In your Home Theater, what brand speakers are your mains?
rod
Posted: Tue Nov 13, 2007 10:30 pm    Post subject:
miss my EVs (stereo) those were great sounding.
Yamaha RX V2700
Axiom speakers all around
M60 - mains
QS8 - surrounds
VP150 - cc
AX3s - rears (upgrading to QS8s)
3 subs (1 axiom, 2 davids) - replacing all three with Axiom EP600
Rod
ADRIANKELLY
Posted: Tue Nov 13, 2007 10:55 pm    Post subject:
Ascend Acoustic 340SE fronts and center 170's 4 surrounds , 2 HSU VTF-3 MK-2 (1 turbocharged) 1 VTF-2 MK-2.
Denon 3808CI .
If You Choose Not To Decide You Still Have Made A Choice .
mack1
Posted: Fri Nov 16, 2007 2:38 am    Post subject:
Mains are polkaudio sda's and the rears are polk audio sda's feed buy a 200x5 rotel.Whole system is 7.1
redcorvette_85
Posted: Fri Nov 16, 2007 9:59 am    Post subject:
Hk avr 240 7.1 receiver
Paradigm Monitor 70p's fronts
Paradigm cc-150 center
Paradigm ADP 150's side surrounds
Pair of older bose bookshelfs for rears until I can get another set of adp's
Older Energy 12" sub
I am pretty happy with my setup, though I need to eventually replace the sub, bose crappy rears and center channel in that order , I still think it sounds good, though the bass really needs some help, my sub sucks and my center is a little on the week side compared to the mains. The bose rears, well there bose, but not much 7.1 material so I don't hear them much and there just surrounds anyway. I also gotta say I am really impressed with the hk receiver, its amazing how clean and loud it gets for such a low watt rated amp. I understand some of the benefits of seperate amps, but I can barely handle what I have now when its turned way up and I am in a decent sized room Thumbs Up
zaphod
Posted: Fri Nov 16, 2007 3:47 pm    Post subject:
oliverg wrote:
Martin Logan Odysseys - Mains LR
Martin Logan SL3s - Rear LR
Martin Logan Scripts - Sides X2 LR
Martin Logan Cinema - Centre
Sony STR DA9000ES 9.1 - Also have a pair of Dared tube amps but I don't use them anymore.
There will come a time when I might split - move my MLs into a listening room with tubes and go Paradigms for the HT. Electrostatics have to be placed 'inside' the room which take away the cinema feel - there's something to be said about in wall/hidden speakers. Alot more WAF friendly.
no sub? take a look at this:
http://cgi.ebay.com/MARTIN-LOGAN-DESCENT-400-WATT-RMS-THE-ULTIMATE-SUB_W0QQitemZ270187117734QQihZ017QQcategoryZ14990QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
i added a ML depth to my other 7 logans and the improvement over my other sub was great. only the ML subs seem to be able to match the response of the ML 'stats. everything else seems a bit mushy and slow.
Posted: Fri Nov 16, 2007 6:59 pm    Post subject:
It is amazing what some will spend on a subwoofer.
Darren Wadsworth
Posted: Fri Nov 16, 2007 8:00 pm    Post subject:
Vandersteen 2ce Signatures. with Vandersteen 2WQ subwoofers that work in conjunction with the mains - Main
Center Channel DIY 2 way
Mains are driven by an Ayre Acoustics V-3 (2-channel) amp. The signal is processed by a Parasound 7100 pre/pro and the 2 main channels are passed through an Ayre k-5xe pre-amp to the Arye amp. The setup is more toward stereo playback, but movies are great too.
Darren
"DLP is the official ESPN on ABC HD telecast sponser of college football"
JJSuperfly
Posted: Fri Nov 16, 2007 8:12 pm    Post subject:
Fronts (LCR): Mirage M5
Rears: Mirage OM-R2
Sub: Homebuilt 2 x 10"
Pre-Pro: Bryston SP1.7
Amps: Bryston 9B-TXH and 7B (sub)
Upgrade Path (at glacial pace in anti-global warming climate)
-Overall cinema sound is great but I'm still not happy with dialogue clarity. I've tried the mirage OM-C2 center channel but prefer the M5. I may try adding a second M5 for the center as I have a spare.
-2 additional OM-R2's for 7.1 system
-SMX acoustically transparent screen with fronts nicely hidden
-carpet, drywall, paint, etc. for WAF
-beer fridge for HAF.
Then again, switch the order of the last two items.
Atom
Posted: Fri Nov 16, 2007 8:15 pm    Post subject:
Hi
Front Main -Acoustat Spectra - Hafler 9505 or Conrad Johnson Premier 4
Front Centre- Acoustat Spectra 22-Sunfire
Subwoofer -2 x Contrabass -Behringer 2500
Rear- Acoustat Spectra 22- Sunfire
Andrew
Stonefool
Posted: Fri Nov 16, 2007 11:11 pm    Post subject:
JMLab's 2006 S Series, all around though, not just front.
Trying to get everything to work.
Posted: Mon Nov 19, 2007 5:37 pm    Post subject:
Aerial Acoustics 10Ts, driven by Krell KMA-160 monoblocks.
Center channel is a Phase Tech PC-3, which is a very good timbral match for the 10Ts.
I'll be putting a set of Phase Tech PC80s into service for the rear channels in the next few weeks,
after I get done refurbishing them. Those should blend quite well.
Subwoofer: Full custom. 2x12, 8.5 cubic foot enclosure (ported), proven to achieve 120 dB at 20 Hz,
counting room effects, fed 500 WPC (at 4 ohms) into each of the two 4 ohm drivers.
CJ
d50q
Posted: Thu Nov 22, 2007 10:05 am    Post subject: my speakers
im using bic acoustech ht-75 279 a pair
a cambridge sound works 12 inch sub and slave but i dont use the slave
dont use a center
mtx 4 inch full range for the rear the waf factor
the bics are great well balanced sound\highs are not harsh bass is tight
a good budget speaker
all driven buy a sony 6.1 reciever
Posted: Sat Nov 24, 2007 12:47 am    Post subject:
I'm amazed at how little some people are willing to spend on such an important component in a home theater. The sub's performance can make or break the "fun factor" of the theater.
I don't think it's unreasonable to spend as much on the subwoofer as you'd spend on your center channel and surrounds combined. Or even spend as much as your main L/R speakers cost.
I have yet to hear a sub that costs less than 500 dollars that I'd want in my own system. But I admit, I'm very spoiled
by what I have now. My main speakers outperform MANY subs on their own, as they are flat to 21 Hz. (Aerial Acoustics 10Ts) And there's a monster of a custom-made sub sitting in the corner that I designed and built some years back
which pushes out a measured 120 dB at 20 Hz. Not many subs play that hard, that low, even today. And they all cost
four figures. I can't find anything to compete with it that I can afford to buy. Which is a perfect example of WHY a
DIY subwoofer can be an outstanding solution.
Of all the speakers in a home theater system, the subwoofer alone is EASY to design and build and get excellent performance out of it. Anyone might take the DIY route with any other speakers, even the fronts, but it's not anywhere
near as easy or as likely that you'll end up with speakers that outperform what you could buy at retail for the same budget.
CJ
d50q
Posted: Sat Nov 24, 2007 1:17 am    Post subject: cost of audio
well by looking at what people are useing.
i can tell im the joe sixpack of the pack lol
i love my csw12 sub its shakes the room granted it does not go down to 20 hz but i got it with the slave for 125.00
in mint condition i just bought a house this year the room is living room is small to medium size
i have a setup for a room i have yet to build inthe basement its 5 insignia 6.5 two ways i got for 40 bucks a pair before bestbuy found out they had a winner and doubled the price
a sony strda30 es reciever was my dads
the 12 inch slave sub from the csw system have yet to buy an amp for it
and my freebee d50q projector
i love a good deal and actually i was a joe 18 pack but have been clean for 2 weeks had to stop drinking for health reasons
who cares what ya spend as long as it works and you enjoy it!
Bucketfoot
Posted: Sat Nov 24, 2007 2:52 am    Post subject:
My budget system:
Front Onix X-LS
Center Onix X-CS
Rear Onix X-LS
Side Wharfedale WH-2
Sub Onix X-Sub
Yamaha RX-V659
Chuck27
Posted: Sat Nov 24, 2007 12:45 pm    Post subject:
A pair of 1978 Cerwin-Vega T-12's. I'm keeping them until I die.
Chuck
Chuck
using acreage for sound insulation since 1999
Wombat
Posted: Tue Nov 27, 2007 8:57 am    Post subject:
Radio Shack LX5-II for left, right and rears. No center, but I've got a few more of them for when I feel like going to 5 or 6 or 7.1. (Got them when Radio Shack put 'em on sale for under $40... I hit just about every store from North Van to Kerrisdale to find enough.)
Receiver is Pioneer VSX-816-K
Sub amp is NAD 2200, running one NHT1259 and a home-built ServoDrive ContraBass. (The other 1259 and ContraBass are offline for repairs.) I have some more powerful pro amps I could use for the subs, but the 2200 is more than enough to frighten the neighbours, and there's no fan noise. But, I would kind of like to know what "F'ing Irene" from "Black Hawk Down" would sound like with both ContraBasses hooked up to the 1200W/side AP4040.
txsmoke
Posted: Tue Dec 04, 2007 5:32 am    Post subject:
7.1 system
Front L/R are a/d/s L-1290/2
Side and Rears a/d/s L-570 (better match than the 570/2)
Center is an a/d/s (Don't remember the model- was made a few years after the others. Dual 8" with dual mids flanking the tweeter.) Not a great match, but works until I can find another 1290/2. Or 1090/2. Or 1590/2...
6 MB Quart PWE-352 (15") in a infinite baffle.
Total of ~3.3 kw of dbx and Behringer power.
Fosgate Audionics FAP-T1+ processor. (Woot!)
A pair of a/d/s L470s as front effects for when I break out the Yamaha DSP-1 for fun.
JaceTheAce
Posted: Mon Feb 25, 2008 3:08 am    Post subject:
Mains: Energy C3
Center: Energy CC1
Surrounds: Energy Take 2
Sub: Energy e:XL-S10
rabies_70
TV/Projector: Sony G70Q
Posted: Mon Feb 25, 2008 5:18 am    Post subject:
I agree with you cmjohnson on the points you raise about subwoofers, more on that in a minute.
Front - Mission 735 Towers - older but very good sounding they are really nice got the pair for 100.00 They were the top of missions 7 series at one time
Center - Polk Cs350LS- Just got this for 100.00 a couple days ago and what a difference a great center channel makes. I am not exagerating when I say it breathed new life into the theaters audio. I knew something wasn't quite right and this speaker fixed it. I was using a mission 73c. But this speaker is by far the best center channel I have ever personally listened to. To be fair I am not an audiophile. And I don't think I've ever heard any truly high end speakers, but I know what I like, and this is a good match for my theater
Sides - Boston THX 575x dipole. They were a good deal and they work
Rears - Energy eXL XLR dipole. Again a good deal and a good fit.
Fronts powered by a Niles SI-250
Sides and Rears by an ADCOM GFA-6000
Center by an InterM R300
Now to Chris's point on the sub. Before I knew anything I figured a sub is a sub is a sub, bigger box bigger sound. Then I heard about something called an infinite baffle and after spending untold hours reading and looking at the cult of the infinitely baffled, I LOST MY MIND and decided to build a home theater IB subwoofer. I can only say that I truly hope I never have to be without it again. There is a buttload of work involved in learning, planning, designing and building one of these beasts, And they aren't exactly inexpensive, but when things blow up on that screen or something rumbles by in the movie and you FEEL it inside your body and all around you it is definitely money well spent in my opinion. You can actually design one so there aren't even speakers visible in the room. Me I wanted to see these big bad 15" speakers so I built an "outtie" box. At first with 2 speakers and within a few days I had ordered 2 more for a total of 4 Dayton IB385-8 15" IB Subwoofers. Some guys run more. If you do any reading on them you'll see that although they could reach insane SPL thats not the main attraction. What is however is that they can go so low, so effortlessly without distortion. 8-10 Hz at 75 db is something you can't ignore. I used to have bass shakers, and I liked them, but with the IB I shake in my seat without any extra machinery needed. I'm not kidding. If you don't build these correctly you can cause structural damage to your house. My neighbors 2 doors down can feel it in their living room if I forget to close my garage door. If it is closed they can still sometimes hear something akin to distant rumbling thunder if I have a good movie with Lots of LFE. It's not an unruly beast either. It is very musical and unobtrusive and then when the processor tells it to, it puts looks on peoples' faces of complete disbelief when they experience it for the first time. You have to accoustically treat the room and use room EQ wizard to equalize the sub with a Behringer DSP1124, then it goes to a Mackie fr1400i for 1000 watts of yummy LFE. But again well worth the effort in my humble opinion.
Ray
I am an iconoclast
Page 2 of 4
