nomadII
| Posted: Fri Jan 11, 2008 8:20 am Post subject: |
Dave,
Settle down before your wife bans you from the forum again. Use your post wisely!!
How & why would anyone argue about this? Is C.W. McCall your next door neighbor?
My guess is that it would cost me more to find 50ohm cables than 75?
Ah the 50 Ohm coax.
First use: Los Alamos, New Mexico
Trinity Project
It was the only thing they could find that would transmit data prior to destruction due to a very inhospitable climate.
Note: Back in the day it was Fast!!!
chillman
Joined: 09 Apr 2007 Posts: 134 Location: Germany, Bavaria
| Posted: Sun Jan 13, 2008 1:59 pm Post subject: |
Can anyone tell me what type of coax-cable can be used for video? Can I use RG-59? Thanks!
Joust
TV/Projector: Marquee 8501LC
| Posted: Sun Jan 13, 2008 3:21 pm Post subject: |
Yes but be careful, RG58 is 50ohm. RG59 is 75 most commonly used in Cable TV installations.
chillman
| Posted: Sun Jan 13, 2008 3:33 pm Post subject: |
So it doesn't really matter which cable I use as long as it's 75 Ohm? I want to make a RGBHV cable for my projector. RG59 is quite cheap, (20$ for 100m) so I wonder if it's good enough for a 10m connection to my Projector.
Joust
| Posted: Sun Jan 13, 2008 3:45 pm Post subject: |
At that price, try it and see.
jkruger
| Posted: Sun Jan 13, 2008 4:16 pm Post subject: |
I'm no EE but I have never seen any difference between 50 and 75 ohm cable in the 30 yrs I have been messing with this stuff, except for one application, a scanner antenna. I tried to go with the cable I had (75 ohm) when I put up my first big scanner antenna and it was obvious that I wasn't getting nearly the signal strength I should have been. I switched to RG-213 (much bigger conductor and better shielding) and the difference was amazing. I started pulling in low power transmissions from literally hundreds of miles away instead of ten. It's the best I have ever used. RG-11 is supposed to be better. Too big for hooking up video stuff though.
| Posted: Sun Jan 13, 2008 4:26 pm Post subject: |
| chillman wrote: | | So it doesn't really matter which cable I use as long as it's 75 Ohm? I want to make a RGBHV cable for my projector. RG59 is quite cheap, (20$ for 100m) so I wonder if it's good enough for a 10m connection to my Projector. |
For that distance, I'd use RG-6. The price difference shouldn't be that significant for the 100m spool you'll need. By far, the most expensive part will be the BNC connectors... $x * 10.
I was going to build my own cable, but the BNC connectors (or the tools to crimp them if you go that route) get pricey enough that a pre-made cable made plenty of sense - it was way cheaper. I bought one of these just to try and it works beautifully:
https://homenetworksupply.com/products_details.aspx?theme_id=1454900095&department_id=4629350247&sub_id=5457350208&product_id=3735708845
It was cheap enough, I couldn't even buy the BNC connectors for that price. I'm not pushing 1080p into a 9"-er, though, so I wouldn't know if they weren't excellent.
Joust
| Posted: Sun Jan 13, 2008 4:39 pm Post subject: |
Ah yes, this is exactly the point made earlier.
Radio uses much higher frequencies and MUCH MUCH lower signal levels.
therefor with Radio you WILL see a huge difference, but with direct connected sources at video frequencies, you should see nothing.
chillman
| Posted: Sun Jan 13, 2008 10:21 pm Post subject: |
| ecrabb wrote: | | It was cheap enough, I couldn't even buy the BNC connectors for that price. |
I know that it doesn't make too much sense if you do this because of the price, but I can't see how the BNC connectors should make a self-made cable that expensive. They cost from 30 (european) ct. for a crimp version to 50 ct. for a solder version each, so 5€ for the connectors for one cable + ~10€ for the 5x10m cable is 15€ for a 10m RGBHV cable. This would be quite cheap if it would provide a good connection.
| Posted: Mon Jan 14, 2008 5:17 am Post subject: |
Chill,
It depends on how many cables you are making for it to be worthwhile. You can get a good quality tool for under $100. The connectors I think are around $2.
| Posted: Mon Jan 14, 2008 5:28 am Post subject: |
The connectors I was thinking of were like $10/ea. and I was looking at $50 worth of Belden RG-6 snake. So, you'd have $100 in connectors, a $100 crimp tool, plus the $50 worth of cable... and the time of getting it all and putting it together. I decided $250 was a little steep and I had too much other stuff to do. Now, with more of my racking going HDMI, I'm even more glad I didn't build it myself.
But, with $2 connectors, cheaper RG-6, and a less expensive tool... It's not a bad idea at all. Go for it!
