Fujifrontier
Joined: 20 Oct 2007 Posts: 354 Location: San Antonio, Texas
| Posted: Mon Jan 07, 2008 3:15 am Post subject: |
lmao
| Posted: Mon Jan 07, 2008 3:22 am Post subject: |
This is a joke right ? Cineramax has gone over the edge ...
| Posted: Mon Jan 07, 2008 3:48 am Post subject: |
Wow, he can't honestly believe that some air coming out of registers at a whopping 10-15 degrees warmer or colder than the ambient temp in the room is going to result in any visible artifact of any kind... can he?
Actually, I wonder if he's confused about where that effect can happen. It CAN happen near the lens - and the focal plane of the film/imager. Our crappy Infocus portable DLP blows hot air (think hair dryer temp) out the front right into the optical path. The result is an obvious "swirling" in the image, especially noticeable if you walk right up to the screen. However, we're talking about low-velocity swirling air that's must be AT LEAST 150-degrees - what, 80 degrees over ambient office temp?
I think the chances of seeing any visible artifact whatsoever as a result of the mildly heated or cooled air from an HVAC system is slim to none.
| Posted: Mon Jan 07, 2008 4:47 am Post subject: |
| Curt Palme wrote: | | LARD works like a highly directional, high power megaphone, able to blast sounds (such as crowd-dispersal instructions in Arabic) in a narrow beam and with great clarity at a deafening 150 decibels (50 times the human threshold of pain). |
It's tasty, too.
| Posted: Mon Jan 07, 2008 5:56 am Post subject: |
Mmmmm LARD ( Homer drool sound )
oliverg
Joined: 15 May 2007 Posts: 800 Location: Melbourne, Australia
| Posted: Mon Jan 07, 2008 1:33 pm Post subject: |
Sometimes my ex-wife would lie down mostly naked in front of the screen and the heat from her body would cause distortions in the image.
I explained how she was ruining my PQ. Women!
_________________ ( R ) G ( G ) 9 ( B ) 0 ( R ) G ( G ) 9 ( B ) 0
WTS
| Posted: Mon Jan 07, 2008 2:09 pm Post subject: |
Yeah right! And when I fart while sitting in my HT viewing position the hot air raising really affects my sight line too.
_________________ Thanks
Walter
| Posted: Mon Jan 07, 2008 2:45 pm Post subject: |
| WTS wrote: | | Yeah right! And when I fart while sitting in my HT viewing position the hot air raising really affects my sight line too. |
Dude, that's not thermal distortion! That's your eyes watering!
| Posted: Mon Jan 07, 2008 3:04 pm Post subject: |
| oliverg wrote: | Sometimes my ex-wife would lie down mostly naked in front of the screen and the heat from her body would cause distortions in the image.
I explained how she was ruining my PQ. Women! |
This post is useless without pictures!
Ile
| Posted: Mon Jan 07, 2008 3:31 pm Post subject: |
I have seen thermal distortion in Infocus LP130 presentation dlp projector, that had cooling air exhaust next to lens.
nemmi69
| Posted: Mon Jan 07, 2008 5:07 pm Post subject: |
I have decided that I need to wear some thermal gear so that my body heat wont affect my picture and as for having friends round!....................
_________________ What doesn't kill you is only biding it's time
joerg
| Posted: Mon Jan 07, 2008 6:21 pm Post subject: |
Well last weekend I have been to a Cinema and this heat distortion was a bit of an issue.
In still frames you could see the hot air moving from the bottom of the picutre to the upper part.
I think this was hot air that was moving directly in front of the film because it was sharp and the air waves were around a foot long.
But with my CRT I have never noticed this problem (LC)
JOerg
_________________ My Girlfriend thinks size matters and she is right!
Owner of the uglyest Barco 808sLC
jkruger
| Posted: Mon Jan 07, 2008 7:20 pm Post subject: |
When I was a kid my next door neighbor was the projectionist at the local theater. We used to go up to the projection room to say hello and check it out. They used a high voltage carbon arc to illuminate the screen thru the film, and there was a lot of smoke and heat from it. Sometimes we could see it on the screen, not sure if it was smoke or heat though. I suppose if you were doing some arc welding during a movie in your HT you might notice a difference in the picture....
