested)
-HVPS Mods (aswell every component swapped as suggested)
-Convergence Board (same as above)
-VDM (same as above)
-CLM (replaced C2/C1/C6/C7 with the caps suggested , did not replace the tantas cause the werenīt on stock)
Thanx for any suggestion
Ronald
P.S.: Stupid me should have tried one board after another but what can i say..
Posted: Sat Dec 31, 2011 12:41 am    Post subject:
Id check the HVPS with another spare if you had one. That is why I always do a few changes and test. doing a complete overhaul at once when you have not test each change makes it hard later to pin down what change might cause a certain issue, unless you have another set of stock boards to swap out. But bad focus might be a low G2 voltage due to rester change. If you saved the old restores from the HV measure them and see what they are compared to their markings. I found mine were from 560 to 680 and putting the original value of 560 caused issues. re ordering 680 values fixed the issue, i know this makes no sense but it is what I have observed.
Bodi79
Posted: Sun Jan 01, 2012 8:37 pm    Post subject:
Happy New Year to everyone !
@Athanasios
I donīt have Boards to swap but could isolate it somewhat.
Resoldered just for testing the original 6x 560k Resistors back on the HVPS .. no go same issue.
But if i start the Marquee without the Focus Board.. i have Focus back.
So my question is can it be some of the newer caps?
As suggested i replaced them with the 1000uf higher voltage Caps and the 470uf on the side with low esr aswell.
And offcourse swapped the Motorola chips with the Tle2074īs.
Thanx again
Ronald
Posted: Sun Jan 01, 2012 9:04 pm    Post subject:
Hmm, you might have blown the some of the 9 Mosfet's that rune in the middle of the board. Can you see if you have focus with any of the different internal resolutions from the menu?
What you do is put up a grid and go into the input menu( i think) and change the internal resolution and note which resolution if any are in focus. if so then it will tell us which mosfets are blown. The Focus board switches different film caps in and out of service for different resolutions trough these mosfets.
Athnaasios
Bodi79
Posted: Sun Jan 01, 2012 9:53 pm    Post subject:
@Athanasios
Well with the Board in place i donīt have any focus on any tube (or any grid).
If a mosfet would be blown at least one tube should focus. (i guess)
Just to be sure i resoldered 6x 470uf Caps back on and even the 2,2uf 250v back on..
Same issue.
Only component i didnīt put back is the TLEs (cause the motorolas wenīt in the bin) and even if one of the
TLEīs were damaged all 3 would be unlogical.
Btw. if i remove the Focus Board Green Focus is perfect / Red is okay/ Blue out of Focus (but that may be cause i didnīt correctly align everything after setting it up again a few days ago.
Thanx again
Ronald
Posted: Sun Jan 01, 2012 10:04 pm    Post subject:
Right Ronald, but I found that those IF520's can blow, all 9 at once or at least one of the resonant frequencies.
There was a way to test by shorting out the legs ( Source to Drain) to switch in the cap. So put the FCM back in and first try the internal frequencies one at a time, you might find the lower ones will focus but the middle wont and then the upper ones will.
So for example on the red channel Q113 is for the lower frequencies, Q114 for the middle and Q115 is the highest frequencies.
So to test you could set it for 1080p@60 and short out Q114 i believe. This would then put C119 into circuit for that frequency.
You would need an extender board to do this though or solder a jumper wire on the underside for easy accuses .
Scott led me through this before, i lost the text but from memory and reading the theory of operation manual I think I have the
method for testing correct.
Bodi79
Posted: Sun Jan 01, 2012 10:40 pm    Post subject:
@Athanasios
Thanx for youre help again.
I donīt have an extender Board..
But i will try setting a higher resolutions to see if it makes any difference.
Will search if anybody has a spare focus board for cheap so i have something to swap out.
Ronald
Posted: Mon Jan 02, 2012 9:34 pm    Post subject:
ok, first step on the Cree HDM mod. I must say I have a lot of trouble with the fact that the circuit is drawn nothing like it actually looks or is physically layed out on the board. I think the Diode's are facing the right way though. Red line is for a jumper I added on back side. Yellow lines are board traces I put on for reference.
 Filesize:  68.3 KB
 Viewed:  7027 Time(s)
dvh99
Posted: Tue Jan 03, 2012 2:02 am    Post subject:
don`t connect anything, the diodes are pointing in the wrong direction.
don`t forget u12 and u1.
and replace c6 with a 2n2 (2200pf) if you are going to use q5 and q7.
Posted: Tue Jan 03, 2012 6:04 pm    Post subject:
ok, well that's embarrassing Embarassed
dvh99 wrote:
don`t forget u12 and u1. and replace c6 with a 2n2 (2200pf) if you are going to use q5 and q7.
check. I'll work on this again tonight
Posted: Wed Jan 04, 2012 5:33 am    Post subject:
ok, got it all done including both u1 and u12 drivers. Everything except for the 24VDC splice/jumper.
I don't have 2n2's and 4n7's here's, they are all 6n8. Tired now, going to sleep
 Filesize:  58.54 KB
 Viewed:  7026 Time(s)
 Filesize:  52.42 KB
 Filesize:  63.37 KB
dvh99
Posted: Wed Jan 04, 2012 6:30 am    Post subject:
despite the fact that these fets will run cooler they do require a heatsink Mr. Green .
Posted: Fri Jan 06, 2012 5:17 am    Post subject:
LOL, Dennis are you moon-lighting in a comedy club? Laughing
So I looked at the back of the board at P11 and some of the traces look pretty thin. I want to tie directly into P12, pin 17 looks like the one carrying the 24vdc. My plan is to pull both the white shorting clips for safety, install the HDM in the chassis without the GOld metal cage, and check pin 14 with a meter. Question is I don't know if I can get down there between the cage and green tube.
Maybe leave the HDM out and probe the socket with a piece of small wire clipped into a lead?
Posted: Fri Jan 06, 2012 5:35 am    Post subject:
DRags you need to make yourself a couple extender boards buddy!!!
Page 45 of 64
