Marquee HVPS smelling hot. Oh boy.
Goto page 1, 2, 3  Next
Posted: Wed Dec 19, 2007 3:30 am    Post subject: Marquee HVPS smelling hot. Oh boy.
I'm watching a movie tonight on my 9500LC and then suddenly I get a faint smell of hot electronics.
A few minutes later the smell comes back and it's a bit stronger.
I'm not the kind of guy who waits for the fireworks. I shut down the whole system and start sniffing
for the source.
It's in the PJ. It's in the HVPS. I pop off the HVPS cover and it's apparently toward the middle of the board,
and as best as I can tell the parts that were getting hot are the two big 5 watt carbon comp 200 ohm resistors
in the middle of the board that are stacked on top of each other.
The HVPS (34.9 KV model) works as of now. But I do tend to believe that it's going to eat itself if I don't take
care of an impending failure.
So who's good with these units and can troubleshoot them before they explode? Shocked
It'll be cheaper and easier to fix it NOW than AFTER the fireball, I think.
Any suggestions would be appreciated. If you're confident that you can repair the unit, let me know
and we'll make a deal for your services.
There's a lot I can handle in a Marquee but I don't mess with the HVPS. No documentation, no parts support,
no desire to ride the lightning.
I'll replace components if someone with a clue makes suggestions based on experience. But I'm not going
to be the troubleshooter as I just won't work on energized equipment that runs in the thousands of volts.
CJ
Posted: Wed Dec 19, 2007 3:42 am    Post subject:
I would at least check the solder joints on those resistors. May just need a simple resoldering. All done with power off and disconnected.
Robert A. Hill
Posted: Wed Dec 19, 2007 4:30 am    Post subject:
I agree with Mac. Simple to do and costs nothing but some time.
I check all the solder joints in the Spellmans in Ampros and have found many joints needing touch-up. I do not know if they left the factory with voids and poor wetting or if these developed due to overheating and just got worse with time. I saw restarts and shutdowns before repair. On one, it was also smelly and very hot. Maybe you have already done this as I remember that you are very skilled with a solder iron/repair station.
Posted: Wed Dec 19, 2007 6:58 am    Post subject:
Those are carbon resistors and can drift. I think each one is 220 ohms, so 110 in parallel. I've seen those get hot over time, I have never seen a schematic of the HVPS, so I don't know how those resistors relate to the rest of the circuit. I'd put in 2 watt metal film and see what happens.
Posted: Wed Dec 19, 2007 12:21 pm    Post subject:
I'm going to measure the values of every passive component and resolder every connection as a starting point. Components that have
drifted out of tolerance will be replaced.
But I'm not so sure about replacing those resistors with metal film resistors due to voltage ratings. Resistors DO have voltage
ratings, you know. And metal film resistors often have lower voltage ratings than carbon comp resistors. It's something to consider.
Thanks.
Update coming when I have one.
CJ
Posted: Wed Dec 19, 2007 12:35 pm    Post subject:
Those two carbon resistors should be replaced before they cause failure to the HVPS.
Replace ONLY with Carbon 'Film' or Ceramic.
That section has a high voltage pulse on it from the power FETs. In those circuits (high voltage), you'll not want to use metal film.
Posted: Wed Dec 19, 2007 7:02 pm    Post subject: Pics of HVPS upgrade
Here is some pics of my modded HVPS. see the new Ohmite ceramic resistors. replace them all the caps are an option.
Hope these will help you find the fault.
oh and i'll also attach a schematic i got form some where cant remember.
hvps.pdf
HVPS PDF
 Filename:  hvps.pdf
 Filesize:  78.22 KB
 Downloaded:  339 Time(s)
Joust
TV/Projector: Marquee 8501LC
Posted: Wed Dec 19, 2007 7:33 pm    Post subject:
cool
you wouldn't happen to have the other two pages would you?
Posted: Wed Dec 19, 2007 7:51 pm    Post subject:
Thats the only one i have. i forgto where i got it. I think it was on this site. I think the person who drew this up did it for his own use. the other parts are most likely the potted section which should be left alone. and maybe the other page could be that small board attached to this board in the schematic.
JustGreg
Posted: Wed Dec 19, 2007 8:02 pm    Post subject:
I wonder whatever happened to sly from AVS. I was hoping he would have come over here when this site went up. He's the only person I know who modded the exposed boards and dug into the potted section. He had all the equipment to repot. He also posted some great pix of his LVPS filament voltage fix.
I'll go see if I can't track him down. He was generating schematics as he went along too.
Greg
Greg
Joust
Posted: Wed Dec 19, 2007 8:08 pm    Post subject:
the voltage multiplyer section is in the schematic. I'd expect that is in the potted section.
PaulB
Posted: Wed Dec 19, 2007 8:19 pm    Post subject:
Blast!!
So presumably the two new resistors R5 and R46 shown here http://www.curtpalme.com/Marquee_Maintenance4.shtm are wrong as they are metal film (see http://catalog.digikey.com/scripts/partsearch.dll?Detail?name=PPC220W-2CT-ND for details ). I've just had these exact resistors installed so I'll now need to get them removed and try to get hold of the correct resistor Sad
I've been trying to follow the Marquee Maintenance guide but I'm now beginning to doubt its validity in some ways. Is there any way to get it updated with more detailed information on the exact parts we need for our Marquee's - it looks like some of the information in there is misleading if not incorrect (or at the very least open to question if you are not sure what you're looking at). I'm no electronics expert but have a friend that can solder things superbly well but its a compeletly wasted effort if I'm getting him to solder the wrong things, possibly even dangerous!
No wonder I'm not getting any definitive replies about which parts to use in the Convergence/vertical boards, maybe no-one actually knows for sure.
Sorry if I sound a bit annoyed and certainly don't wish to come across as ungrateful for the great efforts that folks here make to help fellow crt users but I had thought I was doing the right thing by following the Marquee Maintenance guide but if the guide is indeed wrong/misleading then it needs sorting out before someone destroys their projector or worse.
Paul
Posted: Wed Dec 19, 2007 8:31 pm    Post subject:
Paul, go through it over and over again. you have to because there is soooo much info to absorb. I got the HVPS upgrade from Jeahong lees posts not the marquee maintenance thread. threre are 15 resistors to change on the HVPS if you remove all the carbon comp ones. On the vertical and convergance boards some of the resistors are hard to match up exactly. that is why there are different values. most agree that same value with a slightly higher wattage is ok. and keeep the tolerance equal or lower you should be fine.
Joust
Posted: Wed Dec 19, 2007 8:34 pm    Post subject:
Blast!!
Paul
those look like ceramic to me.
http://rocky.digikey.com/scripts/ProductInfo.dll?Site=US&V=273&M=OY221KE
PaulB
Posted: Wed Dec 19, 2007 8:54 pm    Post subject:
I think you're looking at the wrong ones Joust, R5 and R46 are both shown as Metal Film in the guide as per picture below
The link you provided looks pretty much to be the correct resistor that should be used as per Athanasios' advice and Jeahong lees blog http://blog.paran.com/pcaudio/645731 and conforms to Mike Parkers advice NOT to use Metal Film.
Paul
Joust
Posted: Wed Dec 19, 2007 9:02 pm    Post subject:
oh right. Embarassed
but i don't think it says metal film. It doesn't say they are not either though....
PaulB
Posted: Wed Dec 19, 2007 9:07 pm    Post subject:
From the Digi-Key description for the parts shown in the guide - RES 220 OHM METAL FILM 2W 5% ( http://search.digikey.com/scripts/dksearch/dksus.dll?Detail?name=PPC220W-2CT-ND )
Please don't get me wrong guys, the guide is GREAT! Its just proving not to be 100% accurate in place's when you try to follow it to the letter which, as a noob and an electronic buffoon is the only way I can follow it.
CZEddie also expressed that he had problems finding the correct parts. I think the problem is that the guide is very precise in some areas and a bit vague in others which leads to confusion and guesswork that in turn leads to ... well, leads to this thread.
I'd guess that the guys that know what they are doing electronics-wise (Athanasios for example) can feel their way through the guide and make sense of whats supposed to be done whilst others will get confused and give up. I looked at Jeahong lees blog and presumed that his mods were at a level beyond the Marquee Guide so stuck to the Guide as a sort of basic requirement rather than the seemingly advanced mods by Jeahong.
Paul
Joust
Posted: Wed Dec 19, 2007 9:11 pm    Post subject:
sorry, I'm looking at the master document and I cannot find this reference.
I did update it to indicate the picture is showing metal film parts and not to use metal film in the HVPS.
It certainly could use an update. I'm sure there are a lot of things in there that can be updated.
Posted: Wed Dec 19, 2007 9:13 pm    Post subject:
not sure where your picture came from, or why you're saying that R5 and R46 are metal film, because they should not be metal film.
From the picture that you're showing, it looks like someone had replaced those resistors (not sure). But a safe rule to always follows is that metal film resistors should never be used in high voltage circuits, because they don't deal with spikes and high voltage flashes too well. And that is why they are not found in CRT focus circuits and the circuits that are connected to the CRT elements where high voltages and spikes are common.
Whatever you do, do not put metal film resistors in any circuit that deals directly with high voltage to CRT's elements or circuits that deal with high voltages and pulses.
In the very near future, we will be back with the maintenance thread, and other things as it relates to keeping our hobby alive and doing well.
Posted: Wed Dec 19, 2007 9:14 pm    Post subject:
I ordered all my parts from newark. they have most evrything.
Page 1 of 3
