I miss the Evil Twin. I lost the tse gamma design
beun
Posted: Tue Jan 15, 2008 7:09 pm    Post subject:
If people are interested I can create a small box with just the adjustable gamma portion of the RTC2200, I am willing to open up the schematics as well, no secrets here.
ESL-0.5 Full Range Electrostatic Loudspeakers | RTC2200 Component to VGA Converter with Gamma Boost
papalek
Posted: Tue Jan 15, 2008 7:38 pm    Post subject:
This would be perfect to go with the HDFURY.
I do love my AmPro's
Posted: Tue Jan 15, 2008 7:48 pm    Post subject:
Now there is a match. Scott and Kim together with a bit of collaboration could make this the best gamma card ever ! Wink
jask
Posted: Tue Jan 15, 2008 8:14 pm    Post subject:
I know that a d.i.y. job of this sort is not for everyone here but the fact that people like Scott and Kim are around (and so generous!) and willing to share the knowlege they have and results of all that work.......
You guys are a couple of Class acts!
Thank you.
tse
Posted: Wed Jan 16, 2008 1:37 am    Post subject:
jcmccorm wrote:
Hey guys, I'm just following the circuit to see what Scott has done there. Is it complete? Where does /Sample go? What about RED and RED_SW? Seems like something is missing. Thanks.
Cary
Right you are. The video DC level is sampled during the /Sample pulse and is restored to 0VDC. The video has to have it's black level at 0V for the circuit to work properly.
Scott
 Filesize:  7.85 KB
 Viewed:  8734 Time(s)
Thomas Jefferson
jcmccorm
Posted: Wed Jan 16, 2008 3:07 am    Post subject:
Thank you very much Scott! That clears it up. I'm still trying to figure out exactly how that DC restore works (particularly the opamp with the series cap in the feedback path. I think I'll Spice it...)
One question though, the output of the comparator in your sync circuit swings to both +5 and -5 and drives a 74HC86. I wouldn't think the HC input would like that (or I'm wrong and the comparator only swings between +5 and 0).
Thanks again Scott. Really clever circuit.
Cary
tse
Posted: Wed Jan 16, 2008 4:12 am    Post subject:
Pin 1 of the comparator sets the most negative excursion. It's at ground so the output swings from 0V to near +5V. The XOR gate is happy. When the /Sample input to the mux is at ground the RED and RED_SW nodes are connected together. If, for instance, at that time the video signal is slightly positive (in respect to U7-5 or ground) the output of U7 will move toward -5V which brings the video signal back to 0V. The DC restore works pretty good, as it needs to, for the circuit to work right. It's actually more complex than the gamma part of the circuit. If your video source had it's video restored to 0V that part of the circuit would be unecessary and could be connected directly to the gamma circuit.
Scott
Thomas Jefferson
v_erich
Posted: Wed Jan 16, 2008 3:02 pm    Post subject:
@beun:
That would be great, so it would be also a buffer for the non-buffered outputs of the HDFury.
VGA input from the fury to plug it in directly and BNC outputs for the "old" installed cables, so you can use a short HDMI cable to the fury and everythng is fine.
Would be really a great upgrade for thr fury.
Erich
beun
Posted: Thu Jan 17, 2008 6:32 am    Post subject:
I just finished a new schematic, I will post tomorrow.
Kim
beun
Posted: Thu Jan 17, 2008 3:40 pm    Post subject:
Attached the PDF with the proposed schematic based heavily on the RTC2200 gamma backend.
Kim
Gamma_v1_0.pdf
 Filename:  Gamma_v1_0.pdf
 Filesize:  91.38 KB
 Downloaded:  356 Time(s)
v_erich
Posted: Sun Jan 20, 2008 9:31 am    Post subject:
looks good and simple, I like that.
Some comments:
- the power supply is very simple, why are you using so poor 7805 regulators?
- Please at least add some 100n caps between I-G-O of the LM7xxx regulators.
- I would use seperate opamps for each color, 300MHz opamp are to less for HDTV because you
don't have the right slew rates what are needed for this signals, min. 1GHz would be recommended.
I use for cheap things the AD8058 (SO8).
- a lot of supply names are wrong
- output connector should be 5x BNC (not VGA like now)
- the name on the VGA input should be in not out?
Regards,
Erich
beun
Posted: Sun Jan 20, 2008 7:41 pm    Post subject:
Erich,
The 7805 regulators aren't actually that bad, the output electrolytic capacitors take care of all the low frequency noise (if there) while the 100nF caps across the supply close to the opamps take care of the high frequency noise.
The AD8058 opamp you recommend doesn't seem to be that much better than the LT1399 (325MHz vs 300MHz and 1000V/us vs 800V/us) while the 1dB flatness is actually worse 28MHz vs 150MHz, but I will look for another convenient video amp.
You are right about the supply names, I just copied it from another schematic and forgot to change the names.
I know some of you would like BNC's at the output but when I keep it as VGA I can put this in a very small dongle format instead of a large case.
I just named it OUT, it is just a name to tie the signals together in the schematic, the actual name is of no importance.
Kim
v_erich
Posted: Sun Jan 20, 2008 7:58 pm    Post subject:
Hi Kim,
thanks for your answer.
I know, that the AD OP is not much faster, but you can stuff other better opamp in the same case on the position, thats the improvement Wink
I use very often regulators from linear technology for better power supplies, normally they make a big imporvement in the viewable performance.
If you use VGA out, the people have to buy a expensive vga2bnc cable.
I have installed a very good bnc2bnc cable, I don't want to buy a new one for that, therefore a bnc out would be great, but if not I will install it in a bigger case and make bnc connectors for me only on it Laughing
Maybe you can foreseen some holes and via's to solder real cables on the pcb directly for the pimpers out there...
Erich
Posted: Fri Jan 25, 2008 11:07 am    Post subject:
Just bumping this back to the front page. I got a tse board from Tom and will try it this weekend. My weekend will be spent pre-wiring a new rack location. My home office is being turned back into a bedroom. I'm getting booted to the garage. A little extra work and a lot of peace and quiet Wink
tse
Posted: Fri Jan 25, 2008 1:37 pm    Post subject:
You'll get your best performance if R1, R2, & R99 are as shown.
Scott
 Filesize:  9.71 KB
 Viewed:  8457 Time(s)
Thomas Jefferson
Posted: Fri Jan 25, 2008 4:00 pm    Post subject:
Scott do you know if Buttsplice used your revised circuit in the large batch made over at the ET ?
Posted: Sat Jan 26, 2008 12:38 am    Post subject:
Hey Kim, could you make one of these boxes with a MP 1.4 circuit on it and a VGA HD-15 in and VGA HD-15 out?
Think HD-Fury add on. Gama and a driver stage for long cables. Thumbs Up
beun
Posted: Sat Jan 26, 2008 2:58 am    Post subject:
I am already working on a gamma dongle, but what is a MP 1.4 circuit if I may ask?
Edit:
I found it, I don't think that anyone complained about the output driver on the RTC2200.
Kim
Posted: Sat Jan 26, 2008 5:03 am    Post subject:
Edit:
Kim
No you are correct. They didn't. Just thought it could be a neat joint project.
beun
Posted: Sat Jan 26, 2008 3:14 pm    Post subject:
As I understand the MP 1.4 circuit is more of a replacement for the cheap video card antialiasing filter, but I have to defer to MP as the actual authority on it.
Kim
Page 2 of 3
