XG raster lighting up...sometimes
kschmit2
Posted: Thu Feb 14, 2008 3:29 pm    Post subject:
Doug will have to confirm, but you may have to enter the service passcode first for the settings to really stick.
At least it's worth a try Smile
Bert Randolph
Posted: Thu Feb 14, 2008 3:31 pm    Post subject:
Hm, sounds easy enough to give it a try Smile
Posted: Fri Feb 15, 2008 12:16 am    Post subject:
Try this:
Put up a full white screen test pattern.
Turn on AKB in the INFO menu (in service mode).
Store
Turn off AKB
Store.
Does it help?
Juvental604
Posted: Sat Feb 16, 2008 8:11 pm    Post subject:
I have a Nec Pg 6 and Im having a problem with akb too. When its enabled theres a thick white line at the top of the image that wont go away even with blanking. I tried enabling it the way you guys said in this thread but that didnt work..although im guessing thats cause the xg is different.
kschmit2
Posted: Sun Feb 17, 2008 9:35 am    Post subject:
The PG behaves exactly the same way as the XG.
The NEC AKB system is designed in a way that you don't have to keep AKB enabled.
Typically you would enable AKB after a tube swap, an every couple of hundred hours.
In normal operating state you would have AKB disabled.
Kai
Posted: Mon Feb 18, 2008 8:08 am    Post subject:
LOL, the white line is the AKB line..Wink
