Picking up projector at freight depot -- what to do first?
Joust
TV/Projector: Marquee 8501LC
Posted: Sat Nov 10, 2007 4:38 am    Post subject:
High Voltage splitter. and the red HV leads.
It doesn't matter which goes where.
plug 'em in and give 'em a 1/4 turn.
you will need to remove that white plastic plate below the splitter to get at the magnetic adjusters you need to adjust during mechanical setup.
lyd
Posted: Sat Nov 10, 2007 4:42 am    Post subject:
Thanks!
lyd
Posted: Sat Nov 10, 2007 2:46 pm    Post subject:
wrong, the HV wire with the sleeve over it is from the power supply (you can trace it down into the chassis to make sure). It goes in the lower left corner (when looking from the front). It's marked "supply" on the side of the splitter in White letters.
I would caution against diving into the Focus yoke and flare ring for you first time into a Marquee. You should first learn the basic set-up and operation. The fact that all the High voltage leads were disconnected is a little worrisome, hopefully the set powers up OK?
lyd
Posted: Sat Nov 10, 2007 3:09 pm    Post subject:
Well, there is no such marking on my splitter, but that's where I had plugged the supply lead in anyway.
I would caution against diving into the Focus yoke and flare ring for you first time into a Marquee. You should first learn the basic set-up and operation. The fact that all the High voltage leads were disconnected is a little worrisome, hopefully the set powers up OK?[/quote]
Set powers up fine. I have complete confidence in the set and the seller. No worries there.
Setup, on the other hand, is another story. Round one definitely went to the projector.
After going through all the tightening and checking out suggested above (with the exception of the voltage check... I only have the pin probes for my meter, and the suggestion to use pinch probes seemed like a good one. I'll pick some up and do that today), I powered it up and went through the guided setup. Everything was fine until I got to the mechanical convergence, where you loosen the bolts and move the tubes back and forth. I couldn't even get close that way, no part of the grid seemed to line up with any other part of the grid. The best I could do was to get the lines to intersect at a couple of points, but everything else was way off. Clearly I need to look into further adjustments, so I am going to try to do that and take another crack at it today.
There is a lot of keystone and other stuff dialed in, from the projector having been previously mounted very high, and that is no doubt adding to my troubles.
I am am doing all of this with the projector just sitting on the road case, and I am hoping I can achieve a bit more of a clue by the end of today, because tomorrow it goes up on the ceiling and it will be time to do the setup for real. (Although I have no illusions that I won't be re-doing it for months to come, until I really get it down.)
lyd
CRT_Ben
Posted: Sat Nov 10, 2007 3:50 pm    Post subject:
Hi lyd,
In order to erase the previous setup that was done (because no part of any setup is generally useful to another setup) you need to do a full reset on the machine. Press UTIL, 9, 0901, and I think 4 is Projector Initialization. From there pick whichever option is to reset everything. The PJ will turn off and when you bring it back up it will look like it has a lot of pincushion and keystone, but worry not, at least this time you're starting from scratch. Very important! Thumbs Up
Ben
Joust
Posted: Sat Nov 10, 2007 3:56 pm    Post subject:
No, in fact, I'm not.
I checked with the experts.
some may have labels for guys that feel they need them and give you a sense of security. but thats all it is for.
the internal structure is such that it doesn't matter.
Posted: Sat Nov 10, 2007 4:59 pm    Post subject:
Joust wrote:
No, in fact, I'm not.I checked with the experts.
Well we can debate that point, and I have never dissected one to see what's inside, but my experience is that a manufacturer doesn't do things to give end-users a sense of security. If that label is there, it's there for a reason.
Posted: Thu Nov 15, 2007 11:54 pm    Post subject:
well don't beleive everything the experts tell you, I proved today that the experts were WRONG on this, Wink see thread
http://www.curtpalme.com/forum/viewtopic.php?p=82774
Joust
Posted: Fri Nov 16, 2007 12:00 am    Post subject:
I stand proven wrong.
I deffer to your greater logic. Thumbs Up
