Programming a Crestron Part 2
Goto page Previous  1, 2, 3 ... 12, 13, 14, 15  Next
Posted: Tue May 06, 2008 5:05 am    Post subject:
Nice to see ya back Jeff ! Thumbs Up Thumbs Up
Hell_Hound
Posted: Mon Jun 16, 2008 1:38 pm    Post subject:
Hi i have a crestron CNMS and a touchpannel however i have no clue how to config it AND i don't have the software
can ANYONE please help me?
Hell_Hound
az_max
Posted: Fri Jul 11, 2008 7:31 pm    Post subject:
Hell_Hound
the info jeff presented here can help you get it working. If you can find an older copy of any of the Crestron software online, the update feature will be able to get you the newer versions of all their software.
Hell_Hound
Posted: Sat Jul 12, 2008 10:07 am    Post subject:
thanks for your reply az max i managed to get the software now i've just got to get the time to have a serious sit down and play with it Smile
nmliving
Posted: Sun Oct 19, 2008 11:08 pm    Post subject: Crestron
Just finished up on a demo of a conference room that used to belong to one of the major computer company's and ended up with a crestron control system from it. It is an older CNMU and 2 Ct- 3500 touch screens. I would very much like to use this system in my theater ( which is all older but good equitment). I have programed many other HA control systems in the past but like most of us out there who come across this older crestron eqiptment I am unable to locate the software since crestron restricted downloads from there site.
Any help would be very much appreciated.
Thank's nmliving
jkv
Posted: Wed Oct 22, 2008 1:35 am    Post subject:
you would be better off tossing that stuff and picking up a more up-to-date processor from ebay.
nmliving
Posted: Wed Oct 22, 2008 10:04 pm    Post subject:
Hate to toss any kind of stuff that is still useable.
This system was currently operating everything just fine before removal. I know it is older but will be a good system to practice on while looking for upgraded eqiptment.
KES
Posted: Thu Nov 27, 2008 8:40 pm    Post subject: OK. whatever happened to Jeff?
This thread has just died. Anyone know what happened to Jeff? Got my system going great, except for the serial control to the Barco 1208. Anyone have experience in troubleshoting this issue?
What does not kill you, makes you stronger.
jkv
Posted: Fri Nov 28, 2008 6:27 pm    Post subject: Re: OK. whatever happened to Jeff?
I might be able to help you out; what type of Crestron processor are you using and what problem are you having controlling the Barco?
KES
Posted: Sat Nov 29, 2008 1:56 am    Post subject: MP2 to Barco 1208/2 serial hook up
I am running an MP2 with com A to Barco 1208 RS232 in connection. I have used Systembuilder to build the programming, and have had no problems with it. I am using the Barco 1208 module supplied by Systembuilder. I have also checked the serial cable against the Crestron cable database, and pins 2,3,and 5 match. When I run Real-Time, I see the signals are being sent, but no change at the Barco. I have also checked that the baud rate for both ends are the same. Serial settings are 8 data bits, 1 stop, no parity. Can handshaking settings be the problem? I'm at the end of my troubleshooting expertise. Any suggestions would be greatly appreciated. Thanks jkv
jkv
Posted: Sat Nov 29, 2008 9:21 pm    Post subject: Re: MP2 to Barco 1208/2 serial hook up
By "real-time" are you using ViewPort or Toolbox? When you say "signals", do you mean the serial strings that are output from the MP2? What do those look like? Do they match the protocol doc for the 1208?
9600/8/1/NP is standard and if they match up that's fine. The COM ports on a Crestron processor are non-standard so make sure the cable is correct on *both* ends.
Not sure what your level of expertise is with the Crestron tools (or if you have access to them). If you have access to either TestManager or the Toolbox Debugger, make sure the serial strings going out the port are correct. If they are and there is no response, use something like HyperTerm (or ViewPort in passthru mode) and connect the 1208 to your PC and send the strings directly to see if it responds.
Is there a setting on the 1208 to "enable" the rs232 port? Some devices have an enable/disable in their settings.
try that and let me know...
HTH
KES
Posted: Sat Nov 29, 2008 10:05 pm    Post subject:
I'm using Real-Time as in Systembuiler. I have Toolbox, but havn't used it. Real-Time just shows I have pressed a button and the MP2 processed it. I don't see any serial strings. My level of expertise with Crestron Tools is nil. Embarassed There is no enable for the 1208 rs232 port that I am aware of.
jkv
Posted: Sat Nov 29, 2008 10:18 pm    Post subject:
KES wrote:
[snip]
I've never used SystemBuilder; all of the systems that I do I program in SIMPL and SIMPL+. I would find the serial strings needed by the 1208 to perform the functions you need and use HyperTerm (or something akin to it) to send the strings to make sure the device responds. You also need to make sure that the strings are being sent out the COM port of the MP2. So, in order I would:
1. verify the strings that need to be sent to the 1208
2. verify they are being sent out the COM port of the MP2.
what Crestron s/w do you have besides ToolBox?
KES
Posted: Sat Nov 29, 2008 10:38 pm    Post subject:
Viewport, SIMPL, SIMPL+, Systembuilder, Toolbox, Pro-E, DEAL, Applicationbuilder, and any other s/w Crestron has. I do the updates. Where can I find the strings for the 1208?
jkv
Posted: Sat Nov 29, 2008 10:51 pm    Post subject:
Look in the 1208 manual, sometimes they are there. If not, chk the support section at Barco to see if they are available. If you can't find them there, search the Webatron using your favorite search engine Smile. You could also open up the Crestron 1208 macro in SIMPL (or SIMPL+; I don't know which one it is written in) and poke around in there. If it is written in SIMPL, look for a "serial I/O" symbol in the logic folder; that is *usually* where the strings are sent from unless the protocol requires some other fancy logic.
KES
Posted: Sun Nov 30, 2008 6:33 pm    Post subject:
Found the problem! Embarassed The Barco address is 1. The crestron module assumes 0. Simply had to add a step to switch to 1, when I access the Projector pages on the touchpanel. Thumbs Up Thanks for your help jkv. Can put the Barco remote in storage! Always seems to be the simplest oversights that cause the greatest headaches.
jkv
Posted: Sun Nov 30, 2008 11:03 pm    Post subject:
good find Thumbs Up
english_1969
Posted: Thu Jan 01, 2009 3:33 am    Post subject: Question on ST-LT
after reading this thread I was able to get my ST-CP and ST1550C working quite well.
I now have a grafik eye (3000 6 zones) (which is working and is wired up with a GRX dry contact interface).
I am trying to get my ST-LT programmed in to the ST-CP.
Right now, I am simply trying to get a button to activation a preset on the GE.
I have been able to get the ST-LT loaded into simpl and appear to have the needed drivers for the GR eye, but I can't seem to figure out what signals to connect to get it to work.
When I press the button on the touchpanel, I can see the red light got the lutron OUT on the ST-LT activate, but nothing from there.
Any suggestions?
W
jkv
Posted: Fri Jan 02, 2009 9:28 pm    Post subject:
I've never used a ST-LT, so take this with a grain of salt, but this is what I think (and what I would do).
The ST-LT provides two (2) interfaces, (1) port A connects to the MUX link and (2) port B connects to a PC running Lutron control s/w; you shouldn't care about port B since you don't want to connect to a PC (do you?). Since both of these ports are really serial drivers each with a serial transmit/receive, you should be able receive feedback from the grafix eye on the rx$ line from port A and send cmds via the tx$ line on port A. So I would:
1. use viewport to see what the rx$ line coming from port A looks like (feedback from the grafix eye). Since you have a ST-CP, you will need to add a "serial debug" symbol to your program to view serial data in viewport.
2. you should be able to tie touch panel presses to a SIO symbol and send cmds directly to the grafix eye (via the ST-LT) using the tx$ line on port A of the ST-LT.
3. go to the Lutron web site and search; you should be able to find the rs232 cmds/syntax you need.
ping me if you need more help
english_1969
Posted: Fri Jan 16, 2009 6:36 pm    Post subject: Still not working yet
Well,
I've gotten the ST-LT somewhat working, but I cannot seem to actually get a scene change.
Using a serial debug symbol, I am able to pickup strings from the ST-LT that correspond to changes in the GE when I change the scene from the GE itself or from the GRX-AV.
So, it looks like I'm talking to it, however, when I do the :G command, I get a response, but i get this (in effect) 'NNNNNNNN'. So it looks like my GE is not responding to this request properly.
One question - I installed my GE and never changed anything out of the box. Do I need to specifically set the address of the GE? I see how to do that from the manual, but didn't do it - could that be the issue?
w
Page 13 of 15
