Hinken
| Posted: Sat Jan 12, 2008 1:04 pm Post subject: Help a noob set up a E-home ECP 3000! |
Hi
I have a E-home ECP 3000, and I need your help to set it up propelry. I will not put it in my HT yet, I have it in my room now, and want a decent picture on my wall, before i put it in the HT.
Yesterday me and my friend tried to get a picture following the HELP in the proj. The green was unfocused and we couldnt get it any better. So we began on the red, that one had better focus. But we couldnt get them to lie ontop of eachother. The manual said that we had to loosen the B bolts, so that we did, and then we were supposed to move the lens, but that we couldnt do.
And when we pressed "Source" all of our settings disapeared.
Today i thougt I would check how bad the tubes were, so I removed the lensens, and I dont see any wear on them, so I suppose they are pretty good. I will get some pictures later.
Now to my main problem, the picture is jumping, we got rid of that yesterday, but I cant figure out to do that now. I tried V hold and those. Nothing.
I have the lenses removed atm. There are som pots under the rear cover, what are those for?
Please help me
_________________ My PJs: Sanyo PLV-Z3 , Electrohome ECP 3000
klover
Joined: 30 Sep 2006 Posts: 124 Location: Winnipeg, Manitoba
| Posted: Sat Jan 12, 2008 2:31 pm Post subject: |
Jumping picture can be fixed by combining your Horizontal and Vertical sync cables (using a T adapter) and plugging them into the H-sync BNC connector.
Hinken
| Posted: Sat Jan 12, 2008 5:20 pm Post subject: |
How do I fix the jumpy picture when I dont have a source connected? Its fine on the top and on the bottom of the picture, but not in the center.
EDIT: I managed to get the picture stable and in focus. But I now have a new problem, if I use Vsync @ auto, the picture has the normal size but theres a black box which goes from bottom to top.
If I have Vsync @ manual, the box disappears but then the picture is too small, I dont see all text.
Please help me
| Posted: Sat Jan 12, 2008 8:43 pm Post subject: |
What signal are you running to the projector?
Hinken
| Posted: Sat Jan 12, 2008 8:45 pm Post subject: |
I dont have any signal connected to the proj, if thats what you mean. My father will buy a vga>bnc on monday.
| Posted: Sat Jan 12, 2008 8:47 pm Post subject: |
Ok that sounds like the best plan. When you get the cable try running 640 x 480 or 800 x 600 and see what happens.
Hinken
| Posted: Sat Jan 12, 2008 8:52 pm Post subject: |
So I should wait for the cable and then do all the settings? The proj isnt ready to show any images from a source yet, many settings to set first.
Will the cable fix my problems when Im in the "Help" meny doing all the focus settings and etc?
| Posted: Sat Jan 12, 2008 9:40 pm Post subject: |
I can't say for sure, but, when setting up a CRT projector it's usualy best to have a stable signal running into first.
klover
| Posted: Sun Jan 13, 2008 7:38 pm Post subject: |
The ECP jumps WITHOUT a signal.
| Posted: Sun Jan 13, 2008 8:18 pm Post subject: |
Thanks Klover, I wans't sure. Haven't had one of those grace my door step ( yet )
Hinken
| Posted: Sun Jan 13, 2008 9:25 pm Post subject: |
Thanks guys, I will probably get a cable tomorrow, will post result then
Nitmoe
| Posted: Sun Jan 13, 2008 9:37 pm Post subject: |
I had the same problem with my 4100. With no signal connected, the menu screens were jumpy. Once I hooked to the HTPC they were fine. I use an Extron VGA to RGB converter, and run 720p60, this seems to produce the best image on mine, probably the same on yours.
Hinken
| Posted: Tue Jan 15, 2008 8:18 pm Post subject: |
Having truble once again, I have a computer connected, got a pircture before, but I cant get one now. Running 800*600 and 56Hz. And now the whole picture jumps up each 2 seconds and the picture go out of focus each 3 seconds or so.
What am I doing wrong? Give me some tips?
EDIT: Still have the problem with the V hold, if I use it at manual i do not get the whole picture in the menys, but if I run it at auto I do, but then theres a black box going from bottom to top of the picture.. I want to get rid of these problems im having so I can start with the controls My focus in the menys are great, after I adjusted on the pots inside.
Once again, please help me, or give some tips on what I can do, what I do wrong etc, ask if theres something you need to know to help me.
Hinken
| Posted: Wed Jan 16, 2008 1:37 pm Post subject: |
Noone.. ? :/
| Posted: Wed Jan 16, 2008 3:03 pm Post subject: |
Did you combine the H and V sync?
Keep in mind that a 3000 is now almost 20 years old. Change the Dallas chip, do a hard reset. I have tested and working boards that I can sell you for cheap, my advice is to get a spare V board, waveborm board and RGB input board.
Hinken
| Posted: Mon Jan 21, 2008 8:12 pm Post subject: |
Good news!
My problem was very easy to fix, feel kinda stupid that I didnt test that earlier..
I updated my gfx drivers, downloaded powerstrip so that I could enter a custom Hz, and now I have a picture on my wall from my computer. Running 1280*720 @ 51 Hz. I will be doing all the options this week, hope I get a nice image
More updates coming when I have done something
| Posted: Mon Jan 21, 2008 8:19 pm Post subject: |
There you go. Keep at it.
Nitmoe
Hinken
