HD-DVD/Bluray Combo Drive in the house :)
nuttall_chris
Posted: Wed Oct 31, 2007 12:33 pm    Post subject:
oliverg wrote:
To be HDCP compliant, as soon as an analog output method is selected, the output has to be scaled down Sad
Sorrry guys.
Anydvd helps Smile
Not an issue though as I plan on using the DVI output.
Chris.
Posted: Wed Oct 31, 2007 10:29 pm    Post subject:
Sorrry guys.
This is only true for Audio.
Analogue VIDEO out from a PC works fine, at full res for two reasons:
1. They have not set the ICT yet, which enforces downscaling over analogue VGA. And almost certainly never will.
2. Anydvd removes the HDCP anyway, except for BR+ discs, which they are working on cracking.
Unfortunately HDCP also applies to audio, and there is no real HDMI audio solution for a PC yet (SPDIF replication at best), and in Powerdvd all audio sent to a PCI soundcard (even a 24bit 192khz capable card like mine) is resampled to 16bit, 48khz. Due to the fact that the PCI bus is not secure. Powerdvd just resamples everything, whether it's protected or not currently.
And there is no really usable alternative to Powerdvd. That said, 5 channels of better than CD sound is pretty good, but not (in theory anyway) as good as full blown 24bit, 192khz lossless sound.
As for the multiple points on Scalers - most are completely irrelevant in a 1920x1080 world. And yes, my PC performs close to 100% perfect IVTC of 1080i 60hz material to 1080p 24fps using Dscaler 1080i IVTC MPEG2 decoder and Reclock for TS files, CoreAVC and Reclock for h264 files, and Powerdvd actually does it fine for HD-DVD/BD. I'm sure a torture test file could be found which trips is up, but in practice it works. Fancy deinterlacing is irrelevant for film material, all you need is IVTC.
The video side of the HTPC is as good as it can be currently, and the audio is being resampled.
I still see nothing of real importance in the list of Scaler features to make me want to fork over $2-3k minimum. Anything that matters for HD film based material is done by the PC. Not as slick, but it is done.
Posted: Wed Oct 31, 2007 11:42 pm    Post subject:
Oh, I just thought of something the PC is not real good at - Levels Expansion. Some drivers force it, the next release don't...etc.
Powerdvd uses Overlay on XP and you get expansion. Using Zoomplayer with Dscaler decoder in software running VMR9 (for TS files) you don't. But if you use Hardware Accel on an Ati card and VMR9 you do.
It's all over the place, and a PITA.
That said I see no sign of banding with HD-DVD, but it niggles me as I would prefer it to use VMR9 with no expansion.
oliverg
Posted: Thu Nov 01, 2007 12:45 am    Post subject:
The PS3 will not output 1080P by component, ICT or not. It removes the option as soon as it senses the lack of HDMI/HDCP compliant transport. Same with my BR player. Sony say this is so the machines conform to HDCP standards.
Someone was discussing the issue with Pixel Magic - this is what heir support guys responded with:
"There is a major issue on your setup. Most if not all blu-ray, HDDVD player outputs a HDCP protected HDMI signal. The Crystalio II RGBHV/Component analog video output will be disabled when a HDCP protected HDMI Input is selected. Only the 2 HDMI Outputs will remain active with HDCP protection. This is the rule of HDMI/HDCP processing so it won't work in your system."
On the nvidia forums, its been brought up several times. If you don't have a HDCP compliant display, the video card wont output. I've just hooked up the component adapter on my 8800GTX and it wont output 1080P - only 1080i. Is this different with ATI/AMD cards?
I just tried VGA too, but 1080P isn't even an option that appears.
That's specifically why I got my HDFury. Hmm
Mark, saying that the points I've brought up not being relevant for 1920*1080 - that's blatantly not true. VXP/HQV were designed specifically with 1080P in mind. I've seen the improvements first hand. You haven't, its that simple.
I also find it strange how you keep shifiting the issue to one of price, when price was never the issue at all. You deny that there is any benefit at all. Now you are saying "well there might be a little benefit but not at 1920*1080 and even if there was I wouldn't pay for it because its not worth it"
Overall, your comments are quite profound for someone that hasn't even given the technology due evaluation.
VideoGrabber
Posted: Thu Nov 01, 2007 11:13 am    Post subject: Two Valid Points of View; Different Perspectives
Oliver commented:
> I also find it strange how you keep shifiting the issue to one of price, when price was never the issue at all. <
Actually, that's not correct. Price is ALWAYS an issue, at least for 95% of us. And Mark was always upfront about being an "80%/20%" guy. I.e., as the prices rise, you reach a point of diminishing returns. At that point, the quality is already so good that no marginal increases could ever justify any additional expenditure (to these individuals).
That's just one point of view. There are others that feel that spending 5x as much for a 5% increase in PQ is well worth it, and they are absolutely correct... for them. BOTH are valid points of view... you just need to know where the individual is coming from. I appreciate hearing and learning from both viewpoints. But Mark's are more valuable to me, because they represent a balance and price range I find acceptable.
Your C2 ($5-6,000? USD), exceptional as I am sure it is, cost more than my (used) car, and there's no scenario short of me winning the lottery (which I never play) that the benefits of a C2 have any relevance. Perhaps some day, years down the road, when all electronics have high-quality VP chips in them, that C2 will be selling used for under a grand. I'd find it very interesting then, and would be sorely tempted, but would still think fairly hard about its justification in that context.
> You deny that there is any benefit at all. <
That's not the way I've interpreted Mark's comments from the very beginning. Only within the context of "bang for the buck".
There are "cheap" solutions that get you poor or moderate results. And there are other cheap solutions that yield excellent results... though not the very best possible. There are other costs associated with the HTPC option, which include initial setup and "hassle-factor", that Mark has been up-front about. You've made it pretty clear in your postings that you have no interest in that, which is fine, and Mark IS willing to do so, which is also fine. Each individual has to decide for themselves where they fit along the spectrum of investment: (time) -->--> ($$$), as well as where their personal curves intersect for quality/price.
To illustrate the point, let's take it up a notch. Let's say there was a VP that cost 10x as much as your C2. How much time would YOU have to spend evaluating it before deciding that perhaps the 2% improvement it might offer simply wasn't worth it to you? Then if you had Mark Cuban (a guy with much deeper pockets) chastising you that you really "needed to give it a chance", before making up your mind.
> Overall, your comments are quite profound... <
Yes, I'd agree with that assessment. Wink
- Tim
oliverg
Posted: Thu Nov 01, 2007 11:41 am    Post subject:
When the discussion about routing a HTPC through a VP came up - price was not even mentioned. Go back and read carefully, there is no mention of "There is no benefit of routing a HTPC through a VP because its too expensive"
His question repeated several times despite my explanation of "better PQ" is below:
Mark_A_W wrote:
Oh, and you STILL DIDN'T explain why you need a VP/Scaler after a HTPC in the video chain. WHY????
So frankly, your interpretation isn't accurate. Bang for your buck doesn't come into it.
The question was a technical one. Where in the question does price come into the equation? Only when Mark back peddled to say that he was an "80/20" guy and therefore he was happy with what he had. Which as I maintain - good for him but what's that got to do with his question? All that says is that he admits there's a 20% shortfall in PQ - which is exactly where a good VP comes in.
The fact is, Mark doesn't think there's any benefit to a VP. Based upon his archaic assessment of "scaler" technology, I'm not surprised. That's fine, but don't say that the improvement that people who HAVE tried the technology isn't there or accuse them of being “videophiles”
I’m surprised that this statement didn't alert you to his total ignorance on the subject matter:
I actually laughed out loud.
Posted: Fri Nov 02, 2007 4:17 am    Post subject:
I'll ignore all the other sh*t.
"On the nvidia forums, its been brought up several times. If you don't have a HDCP compliant display, the video card wont output. I've just hooked up the component adapter on my 8800GTX and it wont output 1080P - only 1080i. Is this different with ATI/AMD cards?
I just tried VGA too, but 1080P isn't even an option that appears. "
VGA output direct to a CRT display works fine for HD-DVD with my ATi 2600XT, and it worked with a 6800GT (with an earlier version of Powerdvd), that I had before. Whatever res you want. I haven't tried component.
VGA out from a PC is allowed. You get a nice green Tick in the Powerdvd adviser for Analogue Out.
I actually stopped using my Moome HDCP compliant Input card as it is really finicky and offers no visible improvement over my 2600XT via VGA. In fact it looks better on the 24" CRT monitor (using the 6800gt back then) as that has trouble clamping black with the Moome card in the signal chain (the XG doesn't have this problem, it has better clamping circuits).
That's one thing that the Nvidia card was better with - DVI out to the Moome card. With the ATi HDMI out to the Moome card I get a really blurry image, if I get one at all. I've got a 30cm HDMI lead to test with, but haven't had a chance. I've found HDMI to be more trouble than it's worth - for me anyway.
oliverg
Posted: Fri Nov 02, 2007 5:22 am    Post subject:
Link to http://www.avsforum.com/avs-vb/showthread.php?p=12085588#post12085588
For people that want to see for themselves how many VP owners have seen the same results I have.
Mark, the VP forum on AVS a great deal more VP owners (who were provided with the link to here) and they have commented on AVS about your claims.
As you so put it on AVS. "Bite me" - No, bite me! You want to make claims which are blatantly untrue, then be prepared to back them up with some actual evidence rather than theory. There are a lot of people there that have commented on your observations.
And these are people that actually have got a VP and tried it out with a HTPC.
Posted: Sun Nov 04, 2007 10:32 am    Post subject:
I am curious to know how this will function if one uses the Abit ATI-based HDMI-equipped motherboard. Did Terry say he's using this drive?
Moose
Posted: Mon Nov 05, 2007 3:45 pm    Post subject:
Accck! Deleted! Already answered!
Darren Wadsworth
Posted: Wed Nov 07, 2007 9:00 pm    Post subject:
Mark_A_W wrote:
Phil Smith wrote:
I spent a fortune upgrading my HTPC last summer and it's already outdated. Crying or Very sad
But my goal was to future proof it for hi def playback, and I did manage to do that. All I need is a drive and a video card and I'm good to go. Maybe a audio card too. I'm not sure what's required.
An 8500GT is all the video card you really need, right? I currently have a 6600GT.
This would be perfect for my needs. HDMI, HDCP and fanless. I can't believe they've gotten so cheap: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127301&Tpk=msi%2b8500GT%2bhdmi
Be careful with an 8xxx series Nvidia card if you run a custom resolution.
Powerstrip won't work and the Nvidia custom res panel only works with XP (or Vista?...I forget which one, but not both), and it's flaky at best.
My ATi HD2600XT is working fine for HD-DVD, with custom res's, working hardware accel. I'm very happy with it. Not perfect but close enough.
Mark
Mark,
Could you please post the exact model of the 2600xt card you have.
Thank you
Darren
"DLP is the official ESPN on ABC HD telecast sponser of college football"
Darren Wadsworth
Posted: Thu Nov 08, 2007 12:32 am    Post subject: Re: custom refresh rates without powerstrip
larryk wrote:
I have just built a pc with a quad core, GA- &&% MB, and a 8600GT. I am using the new GCC combo drive and Vista. At standard resolutions it works fine but I found out the hard way that I can't use poverstrip with this video card. I am feeding a CRT XG PJ and I need to be able to configure resolutions like 1920 by 800 48 or 72 ETC in order to optomize my PJ output. What can I do to enable custom res. and timings without powerstip?
I have installed the two earlier versions and the latest beta version of P.S as of Oct 28 but no luck.
Larry
There is a way to create a custom timing in XP with an 8600xt. I am doing it. Although, to get the porch settings close in the begining (you have to enter the numbers) I used the power strip settings from my 6600gt.
Works great. Although, powerstrip does come in handy for quick resolution changes.
Darren
Posted: Thu Nov 08, 2007 10:25 am    Post subject:
Keep in mind some of us waned on thread-reading when the discussion changes to bickering.
kschmit2
Posted: Thu Nov 08, 2007 12:17 pm    Post subject: Re: custom refresh rates without powerstrip
Larry
Darren
Darren, can you elaborate a bit on how to enter these timings on 8-series cards?
Posted: Tue Nov 13, 2007 2:04 am    Post subject:
I am not going to get into the VP debate except for two points. One, I have seen a couple of VPs and they make a difference. How much is a matter of personal taste. I don't think I would spring for a dedicated VP, as I thought the improvement didn't justify the cost for CRT. I think VPs have a greater impact on the digital pjs. Second, I am not taking sides, but I thought it was pretty juvenile to run to AVS and start a thread Oliver. Since I have known Mark, I have never known him to make statements without some knowledge of the subject.
Now, what I really want to know is the difference between using a HTPC and a stand alone player now that they are coming down in price?
oliverg
Posted: Tue Nov 13, 2007 2:11 am    Post subject:
Mark was asking a question which required me to gather more evidence.
As it turns out, I received a bunch of PMs from people who have followed both threads and some of the comments about Mark's observations were far from flattering. This isn't the first time Mark has disgruntled forum members.
There aren't many VP users on this site, so naturally going to AVS into the Video Processors forum is a natural place to gather some more informed opinions on the subject matter. Juvenille was Mark's blustering and abuse, which was not returned by me but noticed by quite a few others.
How can you say that Mark knows about the subject matter when he's admitted he has only spent a few hours trying one out? That's ridiculous!
james69
Posted: Tue Nov 13, 2007 2:36 am    Post subject:
oliverq your wasting your time dude
people that have a vid processor know you are right
your flogging a dead horse .. dont stoop to their level.. you dont have to justify yourself anymore because its obvious to the neutral people who is full of it.. i can see why your frustrated and why you would go to avs and imho i don't think your the juvenile one... one person is a legend in his own lunchbox
after reading the threads here and on avs i went and got a vp50. the one you recommended was too expensive for me
my satellite and my pc look a lot better. not a little bit but a lot so for me it was worth it
there just arent enough guys on this forum that uave really tried out the new type processors so just give it up
this thread should have been closed as its just not getting anywhere ...... what was the original topic again?
oliverg
Posted: Tue Nov 13, 2007 2:55 am    Post subject:
I agree - this thread isn't getting anywhere.
I find it amazing that some people have such strong opinions about something they don't know much about.
Joust
TV/Projector: Marquee 8501LC
Posted: Tue Nov 13, 2007 3:38 am    Post subject:
What do you mean?
Where is it supposed to go? It is about Chris N putting his new combo drive in his HTPC? talk of a video processor is an entirely different subject.
I suggest you start a thread on them. I'm interested but i think they are too expensive for my blood.
Posted: Tue Nov 13, 2007 4:45 am    Post subject:
I haven't seen how Mark can upset a lot of people, but oh well. I am sure I have pissed off a lot more people than Mark.
No, I don't believe you went to AVS to gather more opinions as you already have all of the knowledge you need on VPs. I don't see how one needs to spend days and weeks with a VP to see the difference. As I have said, I have seen them and there is a difference. Is it a big difference? Well, that is a matter of opinion.
James,
I think you have a digital and I said it would make a bigger difference for digitals.
Joust,
I agree. It should be discussed in a new thread.
Page 4 of 7
