9500 Focus Board - what sort of resistor is this
PaulB
Posted: Wed Feb 20, 2008 3:16 pm    Post subject:
Also on that board change out...... (snip) the 3 2.2uf 250 volt to 2.2 305 volt,
Any specific part number for this? I found this one http://uk.farnell.com/jsp/Passive+Components/Capacitors/EPCOS/B32924C3225M/displayProduct.jsp?sku=1112849&_requestid=75401 which matches the specification you provided but just want to double check its the right type.
I'm buying up the parts for future use Thumbs Up
Paul
Posted: Wed Feb 20, 2008 3:27 pm    Post subject:
Paul
Yep thats the ones i used.
PaulB
Posted: Wed Feb 20, 2008 3:29 pm    Post subject:
Thanks Athanasios.
Paul
PaulB
Posted: Sat Mar 08, 2008 4:44 pm    Post subject:
And another question from the mindless masses!
You recommended changing the MC34074P opamps on the Focus Board but what about the HDM? There are three MC34074P's there although they have the suffix of CTE09521 instead of KDE9452 that the Focus board has. Can the TLE2074's be used in the HDM as well or is the MC34074P chip in the HDM a different one?
Maybe there is no real gain in changing these anyway?
HDM
thanks,
Paul
Posted: Sat Mar 08, 2008 6:15 pm    Post subject:
They can be changed if you want , the second set of numbers/letters are date codes of where and when they were made. I have not looked at that boards schematics or read the service manual. its one i will look at some time in the future. I am not sure if they control anything worth while realting to any line placement that could affect stability. But if you have extra chips why not put in lower noise ones it couldnt hurt but might not make a difference either.
