| Posted: Mon May 05, 2008 4:11 am Post subject: |
Kal this part needs to be a bit more clear:
1.6
| Quote: | | Remove this cover/diffusor for both the Eye-One and Spyder2 sensors if you are using a projector setup. Leave it on if you are using a direct-view TV. When you use the software that comes with the sensor, it may ask you to remove the filter depending on what type of display you have. That's only valid for when you use their software. For HCFR you must follow our instructions here instead. Your readings will not be correct if you take off the filter when using HCFR. |
The part in bold is wrong if your talking about FP but correct for Direct view or LCD and Plasma, At least for the Eye one i would presume.
just needs a bit more clarifying.
kal Forum Administrator
