Help a noob set up a E-home ECP 3000!
Clarence
Posted: Wed Jan 23, 2008 6:50 pm    Post subject:
Hinken wrote:
Sry guys, I couldnt link the pictures :E If all of you complain I guess I have to change to name on everyone and reupload them Razz
Instead of renaming and re-uploading, you could just replace the space in the image name with "%20"...
http://uppladdning.com/uploads/20080123_18.22.06_CRT%20006.jpg
http://uppladdning.com/uploads/20080123_18.22.40_CRT%20009.jpg
http://uppladdning.com/uploads/20080123_18.22.27_CRT%20008.jpg
http://uppladdning.com/uploads/20080123_18.22.58_CRT%20010.jpg
http://uppladdning.com/uploads/20080123_18.23.09_CRT%20011.jpg
http://uppladdning.com/uploads/20080123_18.23.17_CRT%20012.jpg
http://uppladdning.com/uploads/20080123_18.23.28_CRT%20013.jpg
http://uppladdning.com/uploads/20080123_18.23.38_CRT%20014.jpg
http://uppladdning.com/uploads/20080123_18.23.47_CRT%20015.jpg
http://uppladdning.com/uploads/20080123_18.23.57_CRT%20016.jpg
http://uppladdning.com/uploads/20080123_18.24.10_CRT%20017.jpg
And then you could use the IMG tags to place them inline...
Hinken
Posted: Wed Jan 23, 2008 7:02 pm    Post subject:
Thx clarence..
The last 4 pics are in the green and blue lens.. Does anyone have a idea on to how get the whole picture? What have i done wrong?
My PJs: Sanyo PLV-Z3 , Electrohome ECP 3000
Nitmoe
Posted: Thu Jan 24, 2008 5:13 am    Post subject:
Running with powerstrip, it should be really easy to get the rest of your image to appear. Go into the advanced timing options, and use the size and position buttons to center and resize the image. If you have trouble the the PJ losing sync during this process, hit the check box that says lock scan frequencies. Also, have you done the focus and astigmatism adjustments that I suggested before? Judging by your images and menu screnn, you have some problems with focus, it should be somewhat sharper, depending on how hard the tubes have been run.
Hinken
Posted: Thu Jan 24, 2008 6:27 am    Post subject:
Nitmoe, I havent done that yet, and I think I can get better focus, this is just a quick setup Smile
Will try some more with pstrip later today.
Hinken
Posted: Thu Jan 24, 2008 8:32 pm    Post subject:
I wanted to redo all settings, I thougth I could try that, maybe that would fix my picture, so that I get to see everything, not just almost everything. I thinked it helped, i now have a 4:3 image on the wall ( or something like that). Before i had a 16:9, dunno what I had done to get that. Now i see the whole menys etc.. But now I cant get a image from my computer... I have tried several resolutions and hz. Nothing.
What have I done now? Smile
Nitmoe
Posted: Fri Jan 25, 2008 4:21 am    Post subject:
I'm guessing you followed the instructions and did a hard reset? If this is the case, in order to get back to a 16x9 you need to push the size button, then press the down arrow to reduce the vertical size back down to the widescreen ratio. Also, adjust the horizontal size to maximize the raster (within the wear area, if it has any). To get the computer image, you may need to select the correct source. There are two slots in the back of the projector, 0 and 1. Slot 0 comes empty, but you may have a card installed in it. The slot 1 has the large connector for a switcher. So for example, if you are plugged in to the 4 BNC input on the same card as the round connector, you need to press source,1,1 (I think, or it is source,1,2) to select the computer signal. Also, in powerstrip, be sure to save your settings once you get a good image, and give it a name like 1080i ECP or 720p ECP, or something easy to remember, then you can more easily switch between resolutions, and be sure to resave if you make any changes, and give it the same name, so it overwrites the old settings.
Hinken
Posted: Sat Jan 26, 2008 10:10 am    Post subject:
Yes, I did a hard reset. I gave up last time, and when I started the PJ yesterday, I had apicture from my pc :S Im gonna mark the sheet hanging on my wall so I can get 16:9 Smile
And, the more space I use on the tube, the more brigther image I get?
Hinken
Posted: Sun Feb 03, 2008 12:05 am    Post subject:
Time for a new post.
Yesterday me and my friend moved the PJ into the HT. We didnt have any serious to mount it on(floor mounted). First off, we never got 16:9, the image was a little too high, I had the HSIZE VERT on 0 and HSIZE HORZ on 10. Still it wasnt 16:9 Sad (The image from my laptop)
Computer image VS the internal menys?
The computer image was smaller than the internal menys, are there any settings that I can make in the pc? In powerstrip to get the image to fit my 16:9 screen? Razz 1280*720 @ 60Hz am I running..
And if the PJ looses its convergence when shutoff, is it the Dallas ship thats bad..?
