Cannot see the dots on the H test pattern on 1272q
Goto page 1, 2, 3  Next
wallace123456
Posted: Fri Sep 14, 2007 2:10 pm    Post subject: Cannot see the dots on the H test pattern on 1272q
I have having the damnest time trying to get my 1272 to the point where I can see the dots in the H on that test pattern.
The pj has about 7,900 hours on it, 07msp tubes, PT-65 lens.
Any suggestions, please? I know I probably am doing something wrong, as usual.
wallace
Posted: Fri Sep 14, 2007 2:24 pm    Post subject:
That's a lot of hours on those tubes. Are you using the internal sync as opposed to an external source? You probably won't see the dots over 480p - if even then.
I have a 3500-hourish 1271 with well-focused PT-65's, and I don't know that I can see discrete dots, either. I know focus is good because I have some weird spots on the face of the red tube... they look like water spots. They're very sharp compared to the projected image, so I know it's the tubes that are soft as opposed to the mechanical focus.
Maybe I could see dots with the internal clock a little... I can't remember.
Hey, maybe we should have a 12xx shootout where we all take closeup pics of our H's, dots, etc. so we can compare setups. I've been wanting to see how my setup compared to others' 12xx's for a long time.
Anybody else game for a 12xx focus shootout?
1031
Posted: Fri Sep 14, 2007 2:29 pm    Post subject: Re: Cannot see the dots on the H test pattern on 1272q
wallace
Those dots on H letters dependts what resolution or aspect ratio you use. Usually att those hours of use on tubes, you can see invidual dots only at 480i/576i.
Trye plug composite or S-vid. and put that H- pattern on and if you still dont have invidual dots Rolling Eyes then i would say something is wrong.
That is how my old 1272 did that H-pattern with hd-145 lenses 567p@50hz 16/9 unknow tube history? probably over 5000 hours on tubes.
 Filesize:  76.44 KB
 Viewed:  12790 Time(s)
DVDO VP-50
New hobby, Rally
wallace123456
Posted: Fri Sep 14, 2007 4:37 pm    Post subject:
That's a lot of hours on those tubes. Are you using the internal sync as opposed to an external source? SC
Using the internal test pattern. But, now that I have a XA2 and hd-dve, I'll try that and see.
Sure! Let me try to get some tonight or tomorrow night and I'll kick it off on a new thread.
Another good idea!
wallace
Posted: Fri Sep 14, 2007 4:42 pm    Post subject:
Aspect ratio... that's really excellent point. Squeezing the raster to 16:9 really squeezes the scan lines together, making the dots blend together much more than at 4:3. Now that I see that image, I'm pretty sure my dots are pretty visible on the internal sync. I'll try it tonight and snap a photo.
Posted: Fri Sep 14, 2007 4:45 pm    Post subject:
No, that will make it even worse. I asked because if you were using an HD source, you definitely would NOT be able to see the dots.
1031's point about using composite or s-video is the right direction - that would be 480i as opposed to the internal sync, which is around 480p, I think. So, at 480i, the dots should be pretty visible.
GEBrown
Posted: Fri Sep 14, 2007 5:27 pm    Post subject:
Back when I had a 1272, I asked the same question. As I remember, I was told at the time that I'd need to connect a S-Video external source and then bring up the H's test pattern in order to see the dots.
So basically the same thing Ecrab is saying - they apparently only show up at lower resolutions.
My 2 cents
Brian Hampton
Posted: Fri Sep 14, 2007 7:15 pm    Post subject:
You may get them with 480p if the tubes are good.
I could see them at 480p after I re-tubed my 1271. But I had AKB off and contrast around 40, that makes all the difference. I still had enough light for me in my fully dark room with small-ish 70" wide screen
Sonynut
Posted: Sat Sep 15, 2007 6:55 am    Post subject:
At 7900 hours the guns themselves have worn quite a bit, no doubt.. The S-Video trick should work, though. By the way.. Two more machines in my house, and still no luck on another good blue and green...What really sucks is that the new additions are both low hours(668 and 1684), just had been setup incorrectly, and driven too hard.. aargh Confused
1272 Stack coming soon:)
CZ Eddie
Posted: Sat Sep 15, 2007 7:35 am    Post subject: Re: Cannot see the dots on the H test pattern on 1272q
wallace
Get a few sheets of 8.5 x 11 printer paper and stick it on the front of your screen, then slowly bring it away from the screen and see if everything comes into focus a few inches from the screen. Or if the best focus is in fact AT the screen. You might be surprised.
1031
Posted: Sat Sep 15, 2007 7:52 am    Post subject:
One thing more to add to this "dots on letter H" thing. i have owned just one 12xx series projector(1272) So Iīm not 100% sure but there can be different software versions on Y-card or different Y-cards. Y-Card makes those internal patterns and those patterns can be different depending what model or what verision you have. Maybe Sonynut have more experience is there difference on those patterns?
Here is one more for comparation.
 Filesize:  51.73 KB
 Viewed:  12699 Time(s)
DVDO VP-50
New hobby, Rally
Posted: Sat Sep 15, 2007 12:27 pm    Post subject:
I just got a 1271 that seems relatively minty, though I don't know the hours. Can anyone tell me how to switch test patterns? The manual on Curt's site is hosed - it starts correctly, but jumps to page 72, then goes to the end, then starts again at 1 and ends at 50! Naturally the bits I was looking for the other day were between 50 and 72... Very Happy
Posted: Sat Sep 15, 2007 12:54 pm    Post subject:
Press and hold the TEST key for 5 or so seconds, the PJ will say "ENTER SERVICE MAN MODE, PRESS (UP)". Press the up arrow, and you'll be in service mode.
Then, if you keep tapping the TEST key, the PJ will cycle through all available test patterns for the selected adjustment mode.
EDIT - Cycle through status pages with the PAGE key. In service man mode, there are a couple of additional page (or one) that shows hours.
Posted: Sat Sep 15, 2007 12:58 pm    Post subject:
Ahh - I got into SERVICE MAN mode (which always makes me chuckle for some reason... Up in the sky! Coming to save the day, and converge the projectors of the city! It's SERVICE MAN!!) to do convergence but didn't try hitting the test key. Thanks.
I'll take a look at the Hs when I get a chance - I've got to fix this stupid fan first, though. I oiled it and it still doesn't want to start (fan on the LVPS). If I poke it it starts going fine - not even noisy. Doesn't feel like it's resisting any more than the other one, either, so either I need to figure it out or attach a pony-fan to it to get it going on startup. Wink
Posted: Sat Sep 15, 2007 8:45 pm    Post subject:
OK, here are my test pattern sharpness shots. This is my good old 1271 w/about 2800 hours on the tubes. Very, very light wear - probably 9-10 all across. Ceiling mounted, dead-on physical setup, and decent mechanical and electronic setup.
Screen is 96x54, WilsonArt DW.
I'm no expert, but I'm pretty obsessive compulsive about image quality being a design/photo/video guy. Let's just say I'm pretty damn anal and leave it there. I went a little conservative on throw/raster max for better uniformity and corner focus, and I think it might have paid off. As you'll see, my bottom corners still need some work. I haven't even done the mooneyass mods yet, but I think it's a damn good image for a projector this old.
These were all using the internal sync signal, which I think is about 480p.
One good thing about these old 12xx's is that even when they're set up as sharp as possible, they're just soft enough at 1080i that it really looks "filmy". MUCH better than SD, but very "solid" - as in no gaps, lines, pixes structure, etc. Practically no scan lines visible, even right at the screen. Looks very film-like from the seating position. Saves lots of money on 1080p processors!
H's - screen center, all tubes on
 Filesize:  78.25 KB
 Viewed:  12659 Time(s)
H's - screen center, R and B muted
 Filesize:  96.37 KB
H's - lower left
 Filesize:  61.82 KB
H's - lower right
 Filesize:  67.54 KB
H's - upper right
 Filesize:  72.54 KB
H's - upper left
 Filesize:  68.91 KB
White field, R and B muted. 480p scan lines are pretty obvious near the screen, but not so much from 1.2x screen width seating position. Whites are where they become noticeable from the seating position.
 Filesize:  29.65 KB
 Viewed:  12660 Time(s)
Crosshair closeup.
 Filesize:  40.29 KB
Crosshair (screen center) with a digit for sharpness reference.
 Filesize:  43.06 KB
tony359
Posted: Sun Sep 16, 2007 12:12 am    Post subject:
On a 1272 I had on my hands, I could saw easily dots with composite interlaced DVD source. Then, "H" dots were there, sharp and well defined. When running higher definition, the dots were not defined.
Check the photo, projected on a wall!!
Ciao
A
Posted: Sun Sep 16, 2007 1:18 am    Post subject:
Tony,
OK, so 480i. Was that 4x3 or 16x9?
Nice dots. Wink
tony359
Posted: Sun Sep 16, 2007 1:24 am    Post subject:
Oh, that was just a test on a wall, but was 4:3 setup.
Ciao
A
wallace123456
Posted: Sun Sep 16, 2007 4:09 am    Post subject:
Hhhmm, those look really dog-gone good!!!
Sc, I see DOTS!!! Big time! I'll bet the picture is great as well.
Ciao,
I also see DOTS big time.
Do you guys have any source cable hooked up? Are you just using the internal test pattern?
I did not get a chance today or tonight to fire up the pj; I was stuck trying to pu a new front door in all day!!!! Mad
GGRRRRRR!! What a PITA!!
wallace
wallace123456
Posted: Sun Sep 16, 2007 4:42 am    Post subject:
Well, I still have 6 machines sitting in the basement. I am thinking of picking up another 1272q with good tubes.
I have been looking for a marquee 8500, but it seems like thats like looking for a "needle in a hay stack". Or, I aint looking in the right place.
Did you use a htpc on your set-up when it was running?
wallace
Page 1 of 3
