It's HT UPGRADE time!!! (My new G70!)
Goto page Previous  1, 2, 3
Posted: Mon Jan 21, 2008 8:14 pm    Post subject:
Lots of experimentation ahead. The 1271 was cake. Set it up painstakingly well, run everything at 1080i. Looks good. Done.
I've never worked with a 1271, but I found the G70 to be a major PITA to set up. I thought my XG was much easier, if that gives you any idea, and the XG was the first projector I ever had. I still fight with the G70.
Posted: Mon Jan 21, 2008 9:39 pm    Post subject:
Wow, and I've always heard Sony's were pretty easy and the NEC's were a little on the tougher side. Interesting. I always thought the 1271 was cake to set up. Very straightforward of course with no scheimpflug or EM focus. Geometry was even pretty easy to get right if physical setup is good.
So, 1271 - Easy. G70 - Eh, not so much. Granted, physical setup consisted of nothing more than dropping a level down from my mounted projector to make sure the green lens was close to center. We used some 2x4's to prop the ass end up to get the raster somewhere near center vertically, and the projector was sitting close to screen center. Even though the projector has to be within an inch or less of center/square, I'll be damned if could get geometry decent. I kept going back and forth between bow, pin, skew and key, and I never did get a nice straight horizontal. Of course, then I found out there was the additional 'balance' control on... what, pin and bow, maybe. I haven't even read up on what those do. Which reminds me, I haven't really read the manual at all. Embarassed
That'll make some good bedtime reading for the next few nights.
mtmelvin
Posted: Mon Jan 21, 2008 10:34 pm    Post subject:
I've never been a big fan of the balance controls on the G70. On the G90 you get separate Key, and Pin adjustments for left, right, top and bottom where as on the G70 you get Horizontal Key, Horizontal Key Balance, Horizontal Pin, Horizontal Pin Balance, (and the same controls for Vertical). I absolutely hate that and its really my only gripe about the G70. Fortunately they improved the controls on the G90.
Despite that, I've always liked setting up the G70. But even if you struggle with it for a while it will be well worth the effort. The G70 (esp with such low hours) should stomp all over your 1271.
-Mark
Posted: Mon Jan 21, 2008 11:03 pm    Post subject:
It's good to hear you still liked setting it up. As for the stomping - believe me - I can see that will be the case already. Even with (as my friend called it) the trailer park setup, it's throwing a simply amazing image compared to what the 1271 was throwing (which was damn good already, imho.) Seriously, short of a full-on calibration (something like a Ken Whitcomb type would do), I think my 1271 looked almost as good as you can make it. I'm not joking when I say I'd take it over practically any 720 digital.
So, seeing what the G70 can do in spite of a train wreck of a setup, I'm almost giggling to myself thinking about how incredible it will look set up correctly, hanging on the ceiling with the convergence, geometry, flapping, focus and EM focus all dialed in to perfection. Oh, the anticipation.
That reminds me, I gotta get order out those fans from Newegg and do the fan mod to get rid of the flakey one. Has anybody else done the mod besides whomever it was that took the pics? Any issues?
Posted: Mon Jan 21, 2008 11:22 pm    Post subject:
I haven't done the fan mod yet but plan to before my G70 gets mounted
Posted: Mon Jan 21, 2008 11:30 pm    Post subject:
Zebu Fellenz wrote:
..... before my G70 gets mounted
Carfull or you'll have a bunch of D-50's running around Wink
fireanimal
Posted: Mon Jan 21, 2008 11:31 pm    Post subject:
Just watch you don't run the active image area to far to the sides of the tubes, that's were I ran into problems with mine with bad geometry in the corners. I think the recommeded amount is 7mm, but maybe one of the experts will know for sure. Even with the bad geometry it threw an amazing picture!!
Posted: Tue Jan 22, 2008 12:10 am    Post subject:
Mr. Green If I get twin D-50's can I trade them in for a G90
Posted: Tue Jan 22, 2008 12:11 am    Post subject:
No but you can put them up for adoption on the fourm. Someone will take them in, clean and care for them and it they get ornary they'll cut them up for parts Shocked
Phil Smith
Posted: Wed Jan 23, 2008 7:52 pm    Post subject:
Person99 wrote:
What's your screen size/viewing distance relationship, Phil?
Phil is over 1.5x back from a rear projected set up.
Dave's right SC. I'm not sure, but I think I'm 1.8-2.0 back. I forget that most people prefer to sit a lot closer than I do.
So my opinion about scans line doesn't count. I'm so far back they're not much of an issue.
Phil Smith
Posted: Wed Jan 23, 2008 8:10 pm    Post subject:
This is true! You already have yours mounted SC, so it's a mute point now, but one really needs to make a compromise between maximizing phosphor use and minimizing lens distortion. Push the pic too far towards the edge, and the lenses really start screwing up the corners. Correcting the corners electronically causes problems in other areas. Next thing you know, you have one big cluster f*ck*** mess.
I get really good geometry out of my G70. The horizontal line should be easy to get straight. A few of the zones will also help straighten it, but you should only need a little, if any, zone for that purpose.
Might not hurt to read the manual. Wink Experience will make things a lot easier too.
Gary,
You may have a lemon. I've never heard of anyone having as much trouble out their G70 as you seem to be having. Most G70 owners are pleased with their PJs.
Posted: Wed Jan 23, 2008 8:57 pm    Post subject:
Phil - No, I don't have it mounted yet! It's sitting on a stand behind my head - right under the 1271 that's on the ceiling. So, I'm just data gathering right now.
According to PJCalc, the G70's throw seems to be about 6 or 8 inches longer than the 1271 (I can't remember exactly.) I don't have a lot of flexibility in my mount point on the ceiling, but it's enough I think. I should be able to push it far enough back. We'll see. I'll have to do some tests with it on the floor (to simulate the ceiling), I think to be sure. All I know is I'm a stickler for good geometry and corner focus, so I'm definitely not going to push the rasters out too far.
Hey, can a couple of you G70 guys give me your projector-screen measurement, screen size, and how far your rasters are pushed (and how you like the geometry and corner focus/convergence.) I definitely want to be conservative. Maximized rasters are great, but I don't want to have problems like Gary is having with his geometry. Maybe with enough data, we can compile a good guideline... along the lines of: If you're using approximately the standard projection angle, throw should be 1.2-1.25x screen width (did somebody say 1.22 was optimal?). At 1.3, the raster will be too small, and at 1.15, you'll start having trouble with the corners... or something like that.
I'm waiting to hear back from Curt to see if he has any spare mounting plate's laying around he can sell me and Axatax is going to send me a spare OEM fan he has to replace the one on mine that won't spin up every time... THEN I'll be in HT nirvana. I was hoping to get it on the ceiling for next weekend, but that probably isn't going to happen unless I fab up a mounting plate myself... and I'm too damn busy at work to get specs to somebody to cut me some plate, etc.
winduptoy
Posted: Wed Jan 23, 2008 10:28 pm    Post subject:
PJ to screen - 92"
Screen width - 72"
960p72
more details later...have to eat.
Axatax
Posted: Wed Jan 23, 2008 10:55 pm    Post subject:
If you can find a Chief mount, these are even better (and usually less expensive) than the Sony. While they look like the stock mounts, they will allow the projector to slide forward, back, left, right, swivel (with pole mount), and tilt. They also seem to be easier to find in the usual venues (Videogon, etc.). These mounts really let you nudge the PJ into perfect alignment.
Posted: Thu Jan 24, 2008 1:25 am    Post subject:
I think I have one these, or at least a copy. While it sure is nifty to have all those adjustments on the the mount, it's important to note that this all adds up to a height of about a 6". that's about 3 times taller than a typical lo-pro design of 2".
Posted: Thu Jan 24, 2008 1:56 am    Post subject:
Yeah, I can't use one of those. In fact, the way I designed my mount, the projector's mount plate actually recesses right into a cavity in the ceiling. As I tighten the bolts on my mount the bottom of the projector tightens right up to hug the ceiling. It was sweet with the 1271 mount plate because the whole damn thing went up into the ceiling. It won't be quite as nice with the G70 because the mounting plate is quite a bit larger. Plus, when I shift it back, it's going to go to the back of the joist bay, so I'm going to lose a little headroom.
It's already tight with the riser right under the projector - the projector would be obnoxiously low with one of the adjustable mounts. All I really need is the plate, anyway! My mount is dead-ass square to the screen, and perfectly on center (within 1/16"), so I'm not worried about any adjustability besides closer/farther (which I accounted for).
Stupid builder for not asking and stupid me for just assuming houses were all built with 9' basements these days. 93" sucks.
fireanimal
Posted: Thu Jan 24, 2008 2:24 am    Post subject:
Rasters are maxed close to 2mm from the edges, 102" Throw to the front of the lens 78" Screen, and I have severe corner distortion. I still not sure if it is bad lenses on my G70 or what??
Maybe you can start with a small raster on a grid pattern and start to enlarge it until you see the corners start to fall, and that would be the point that I would stop.
If you are watching video only, I would not worry about it, becuase it has had zero effect on that. It is my windows desktop on my HTPC that really pisses my off!
greg_mitch
Posted: Thu Jan 24, 2008 11:25 pm    Post subject:
Not a single picture yet? This is an awesome upgrade I would imagine. Congrats SC.
Posted: Thu Jan 24, 2008 11:33 pm    Post subject:
No, I'd bet it's your setup. You're supposed to keep the image about 7mm from the edge, if I remember right. Try shrinking your raster size and see if the corner distortion clears up.
Posted: Sat Jan 26, 2008 7:13 am    Post subject:
Thanks - yes, it's an awesome upgrade. I still can't believe it, actually. Damn, I'm excited to hang it up and go town on setup. Patience...
Guys, here's a little mystery. I was farting around with the G70 after the movie and found something interesting. A sticker on the aluminum shroud inside is marked serial number 2000097, while the serial number in the service menu is 2000112. I wonder if the CPU boards in this set were replaced at some point??!? I'd think that's why the hours were so low, too if the tubes weren't totally pristine and the inside of the set completely clean and dust free. The plot thickens...
I'll snap a photo of the beast on the test stand tomorrow. Still trying to find a mounting plate so I don't have to fab one, and the fan now fails almost 100% of the time, so it will be damn nice to get a replacement in there.
Page 3 of 3
