Picking up a defective 9500 Ultra, what is recommended?
Posted: Thu Aug 30, 2007 6:38 pm    Post subject:
Ouch. That's the first time I've ever seen a face failure on a Panasonic P19 tube.
The pressure must have been remarkable. I'm surprised the chamber didn't just
pop before it got to that level. But silicone rubber is strong stuff.
Incidentally, the glycol in the other tubes (blue for certain) is also cloudy and needs
to be replaced.
But given the condition of the red and blue tubes, I'd say it's worth it to spring
for a new green tube.
CJ
Posted: Thu Aug 30, 2007 10:54 pm    Post subject:
Not so rare. Brings back bad memories
 Filesize:  51.97 KB
 Viewed:  6081 Time(s)
Posted: Fri Aug 31, 2007 4:10 am    Post subject:
Wow cracked in an 'H' shape.
I remember your post about that. That's an expensive 'H'
Posted: Sun Sep 02, 2007 12:20 am    Post subject:
Hello
We are curious, were the red and blue bellows hard (pressurized) or mushy (OK)?
I have seen two cracked greens in the last three years; I think it was glycol pressure, others think it had to be beam damage or flawed glass, any comments guys?
jantje112
Posted: Tue Sep 04, 2007 9:39 pm    Post subject:
This baby is in my hands from now on. It has the 03P VIM that's the good one I think (when it's working Wink )
I stripped it completely and too bad the HVPS had a lot of white corrosion on the electronics, so I'm afraid that..
Well, let's see how it works out.. Time to clean the chassis, order a new tube, get a bunch of MP mods and enjoy the movie Smile
Anyone know if it will work if I only install 1 tube, for testing use?
Posted: Tue Sep 04, 2007 9:52 pm    Post subject:
I'm pretty sure you need all three scan yokes connected so the projector will power up; why not install all the tubes and just pull the HV on the ones you don't want running.
It already has a usable R AND B right.
Erik
WooHoo 300 Posts Very Happy
jantje112
Posted: Tue Sep 04, 2007 10:44 pm    Post subject:
Erik
The projector probably decided not to work in the days it's moved from spot to over here. The HVPS has a lot of corrosion, I guess when it whas flipped down in ceiling mount position it leaked some back in the HVPS and that results in a dead Marquee.
The picture was his last breath Smile
tse
Posted: Tue Sep 04, 2007 11:51 pm    Post subject:
White, powdery stuff in the HVPS is probably release agent used to ease removal of the potted HV section from it's mold.
Scott
Thomas Jefferson
jantje112
Posted: Tue Sep 04, 2007 11:56 pm    Post subject:
Scott
Well,
That's sound promising. Strange thing is that the 9500 at my home didn't do anything. Diconnected green, it powers on, blue and red tubes are on (they glow by the neckboard) But, no raster and no sign of anything on the tubes (pressed every button)
Good thing is, I cleaned out the whole chassis (so easy its a dream) and prepared the LVPS for a fanmod, lot's of dust in the LVPS, is that normal?
Posted: Wed Sep 05, 2007 12:21 am    Post subject:
jantje112 wrote:
Well,
Hello
You will need the scan yokes connected or the Marquee goes safe and the high voltage will not fire up.
jantje112
Posted: Wed Sep 05, 2007 6:32 am    Post subject:
Tim in Phoenix wrote:
jantje112 wrote:
Well,
Hello
That's the info what i was looking for. I keep you all informed.
BTW, the green has no typenumber and a vdc sticker. Is that a rebuild?
Posted: Sat Sep 08, 2007 9:25 pm    Post subject:
Probably.
Easy way to tell: What color is the bell glass? It goes yellow, then amber, then brown with a lot of use. (X-rays do it.)
A "typical" tube at the end of its service life will be rather brown. This will almost always include well-worn phosphor.
Seriously browned bell glass and clean phosphor is a combination that screams "I'm a rebuilt tube!".
Plus the dag coating color can be a clue, too. Brown means rebuilt, ALWAYS. But not all rebuilds have brown dag.
Some have the factory grey-silver dag.
CJ
