Cannot see the dots on the H test pattern on 1272q
Goto page Previous  1, 2, 3
wallace123456
Posted: Sat Sep 22, 2007 1:22 pm    Post subject:
imprez25 wrote:
As for the convergance drift on the 1272 are you using a lot of convergance? If so that might be your problem. And are you letting the projector warm up to operating temp before making changes? If not you will continually be chasing the convergance.
I had a similar problem until I built a small table to raise my 1251 up off the floor. It would constantly need re-converged (a little) every time I turned it on. Mainly in the corners. Then I built a 10" riser. this took some of the strain off of the zone convergance. Now I can turn it on and there is no more corner drift. I can watch a movie as soon as I turn the projector on. My wife is happy about that. Smile
The convergence needs to be done in the middle almost everytime; a little on the corners. I will turn on the pj without the usual sony white warm-up screen (I disabled that), for about 15 minutes, then put in a movie and let it play for about 15 minutes, then check the convergence. I have the pj sitting on a small coffee table like. I also have a couple of 2x6 boards to help get the pj up higher off the coffee table. There is plenty of ventilation.
The pj I picked up yesterday is a 1272, not a 1271 like i said above. I am going to get it fired up this weekend and see what it looks like.
wallace
sh4dow
Posted: Sun Dec 09, 2007 7:07 pm    Post subject:
does it actually matter what you're projecting in order to reach operating temperature? should it be a white screen, like it used to be default with at least my 1252 or is black fine as well?
imprez25
Posted: Mon Dec 10, 2007 3:06 am    Post subject:
A black screen will not help get the tubes up to operating temps. I would also advise against running the white warm up screen, as this can prematurely wear your tubes. Just fire the projector up, watch a movie for 20 minutes then start making your adjustments.
Halo1963
Posted: Wed Dec 12, 2007 12:19 pm    Post subject:
Hi Wallace
One of the things that can cause convergence drift on the 12xx is dry solder joints on the banks of main transistors on the middle of the two top main boards (E and DC)
It is worth a try provided you can solder
Regards Halo1963
wallace123456
Posted: Thu Dec 13, 2007 2:03 am    Post subject:
Halo,
Thanks for the idea. Soldering is not a problem. Thumbs Up
Since I am now using one of the 1272's with the KF board the drifting has stopped. (Not that the KF board has anything to do with the drifting, it's just that everyboard is different than the older 1272.) But that is good info and I am going to check the boards on the one I am using now, just to make sure.
wallace
Halo1963 wrote:
Hi Wallace
Page 3 of 3
