ysati
| Posted: Sat Oct 31, 2009 9:54 am Post subject: |
Now I have more advanced testing.
It seems that color is more explosive, more vivid.
But on the DVE test patterns, you never see the
side bands.
Also the gray scale pattern of 5 IRE is not visible, only from 10 IRE, but it is not the side bands.
I did not use the remote, because unfortunately it does not work?
I have the IFB of John, on the input B and the IFB of Moome on the input C.
At the moment, for me, it was not necessary to spend $400, for this result?
Yves
ysati
| Posted: Sat Oct 31, 2009 1:32 pm Post subject: |
| Nashou66 wrote: | did you see the post from moome where you need to use the A, B buttons to change color space? this might be your issue with not seeing BTB
Athanasios |
No because my remote control, not work...:
Yves
| Posted: Sat Oct 31, 2009 2:58 pm Post subject: |
| ysati wrote: | | Nashou66 wrote: | did you see the post from moome where you need to use the A, B buttons to change color space? this might be your issue with not seeing BTB
Athanasios |
Yves |
The remote is difficult, but it usually works with some finesse. Point the remote directly at the card. Press one button at a time. Wait at least two seconds or more between each button press.
Try the remote at various angles until you find the right spot. You will know when the remote works because a red led will blink once on the card when you press a button on the remote.
Remember, only press one button at a time and wait at least two seconds between each button.
| Posted: Sat Oct 31, 2009 5:05 pm Post subject: |
The screen shot below captures the bandwidth problem. The first photo is with the stock filter and the second is with Mike's filter. I did this mod months ago and have also done it on several of my client's cards.
This is 1080p 60Hz 1:1 on/off pixels.
| Posted: Sat Oct 31, 2009 5:08 pm Post subject: |
Incidentally, this is a common problem with many DVI/HDMI to RGB converters. I see this attenuation with the HDF1 and HDF2. The HDF1 actually has a slightly better response than the HDF2. I have looked at ALL of these on my oscilloscope as well and may post photos of the scope to illustrate.
The only two boards I have confirmed to have full bandwidth at 1080p 60Hz are John's original DVI IFB and Moome's FULL-HD with Mike Parker's filter.
ysati
| Posted: Sat Oct 31, 2009 6:03 pm Post subject: |
| CIR Engineering wrote: | | ysati wrote: | | Nashou66 wrote: | did you see the post from moome where you need to use the A, B buttons to change color space? this might be your issue with not seeing BTB
Athanasios |
Yves |
craigr |
Thank you craigr,
My G90 is the ceiling to 2m in height ...
It's really not easy, but I managed to operate the remote.
The gamma is correct only with 16-235?
With input B, 0-255, blacks are too black.
The IFB FullHD is set to RGB and 444.
I think we should adjust the colorimetry ...
In conclusion, I see no difference in comparison with the IFB card of John...
Yves
1031
| Posted: Sat Oct 31, 2009 6:09 pm Post subject: |
Hello.. Seems that my new marquee card has similar bw. limit problem. Anotherwise it seems to be better than older hdmi card. Here are two (crappy celphone photos) One with 1080i and second with 1080p (both 60hz) . i´d like to test that filter with MP´s suggested components. This solution does limit BW too much and takes defenatly some "edge" out of picture.
So Moome can you PM me what components must be changet to get filter circuit similar to that what MP recomendet. I´m familiar with SMD components.
| Description: |
| Filesize: |
13.01 KB |
| Viewed: |
6556 Time(s) |
| Description: |
| Filesize: |
11.81 KB |
| Viewed: |
6556 Time(s) |
_________________ Marquee 9500LC (Frankenyokes / Thomas electric tubes / HD-10L / +many mod´s)
DVDO VP-50
New hobby, Rally
| Posted: Sat Oct 31, 2009 6:13 pm Post subject: |
| ysati wrote: | | CIR Engineering wrote: | | ysati wrote: | | Nashou66 wrote: | did you see the post from moome where you need to use the A, B buttons to change color space? this might be your issue with not seeing BTB
Athanasios |
Yves |
craigr |
Thank you craigr,
Yves |
The best settings for BluRay will come from 16-235 with YCbCr 422. This is 10-bit color depth along with proper luma levels. You will get better colors with YCbCr 422 than with RGB or 444.
This can be verified on screen by pausing real world images. Look at people's faces under bright light on the screen. With 422 you will observe more color graduation (and colors) between shadow to bright areas on a face. There are of course other examples as well.
| Posted: Sat Oct 31, 2009 6:14 pm Post subject: |
| 1031 wrote: | Hello.. Seems that my new marquee card has similar bw. limit problem. Anotherwise it seems to be better than older hdmi card. Here are two (crappy celphone photos) One with 1080i and second with 1080p (both 60hz) . i´d like to test that filter with MP´s suggested components. This solution does limit BW too much and takes defenatly some "edge" out of picture.
So Moome can you PM me what components must be changet to get filter circuit similar to that what MP recomendet. I´m familiar with SMD components. |
Yes, the Marquee card is using the same filter system as the G90 IFB.
| Posted: Sat Oct 31, 2009 6:43 pm Post subject: |
| 1031 wrote: |
No, that cannot happen at this point.
There's a few things that has to be worked out first, and until that happens, it's best to keep this off the forums.
ysati
| Posted: Sun Nov 01, 2009 10:17 am Post subject: |
| Quote: |
craigr |
Thank you craigr,
I'll check and I inform you.
Yves
ysati
| Posted: Mon Nov 02, 2009 11:29 am Post subject: |
| craigr wrote: |
craigr |
I use the following setup:
Faroudja:
Full HD input signal by DVI
Output YUV by DVI
IFB:
16-235
How to configure in 422?
G90: YUV mode
Unfortunatly, in this setup, the projector, working with incorrect behavior.
Yves
| Posted: Mon Nov 02, 2009 1:55 pm Post subject: |
I've been corresponding with Moome over the past several days concerning the possible problem with the latest cards having a HF problem.
All I can say for now is that the potential problem is seriously being looked into.
And to add, let me say this, as I've indicated this so many times in the past about the last two versions of the Moome cards. The last two versions (v1.2 / V1.3) were well thought out from a design point. And what I mean by that is that he did very well in his design when putting both analog and digital (mixed signal) circuits on the same PC board on a close area.
I spent a good amount of time over the weekend once more looking at the design while looking at things from various technical perspectives. His design is very impressive in that he put a lot of design work into keeping the digital crap (clock/processing noise) away from being a problem in the analog circuits. There's a lot of de-coupling going on on that small board. much more than I've seen on anything. And it measures out well.
In most cases these designs ideas are played out on paper (math), but the math is not always correct. In the case of this board design, the math was close and it appears that he spent a lot of time also doing what should always follow the math, and that was to test and verify things. That is how he was able to do so well with his design, with only one area of exception. And this particular area is almost not done right by everyone (my opinion). it's a problem area that the math is never correct, and the process of finding that particular sweet spot that's needed for 1080P /60 requires a lot of R&D using several pieces of test gear and you're have to use a particular group of test patterns to dial things in properly.
I've said it so many times in the past, 1920x1080P 60 or 72 hz is a very tricky frequency to properly convert to a clean and properly resolved HIGH Performance analog signal.
I still can't post here anything that we've been looking at so far, because anything that I'm doing for this is proprietary info. so it's not mine to disclose.
So take my word for it that whatever the problem may be if any, it would be solved or corrected soon. And that for anyone getting the fix, update would be getting something that far exceeds anything that i was expecting from this card.
Trust me on this one..
There may be somewhat of a communication problem dealing with Moome, but let me assure you that he is one very conscientious guy when it comes to trying to make sure things are right. That I did not know so well about him until this past week.
marksG70
Joined: 27 Jan 2009 Posts: 5 Location: Bendigo Victoria Australia
| Posted: Mon Nov 02, 2009 2:54 pm Post subject: |
I feel you have more respect for him and his engineering workmanship. That helps with my confidence! My concern is I have already ordered the card will I get the fix/update?
| Posted: Mon Nov 02, 2009 3:45 pm Post subject: |
| mp20748 wrote: | I've been corresponding with Moome over the past several days concerning the possible problem with the latest cards having a HF problem.
There may be somewhat of a communication problem dealing with Moome, but let me assure you that he is one very conscientious guy when it comes to trying to make sure things are right. That I did not know so well about him until this past week. |
I want to say that I have a lot of confidence in Moome as well. We spoke on the phone a couple of days ago for over a half hour. Moome and I verbally nailed down the problem and I reiterated the fix; and Moome assures me that he is on it. All forward boards will have the correct filtration and HF response.
This card is absolutely fantastic in almost every way and I told Moome that on the phone. Once the filtration is worked out to pass HF it will be the absolute best IFB ever created at this point. It will exceed anything ever produced thus far, and in most ways the current IFB already does.
Furthermore, Moome is adding a feature that I requested to the newer firmware. He will be shipping me a beta chip to test soon. With the new feature you will still be able to select 15-235 or 0-255 for all digital inputs, but you will also be able to force the card to YCbCr 422 or 444. This is a feature that is usually only available in a high end video processor such as those offered by Lumagen.
I think Moome really deserves a lot of props for this card and for sticking to making it more refined. The existing cards are already quite good, but the final version will be near ideal reference. Nothing is ever perfect, but these cards are getting close to it.
hlmiii
| Posted: Mon Nov 02, 2009 3:49 pm Post subject: |
Mike -
Would you advise me to pull my new board out and return it to Moome now?
Or wait?
I have both of his earlier boards that I can use until the updated/replacement product is ready and back in my system.
Thanks.
| Posted: Mon Nov 02, 2009 3:55 pm Post subject: |
| ysati wrote: | | craigr wrote: |
craigr |
Faroudja:
Output YUV by DVI
IFB:
16-235
G90: YUV mode
Yves |
DVI only supports RGB at either 0-255 or 16-235. You can not make a DVI source (in almost every case) output YCbCr. Furthermore, any DVI source that supports YCbCr is outside of industry specifications. Only HDMI supports YCbCr.
To utilize YCbCr 444 or 422 you will need a source or video processor that can output YCbCr through HDMI. Many BluRay players support this as well as the Lumagen Radiance video processors.
The only DVI source that I am aware of that supports YCbCr is the HDG-4000 pattern generator from Accupel. However, thre are problems with thios because it is outside industry spec. Even though the Accupel can output YCbCr, it can not give the correct info frame data since it is DVI. The display device in this case needs to be manually set to YCbCr by the user because with DVI it can not happen automatically. This is one of the reasons I would like the new feature of manual selection for colorspace. The new colorspace selection feature is also useful when you get stuck in a situation where the auto selection does not work. This is what happened at my client's install last week. The IFB just stayed in RGB when I sent HDMI YCbCr.
