Goto page Previous  1, 2, 3 ... 22, 23, 24 ... 62, 63, 64  Next
Posted: Thu Oct 08, 2009 3:58 pm    Post subject: Re: EMI Tape
Ohmess wrote:
Would any of the 3M tapes be appropriate? Newark carries them.
Actually this might be perfect
3M™ EMI Shielding Tape has a multitude of uses in electronic design and test laboratories for prototyping, design and troubleshooting. Tapes with foil backings satisfy many requirements for effective grounding, bonding and EMI shielding. Aluminum, copper backings are available, both smooth and embossed, and with conductive and nonconductive adhesive systems. Both the unique embossed foil tapes and the smooth foil tapes with conductive adhesive offer excellent "through-the-adhesive" conductivity. A copper-plated polyester "rip stop" fabric backing is also available, providing shielding plus strength, flexibility and low weight. Available in custom widths from 1/8 inch to 24 inch, and comes standard on a 18 or 36 yard roll
the stuff with Conductive backing looks very good. Basically you could cover the outside of HDM cage, then ground the cage to the rear heat sink. vidikron actually grounded the HDM cage to the tube housings as a pathetic little "tweak" but this would be a big improvment. there's already a non-conduvtive/leaded shield on the inside of the HDM, another layer outside should help a lot. Mouser has 6 x 10 inch pieces for 3 bucks
http://www.mouser.com/ProductDetail/3M/AL25BT-65X10/?qs=RnLyf%252bIy6kFLhTb5wkJS4A%3d%3d
Posted: Thu Oct 08, 2009 4:47 pm    Post subject:
I am very curious about the magnefilm as its rated into the kilohertz, very low, this might be what we are looking for. I should build on of those Gauss meters that jarmo linked to, looks like a fun project just to see what the EM fields are like, also it really help with my barkenstien project I plan to get back to someday, hopefully Very Happy
Posted: Fri Oct 09, 2009 2:20 am    Post subject:
Here's a filament mod I did the other day. It's using only one inductor, but does an excellent job cleaning up the noise.
I'm sure I've played around with this before, and can remember doing a comparison with the scope and by watching the image. Also had an inductor on my test unit right at P14. Though I've been able to see a difference when looking at things on the scope. But have never been able to see a difference in the image. So that's why it was never implemented to my main Marquee.
Below are before and after shots. The before shots were taking a few weeks ago and from this same batch, I posted over on AVS. In each of the before shots, the two top patterns in the six pattern group are not matched (hue/tint). There's a green ting in the top left with a bit of blue in the top right, while the other four shows equal. Color balancing would not correct the difference.
In the after shot (taking today), both top patterns in that six pattern group are more equal. The horizontal lines are also more defined. What was more noticeable was the overall change in gray scale.
I'm still somewhat puzzled here, but from looking at the smpte pattern on the screen after the mod, it seems to have removed a color tinge that I was not able to get rid of on these boards.
I'm not claiming anything here yet, but there is a difference that I don't understand why and what's going on yet.
before (notice the color difference in the two top patterns - not corrected w/calibration)
recent (notice that the color difference is no longer there, the horizontal lines and overall gray scale difference)
Posted: Fri Oct 09, 2009 4:24 am    Post subject:
I see the difference, I wonder how this filament mod would alter greyscale? looks like you kept the original ferrite beads there and added the inductor and some caps to gnd , a simple LC filter. I agree why would this alter the grey scale that much ? You can see it did clear up the definition on the lines and got rid of the tint, but it gave the solid grey boxes a different shade of grey almost on the yellow side? I wonder what HCFR or Calman would show on the chart? if the whole scale shifted to the green/blue end of the chart? What was the voltage after the LC filter there?
HK-Steve
Posted: Fri Oct 09, 2009 6:46 am    Post subject:
Nice pics Mike,
What size was the inductor that you used??
I would be interested in testing a few values and see which is the sweet spot.
Strange about the correction on the color balance, or green tinge.
I see that you also added the 1uF caps at the diodes,
I put mine across the diodes,
Why did you go to ground?? , as I didn't see much improvement when I went to ground.
Cheers
Steve
Posted: Fri Oct 09, 2009 2:26 pm    Post subject:
that's a HUGE difference to my eye's! I can't believe no ones ever found this before. I mean people have spent hundreds of dollars to get a much smaller improvement than that. We have an increase in ANSI CR and color balance, that's a big deal IMO.
Posted: Fri Oct 09, 2009 2:43 pm    Post subject:
HK-Steve wrote:
Nice pics Mike,
Cheers
Steve
The inductors are 1uh. I'll post a picture of them later.
The filament rails are grounded in the LVPS (one side goes to ground). On the neck board they are floating the filament with only the diodes going to ground.
While running the noise down, i found it to be better to add the two caps where I have them. Not sure why, but it sure makes things look better on the test gear.
I placed 1uf, because I could not find my 0.1uf caps (which will be used there later).
The color differences are a problem caused from pushing the boards beyond their bandwidth. I basically replace the entire front end of the video section, that includes both driver transistors and Op amp. That upgrade yields higher bandwidth, but at the same time causes a distortion that has been a problem for me. On my Mikron boards, there's a blue variable trim cap that's designed to trim each neck board to eliminate that distortion if it shows on some of the boards.
Why the two images have a different gray scale is mostly because I did not check which boards went where when I removed them for the mod. But changing boards around would never effect this problem in those two top patterns before the mod. So seeing that problem go away after the mod, is a big plus. It did not go away when using the single inductor at P14 either.
two other things I've noticed, with one of them not making any sense at all. The black level or lower end became brighter. I'll check it out better later today, but there's definitely something different about the image.
Posted: Fri Oct 09, 2009 4:03 pm    Post subject:
I have noticed that black level thing also with my filter..Another guy with stock lvps reportet that he got much better blacks (mostly from reduced noise level/cleaner picture)
I did not noticed much difference at my Marquee (recapped lvps)
Maybe i should try also filtering at VNB and see how much there is difference between those two.
Mike, maybe black level rise is from that there is now less noise "modulation" to cathode. That can made that "sample" line voltage little different (there is not much lowpass at that line, so it is sensitive to noise)
DVDO VP-50
New hobby, Rally
Posted: Fri Oct 09, 2009 6:28 pm    Post subject:
this brings an intersting question to mind, are we running out of brigntness adjustment on the Marqee?
reason I say this the chrsity line fix raies brighntess a lot, the panasonic BD-80 palyer I have now does too, any kind of gamma boost will rasie it (even if just a little), and now removing noise from cathode heater is doing it too. Will there be enough adjustment left for full FFTB?
Posted: Fri Oct 09, 2009 7:13 pm    Post subject:
Drags I assume you will have to go into the G2's and adjust there for the proper black level afterwards, Lets wait and see what Mike finds first .
I cant wait till I get the 2nd PJ up on the ceiling so i can get back to what I really like to do , experimenting with different things on the Marquee.
My sore back has healed a bit so this past week little by little, 20 minutes at a time, i got the unistrut up to attach the top part of the pulley mount to. Now I have to take down my Trusty old M8000 and haul up the 2nd Long bow. But having screwed up the first Pj's mounting so many times this one will go up much smoother.
I am still curious if the voltage for the filament changed much from the P14 pin to the point after mikes mods on the VNB? I wonder if lowering the heater voltage would change that brightness issue. if I am not mistaken doesn't that voltage contribute some to how Bright the overall tube will Project. i remember reading somewhere that somebody had the voltage too low and when they raised it to the Proper 6.35 volts the image brightened up? So maybe that cleaner heater supply is like having more voltage to the heater? Hmm Would that then speed up decay of the heater element as if the p14 voltage ran away on you?
Posted: Fri Oct 09, 2009 10:00 pm    Post subject:
yes, i have an LVPS here modified by someone else that reads 6.23VDC, it's is noticeably dimmer.
It's easy enough to check at the heater pins, i'm not sure if the Inductor would have an effect or not. Only way to check is to measure.
Posted: Fri Oct 09, 2009 10:14 pm    Post subject:
A picture of the inductor I'm using (including one without the shrink).
Absolutely NO DC voltage drop..........
If I get a chance later, I'll hook up the digital scope and do a dual trace showing a stock board in comparison.
Posted: Fri Oct 09, 2009 10:36 pm    Post subject:
Ok, no voltage drop. one variable out of the way. So it could be as I mentioned then; the cleaner supply voltage acts as a higher voltage. But since the spec's for most tubes heater elements is 6.35 volts , and I am sure they do tests with supper regulated voltage supplies, then we may be just seeing the CRT behaving as the original designers intended? What do you think Guys?
So Mike when you say an elevated low end do you mean it is just brighter or that the shadow details are more pronounced now?
Posted: Sat Oct 10, 2009 10:30 pm    Post subject:
I'm not sure how to answer this. I'm not sure of what's going on with it, or why this is happening. I'm not trying to believe it's related to the filament mod, though I can say there is a difference in the test patterns horizontal lines. The elevated brightness puzzles me.
What I've been waiting to show is the G2 mod. That I'll be showing on Williams Blend setup next week.
I thought I had already done it on my 9500, but found out yesterday that it was not done. So I'll make that happen in a few and will try and take a few screen shots of a few previous Blu Ray/scenes. Maybe the two changes will show in the shots.
Posted: Sat Oct 10, 2009 10:40 pm    Post subject:
Oh you mean the inductor you added? What frequencies of noise does the G2 line show? That is one place I am afraid to scope, my scope shows 400 volts max input so i am a bit leery to look there. I just got my new scope delivered today the 2445A Techtronix, that too is 400V max, now is that Ac or DC? I need to find a manual for this one, my 2335 came with one.
I am going to go lower the M8000 and get the Longbow ready to put up top Very Happy
tse
Posted: Sun Oct 11, 2009 5:16 pm    Post subject:
draganm wrote:
tse wrote:
Yep, those FB43-422-RC jobs should do a pretty good job. Remember, if you add a small cap (0.1uF = 1.6 ohms @ 1MHz) after the bead, it will really help to cut the noise down. Probably a larger cap would help more. Filters are kinda funny to calculate. Try your idea and see the results. Always the best method.
Scott
Scott the FB43-422-RC shows a range of 40 to 200Mhz. Do you feel that's a better choice than the FB73-422-RC? That ones shows a range of up to 40Mhz. Or maybe stack both if they fit?
The FB73-422-RC parts would be a better choice than the FB43 in this situation. Brain fart on my part. I meant the lower frequency range parts. Doh!
Scott
Thomas Jefferson
tse
Posted: Sun Oct 11, 2009 5:22 pm    Post subject:
http://i604.photobucket.com/albums/tt130/mp20748/Picture6800-1.jpg
http://i604.photobucket.com/albums/tt130/mp20748/Picture6790.jpg
http://i604.photobucket.com/albums/tt130/mp20748/Picture6799.jpg
That is very interesting! What are the faint, fine vertical lines showing in the screen shots?
Scott
Thomas Jefferson
Posted: Sun Oct 11, 2009 5:28 pm    Post subject:
Scott
I see them now Scott, do you mean the ones you can see in the solid grey squares? i wonder if its just the Screen material texture?
Posted: Sun Oct 11, 2009 6:00 pm    Post subject:
Scott
That is the surface of the screen itself. You can even feel it if you run your finger nail along the screen.
It's a really old electric Draper screen that I paid about $21.00 for almost 14 years ago from a company I used to work for.
It was OLD stock they wanted to take out of inventory.
Not only does the lines show up on clear surfaces in the image. It also distorts the vertical one pixel lines if you look at them closer. It used to really bother me and it effects more of the image than what shows in the shots. But it's to be expected from something that's most likely was made back in the 80"s
We'll be going to an 8' wide DIY screen soon. JB is coming down to help me put one together. And I'll finally get to see what those one pixel lines really look like on my setup.
Good eye!
Posted: Sun Oct 11, 2009 9:35 pm    Post subject:
Here's two shots showing the lines. I have a piece of plain white paper taped to the screen right on the vertical one pixel lines.
Both shots are not well focused, but they should give a good idea of what's going on with the screen.
Page 23 of 64
