Marquee fan mods How to use a 12v fan on the marquee
Gino
Posted: Tue Jan 29, 2008 3:15 am    Post subject:
fireanimal wrote:
If I do some testing to ensure the amperage load, the current design will work for 4 fans. The circuit can currently work with up to 2 amp draw with no cooling. Any more than that there would have to be heatsinks installed on some of the components. If you were to tell them amperage rating of the fans that you intend on using that would help.
I belive though that most fans to not draw that much wattage.
Fans are 0.12A / 1.44W
I'm pretty useless when it comes to this stuff, is this pretty easy to install? As I said, I'd like to use it for both my projectors, so I'll need 4, how much will this cost me and how soon can they be made?
fireanimal
Posted: Tue Jan 29, 2008 3:26 am    Post subject:
4 fans are well under the amperage load. Please PM me.
Thanks.
Gino
Posted: Thu Jan 31, 2008 12:52 am    Post subject:
Thanks fireanimal. I'm actually going to get Joust/Barry to contact you and order some on my behalf. Cheers
Posted: Thu Jan 31, 2008 1:13 am    Post subject:
There was apost on AVS in the fan mod thread about runing four silenex fans, i think he ran them two in series and two paralle with those 2 in series and it worked fine turned out to be same draw as 3 24 volt fans.
Joust
TV/Projector: Marquee 8501LC
Posted: Thu Jan 31, 2008 1:37 am    Post subject:
we want to avoid that, if one fan dies it takes out two. Its better to use an efficient switching regulator.
PaulB
Posted: Fri Feb 01, 2008 9:35 am    Post subject:
This is how I wired up my 4 belly fans;
I take it this is perhaps not the best way to do it?
Paul
voodoo7869
Posted: Fri Feb 01, 2008 9:43 am    Post subject:
it would work fine till one fan goes out then you lose half of your cooling and that can be bad for parts. other than that it would work just fine if you had a way to monitor the fans you could do it this way. like a buzzer or something to let you know you have a fan failure. or an led to tell you they are ok. you get the idea.
Marquee 8000 modded, Marquee 9500lc with LUGs, Frankenyokes, and Moome. My avatar is not just a black box. CRT Is KING!!!!
PaulB
Posted: Fri Feb 01, 2008 11:27 pm    Post subject:
Got it John , excellent!
Paul
