marquee hfail vfail question
voodoo7869
Posted: Sat Mar 01, 2008 10:41 pm    Post subject: marquee hfail vfail question
I have a problem with the marquee I have tried different vims to no avail what else could cause bolth lights at the same time?
Marquee 8000 modded, Marquee 9500lc with LUGs, Frankenyokes, and Moome. My avatar is not just a black box. CRT Is KING!!!!
Joust
TV/Projector: Marquee 8501LC
Posted: Sat Mar 01, 2008 11:03 pm    Post subject:
sounds like HVPS...
voodoo7869
Posted: Sat Mar 01, 2008 11:28 pm    Post subject:
what part of the hvps? should i be looking at it will energise the tubes sometimes but will not show a pic. when i turn it off and on again right away i get bolth lights then every time after that i get bolth lights.
Posted: Sat Mar 01, 2008 11:35 pm    Post subject:
No, I don't buy the HVPS issue. THere's nothing within the HVPS that can trigger the error lights.
In that case, if it's not a bad CLM, you could have separate H and V issues. It's a matter of swapping boards at your end with another Marquee to see if the error lights go out. If not, send me the boards for testing here.
voodoo7869
Posted: Sat Mar 01, 2008 11:40 pm    Post subject:
ok i wil do first I will try swapping boards from my 8000 late model to see if it is fixed
Joust
Posted: Sat Mar 01, 2008 11:44 pm    Post subject:
you had CLM seating issues in the past didn't you?
I'd try cleaning the connectors on it.
voodoo7869
Posted: Sun Mar 02, 2008 12:46 am    Post subject:
yes but i removed all the chips on at a time and cleaned them as well at the board and still nothing I cleaned the daughter boards as well and no luck.
I will try swapping in my clm from my 8000 and see what happens it should be compatable with the 9500 boards shouldn't it?
Posted: Sun Mar 02, 2008 1:59 am    Post subject:
It should be but you might loose some functions but at least it should fire up. reseat all the other boards and also check the daughter board on the HDM and reseat that. Also check the two plugs that go into the vertical deflection modual and the convergance modual that connect it to the mother board. if you have recently disconected them for any maintanence work you may have not connected both rows of pins. Basicaly just go though out the entire set and reconnect evrything, you might get lucky.
voodoo7869
Posted: Sun Mar 02, 2008 2:14 am    Post subject:
will do I will let you know what happens
the_avguy
Posted: Sun Mar 02, 2008 6:24 pm    Post subject:
voodoo7869,
Have you managed to find the problem yet?
I have exactly the same thing happening on my 8000.
working ECP 4100.
marquee still in pieces, just gathering knowledge.
optoma ep729
voodoo7869
Posted: Mon Mar 03, 2008 6:49 am    Post subject: he
not yet i have not had time i will on tuesday though I will post what the problem was.
the_avguy
Posted: Sun Mar 09, 2008 12:17 am    Post subject: Re: he
Did you figure out what the problem was?
working ECP 4100.
optoma ep729
voodoo7869
Posted: Sun Mar 09, 2008 6:40 am    Post subject:
I am waiting on some boards from a fellow member I will let you know. here are some of the things i have done clean and reseat the clm (chips and addon cards.) clean and reseat all boards. and daughter cards. no effect. I have tried swapping the clm from an 8000 no joy swapping deflection processor boards. no joy. I am waiting on a vdm because mine was modded for 16x9 and they destroyed a couple of traces. but if i put the 9500 clm into the 8000 i don't get a picture I got a no sync once then i never got anything again. it might be a compatability issue not the board no error lights.
I will say this with all of the 9500 boards installed i hear a whine when i put it in standby it is hard to discribe goes form low pitch to high pitch very fast if you can picture vvvvvvvtt low to high like something has a frequancy issue. if anyone has any thoughts please by all means I ahev tried several vim s and no luck.
listenlounge
Posted: Sun Mar 09, 2008 8:13 am    Post subject:
Strange question....
Have you had the LVPS out of the chassis lately?
voodoo7869
Posted: Sun Mar 09, 2008 9:42 am    Post subject:
yes during the cleaning process? why?
listenlounge
Posted: Sun Mar 09, 2008 10:48 am    Post subject:
Don't get your hopes up but....
There is another possibility.
If the connector for the LVPS has been damaged, and the pcb edge connector is not making full and proper contact, then any or all diagnostic leds on the clm can light up.
I had a lvps connector that had been forced against its wishes and the mounts simply snapped. The result was a poor connection that presented with similar symptoms.
Follow this thread https://www.curtpalme.com/forum_archived/viewtopic.php@t=6315.html
It's not that hard to diagnose - just remove the LVPS and put your hand in and push ( gently of course and after the HV has had a chance to dissipate ) on the black connector. if it moves backwards - bingo.
Good luck
voodoo7869
Posted: Sat Mar 15, 2008 11:23 am    Post subject:
ok found the problem thanks curt it was the clm. no i have another problem the raster is lit constantly no matter what i do I have the g2 at zero and drive at zero with brightness and contrast at zero and raster is lit and unstable. any ideas where to start? that is the last problem i have then i can setup the pj.
All help is appreciated.
John
voodoo7869
Posted: Sat Mar 15, 2008 3:03 pm    Post subject:
so does any one know what this could be?
Posted: Sat Mar 15, 2008 3:11 pm    Post subject:
John
is this for all tubes or just one? Also have you done the hvps mods?
voodoo7869
Posted: Sat Mar 15, 2008 3:18 pm    Post subject:
just one the other tubes seem fine
