rabies_70
Joined: 15 Feb 2007 Posts: 1189 Location: Carlsbad, CA
TV/Projector: Sony G70Q
| Posted: Tue Oct 27, 2009 7:46 pm Post subject: |
Package from Mr Moome arrived today I wish I had free time to set it up right now.....
_________________ Ray
I am an iconoclast
kal Forum Administrator
hlmiii
| Posted: Wed Oct 28, 2009 2:25 pm Post subject: |
I received my card yesterday afternoon (Tuesday, 10/27/09). It was installed to replace the prior version from last year, which was itself an "upgrade" from Moome's first Sony card.
Reference: (source) > Lumagen Radiance > G-90 @ 1080p 60Hz.
The new card is a definite and noticeable improvement. The most obvious difference is the reduced noise - the existence of which wasn't apparent until made (in)visible by the new card. Along with that is an image with improved resolution and better-defined contrast transitions. My guess is that these latter two improvements are due to faster step response (?). White - black dynamic range is also increased.
In short the card provides the improvements as claimed in its product descriptions. I was hesitant to believe and see improvement - and spend money yet again on the same general product. But now having seen the results I am very happy with Moome's effort in reworking his previous product and would definitely classify it as worth every penny.
Highly recommended. Thanks.
JohnHWman
Joined: 15 May 2007 Posts: 215 Location: France - Grenoble
TV/Projector: Sony VPH-G90U (one unit for me, four others units repaired and sold)
| Posted: Thu Oct 29, 2009 8:55 am Post subject: |
I agree with hlmiii,
Received my card yesterday and installed it right away inside my VPH-G90 PJ after removing the older IFB-FULLHD card from the B slot.
Reference : HTPC or Oppo BDP-83 > DVDO VP50Pro (Y/Pr/Pb 4:4:4 ITU 709) > Blue Jean BJC2 7m HDMI cable > G90 @ 1080p50 (PAL DVD) or 1080p48 (Blu-ray/HD-DVD) on 3m wide 16/9 AR screen
I've setuped the card like this :
- Input Link0
- 'B' mode [0-255] dynamic digital input range
- 100% Gamma
G90 brightness = 50
G90 Contrast = 70
Tested with the High définition Benchmark blu-ray Disc from Spears and Munsil. I've used the low level test patterns (with BTB infos) and the improvment on video noise figure is clearly seen.
Sharpness improvement on the picture is not obvious for me but this is maybe because I'm only using 'low' 120MHz pixelclock resolutions (and not 145MHz pixelclock like 1080p60).
Video Noise improvment is the key feature for me.
John
_________________ Home theater enthusiast for over 20 years !
My dedicated HT room !
| Posted: Thu Oct 29, 2009 4:39 pm Post subject: |
| JohnHWman wrote: | I agree with hlmiii,
- Input Link0
- 100% Gamma
G90 brightness = 50
G90 Contrast = 70
John |
Yes, I received a new IFB for a client's G90 and used it yesterday. Unfortunately Moome did not apply the new bandwidth improvement mods that Mike Parker and myself suggested. He used a different filter that was suggested by someone else and it does not pass 1080p 60Hz. Because of this, the new board does not improve the frequency response over the original version and it still is attenuating 1080p 60Hz rather profoundly.
I also had an issue with YCbCr 422. The card would not consistently lock onto the info frame and would get stuck on the RGB color space. If I ran through various switches and repeaters I could force the board to find YCbCr 422, but it was not working as well as the old card and I had to rig up the clients system. Most likely the new card is requiring a very high level voltage for the video to get the info frame data.
The new card also cropped blacker than black showing that anything below level 16 was not visible even when raising the brightness to MAX on the G90. I did not check whiter than white however so I can't say on the white side.
Honestly, I wish I had the older card for this client. I could have applied the bandwidth mods myself and it would have worked better. If you have this card or the Marquee card and you want full frequency response for 1080p 60Hz I could apply the mods for you. Send me an email at craigr@cir-engineering.com to make arrangements. I will however be sending Moome an email as well to discuss this with him. I like Moome very much, but with the language barrier it can take time to get these sorts of things sorted out.
It is still the best card out at this time. I do think it could use more refinement.
JohnHWman
| Posted: Thu Oct 29, 2009 5:03 pm Post subject: |
Thanks for the in-depth report Craig,
This is disappointing since I thought that, at least, the VBW improvment made by you and MP was in fact included in this new revision. That's the reason why I didn't noticed any sharpness inprovment even in 1080p48/120MHz mode...
I also noticed that something wrong was shown with the BTB info but I was suspecting problem with the test pattern I've been using. I will retest this aspect together with WTW with another test pattern to confirm.
Later then
John
| Posted: Thu Oct 29, 2009 6:08 pm Post subject: |
Huh ?????
Very odd indeed that Moome would not include these new features as he specifically states the he did in the manual! See the third page of the manual here: http://www.curtpalme.com/docs/ifb_fullhd_v20.pdf
| Quote: | What difference between IFB-FULLHD and IFB-FULLHD V2
Gamma: Improved gamma (suggested by WTS)
sharpness: More sharper image (improved suggested by MP)
Picture purity: More clean (improved suggested by MP)
Super white: support
Stability: ESD enhanced |
Are you sure Moome didn't send you some old version by mistake? This doesn't make any sense.
WTS
| Posted: Thu Oct 29, 2009 6:22 pm Post subject: |
Hi Craig,
With regards to the Moome board, the new filter ( if he used it on these boards)should be passing 1080p/60 with no problems. The only thing I can think of is that he used the wrong components and it is filtering to a lower freq. Correct me if I'm wrong but the 1080P/60 is BW limited (brick walled) to 60 Mhz and this filter should be passing easliy up to 80Mhz or higher. I don't know offhand what the exact corner freq. that Moome finally went with on these. On your filter mod what was/is the corner freq?
Hmm this isn't good if it's cutting it off too soon.
My mistake, the max filter BW required for 1080P/60 is 75Mhz, this is according to Analog Devices AN944, for some reason TI's paper on this states 60Mhz.
_________________ Thanks
Walter
WTS
| Posted: Thu Oct 29, 2009 6:37 pm Post subject: |
As for the level 16, do you have it set to 0 to 255 and not 16 to 235, I don't mean to insult you on this question but the led should be off when it is in the 0 to255 mode.
Walter
moome
| Posted: Thu Oct 29, 2009 7:31 pm Post subject: |
Dear Craig:
for filter, I will check with factory again,
and for BTB and WTW, there is a notice: (I am sorry I think I need improve this on the datasheet)
YCbCr 444/422 16-235 input , you can use A or B on remote (A will has BTB and WTW output )
RGB 444 16-235 input , you can also use A or B on remote (A will has BTB and WTW output )
RGB 444 0-255 input , you need let card stay A (press B will get crash picture)
I think I use wrong word "super white support", super white function on my card means the card will expand 16-235 to 0-255 to get more DAC range usage. maybe it should tag as range expand function.
and actual superwhite define by video industry function means WTW
so if you want to see BTB and WTW, it will let card stay A (by press remote button A)
let me know if any other problem.
thanks
| Posted: Thu Oct 29, 2009 8:15 pm Post subject: |
Moome, check your PM.
WTS
| Posted: Fri Oct 30, 2009 12:30 am Post subject: |
After thinking about Craig's question on the levels below 16 I have a question about the HD test discs DVE and the new S&M.
Does anyone know what test patterns on these discs have levels below 16, I thought the pluge test patterns were suppose to have levels below 16 but I can't find any info on what the actual digital levels are on these discs.
Anyone know?
I did some looking on the AVS forum and found an question/answer thread with Spears and Munsil which pretty much answered my questions about their disc and they actually have a lot of levels below 16 on their disc.
Walter
JohnHWman
| Posted: Fri Oct 30, 2009 8:48 am Post subject: |
| WTS wrote: | | My mistake, the max filter BW required for 1080P/60 is 75Mhz, this is according to Analog Devices AN944, for some reason TI's paper on this states 60Mhz. | 75MHz (square wave) maximum frequency of 1080p image with black/white one pixel after another is OK, but Y/Pr/Pb or RGB components analog filtering at this value will result of changing the video square wave to ~sine wave by removing all the harmonics above 75Mhz fundamental.
The result on the image will be too smooth pixel transitions between black/white : then no real sharpness on the displayed image. For my point of view, you need at least 140MHz analog bandwidth output to have a decent sharpness on the 1:1 B/W test pattern (and on a movie image ).
FYI, This is this 140-150MHz Fc value I've been using on all my designed products (IFB-DVI, BG-DVI, HDfury and HDFury2).
My two cents
John
ysati
| Posted: Fri Oct 30, 2009 3:59 pm Post subject: |
I have received the IFB-FULLHD V2 this morning.
I installed it on the G90.
DVD Pioneer LX71>Switch HDMI>Faroudja DVP1080>DVI/DVI cable 25 feet + adapter DVI/HDMI>IFB-FULLHD>G90
This works very well.
but the remote control,does not work?
Yves
| Posted: Fri Oct 30, 2009 11:33 pm Post subject: |
| kal wrote: | Huh ?????
Kal |
I don't have a lot of time to type today guys...
I am sure I got the new board. It is the one in the new photo above with the new added daughter card.
| Posted: Fri Oct 30, 2009 11:40 pm Post subject: |
| WTS wrote: | Hi Craig,
Mike and I talked about this extensively on the phone the other day (or week I forget). There was a filter that I think maybe you proposed(?) to Moome between the DAC and Opamp that is different than the one Mike came up with that I tested.
I applied several of Mikes mods a couple months ago including that one. Mike's filter seemed to keep clock noise out while maintaining full response with a 75 Mhz signal.
With the circuit on the board now, there simply is not enough BW to maintain full response. I think you need a min of 2x the signal frequency built into the circuit (like John says), but more would be even better.
Last edited by CIR Engineering on Fri Oct 30, 2009 11:57 pm; edited 1 time in total
| Posted: Fri Oct 30, 2009 11:41 pm Post subject: |
| WTS wrote: | | As for the level 16, do you have it set to 0 to 255 and not 16 to 235, I don't mean to insult you on this question but the led should be off when it is in the 0 to255 mode. |
No insult taken... in fact I think that may have happened... more below.
| Posted: Sat Oct 31, 2009 12:05 am Post subject: |
| moome wrote: | Dear Craig:
RGB 444 0-255 input , you need let card stay A (press B will get crash picture) |
I did not realize that I could use the A or B with YCbCr. This is because YCbCr is always 16-235 by industry standards. I did not expect that option. 0-255 is illegal and should not be implement by a manufacturer ever.
However, this is a good feature from you because sometimes manufacturers get it wrong. If YCbCr is being sent by a device at 0-255, the IFB can fix it because of the A or B with YCbCr
| moome wrote: | I think I use wrong word "super white support", super white function on my card means the card will expand 16-235 to 0-255 to get more DAC range usage. maybe it should tag as range expand function.
let me know if any other problem. |
I did see "Super white support" and it did not register with me that is what it would do. Now that I know, I will be fine with using it.
I have a request. Can you add a remote control feature to your card. I would like to manually select RGB or YCbCr 422/444. I want to be able to force your card to go to YCbCr. This way if a source info frame can not get the card to YCbCr, I can make it.
Do you know why my client's card would not lock onto YCbCr 422 or YCbCr 444? Your card was stuck on RGB.
I was able to get your card to go to 422 by running the source through an HDMI distribution amp first and then to your IFB.
Last edited by CIR Engineering on Sat Oct 31, 2009 1:12 am; edited 1 time in total
| Posted: Sat Oct 31, 2009 12:13 am Post subject: |
| WTS wrote: | After thinking about Craig's question on the levels below 16 I have a question about the HD test discs DVE and the new S&M.
Anyone know?
I did some looking on the AVS forum and found an question/answer thread with Spears and Munsil which pretty much answered my questions about their disc and they actually have a lot of levels below 16 on their disc. |
I always look at this with my Accupel generator. If I am installing a Lumagen Radiance, there is also a fantastic "contrast" test pattern that shows several bars with low level grey and blacker than black with nothing else on the screen (all very dark).
I also made up a test disc a while back that can be burned to a DVDR and it plays like a BluRay disk. Here is a link http://www.cir-engineering.com/bin/yc++.zip. I am sorry but I forget who the author of the patterns is.
| Posted: Sat Oct 31, 2009 12:16 am Post subject: |
| JohnHWman wrote: | | WTS wrote: | | My mistake, the max filter BW required for 1080P/60 is 75Mhz, this is according to Analog Devices AN944, for some reason TI's paper on this states 60Mhz. | 75MHz (square wave) maximum frequency of 1080p image with black/white one pixel after another is OK, but Y/Pr/Pb or RGB components analog filtering at this value will result of changing the video square wave to ~sine wave by removing all the harmonics above 75Mhz fundamental.
My two cents
John |
John, your IFB-DVI passes perfect bandwidth and I still always keep it in my projector. Moome's new board is equal in BW with Mike's mods added, and Moome's board has the added advantage of YCbCr, 16-235, and more digital BW for 1080p 72 Hz. I always use Moome's board now because of the better 10 bit colors with the full BW.
