if you think your htpc plays .ts files smoothly...
Posted: Fri Sep 14, 2007 8:34 pm    Post subject:
It's actually all electric, so if you have it on a cement floor it's nearly silent. Just zings a bit. Plugs into 110. Technically if you reinforced stuff enough it would lift a 1252, but there'd be a performance penalty, and keeping it converged during 2g accelerations and 20hz vibration would be a trick! Smile
Posted: Fri Sep 14, 2007 11:22 pm    Post subject:
Naw just have the projector external
Posted: Sat Sep 15, 2007 12:13 pm    Post subject:
If you think calibrating a CRT is tough now, try doing it when the screen can be at any angle from -30 to +30 degrees on two axes and anywhere along an 18" path vertically Wink
Actually, the screen pretty much has to be attached to the platform because otherwise the motion illusion won't work effectively. It depends on the horizon line you see remaining static vs. your field of vision, which convinces your brain that you can't possibly be rotating - and therefore, you must be accelerating instead. I wrote a lot more about it at http://force-dynamics.com/content/simulation.php, I don't think it's really on-topic for the HTPC section unless we start talking about modifying the machines to run d-box motion codes. Razz
Posted: Sun Sep 16, 2007 3:09 am    Post subject:
Hey, start a new post about simulators. It's on topic enough for us. We don't really care about off topic posts. We're not as concerned as some forums. So, Have at it.
