Looking at a 1209 and if I should "upgrade" from 1
Barry
Posted: Fri Sep 14, 2007 8:56 pm    Post subject:
HEAT question.....I have been running the PJ now for a couple of hours to see if there are any problems. There are access holes that allow me to stick my finger down on the CRT face heat sink siding. The heat sink is at room temperature. I upped the 720p refresh rate to 72Hz before the test. I suspect the issue of cooling is more of a "hotspot" issue for the face of the tube as opposed to overall heating.
Second thing...when I stand near the screen I can see some random jitter to the image which I would attribute to sync noise. I am looking forward to seeing upgrades to the boards I can DIY to clean up those paths.
Barry
Addicted to buying cool used expensive toys...(especially CRT projectors) Barco 1209, 1208 and Elektra Espresso Maxi2 most recent additions.....
Dave Lister
Posted: Sat Sep 15, 2007 4:01 am    Post subject:
That tank idea we discussed in the other thread may be very useful, to reduce pressure without glycol spraying everywhere all you would need to do it unscrew the cap, the pressure would be relieved and you could check the level to determine how much water vapour has been absorbed and determine when you need to replace the glycol, you could also use a syringe to remove some glycol to check for yellowing/darkening of the glycol.
it may even make replacing the glycol easier depending on how it is positioned:
1: relieve pressure by unscrewing the lid of the tank and the re-tightening it
2: tilt the projector appropriately to allow the glycol to drain from all 3 tubes
3: place a bucket under the tank so when you unscrew the lid and remove it the glycol drains into the bucket
4: tilt the projector to the opposite of above and refill by pouring the glycol into the tank
5: some careful 'jiggling' to get any air bubbles out of the LC chambers and hoses
6: a final top up to bring the glycol level in the tank up to the appropriate level
This looks more and more like a must do project for the ugly Retroblock I have in pieces on my kitchen floor. Thumbs Up
Stuff for sale;
Barry
Posted: Sat Sep 15, 2007 6:21 am    Post subject:
I am having problems adjusing one CRT (red)to center the raster/image. I run out of range using various combinations of raster shift red and convergence red on green. The physical lens adjusting required to static converge is asymetrical vs. the blue to green adjustment. The result is an image centered on the blue and green but shifted to one side (over scan) on the red.
Since I had all three CRTs out to replace the C- elements, the problem may be related. I thought I might adjust the something magnetic on the neck but only the yoke should have a significant affect on the image position and it looks pretty secure.
Suggestions?
Barry
Ile
Posted: Sat Sep 15, 2007 9:15 am    Post subject:
Cpc magnets have effect to raster centerings.
Procedure for astig and finding best position for focus yoke is covered in link two last pages.
http://www.curtpalme.com/docs/BarcoGraphics808s_CRTReplacementProcedure.pdf
When astig is ok you can set R/B raster centerings to 50/50 from menu and adjust rough R/B raster centerings from pots in back end boards.
http://www.curtpalme.com/Barco808_Layout2.shtm
You might have plate over board, but pot position is same.
http://www.curtpalme.com/Barco808_Layout3.shtm
Barry
Posted: Sat Sep 15, 2007 5:20 pm    Post subject:
Ile,
Thanks again for the great guidance. I checked and the CPC magnet assembly was loose on the neck so I assumed it might have shifted during my CRT removal and tried using it to change the red raster center. Does it require differential movement of the CPC magnets to shift position? I looked in the guide and this wasn't mentioned. I moved the assembly as a whole and it seemed to have no effect on position though I will surely have to go back and check and set astig tonight.
I found the red raster shift pot and it didn't seem to have any effect until I turned it multiple turns. I guess I wasn't expecting a multi turn pot. This brought things back to reasonable centering.
Previously you told me how to adjust the master H width pot which I did to get better painting of the screen. I just realized that it expanded the raster to well past the edges so I brought it back within the phosphor area. Is there a control that will widen the range of the image within the raster (other than the one in the geometry menu?) Now the image maxes out at about 85% of the raster which is set with a minimum margin of about 4mm at the widest point. In the guide Guy mentions that some installers will set the raster to overscan while keeping the image within safe limits. Theoretically there won't be any real heating of the tube edge if it is outside the image zone.
On another note I have noticed an erratic jumping of the pic for a fraction of a second where the expands or contracts by ~5% linearly as far as I can see, both horizontally and vertically. Since it is happening on two axes and all three CRTs I suspected something with the high voltage supply. I don't hear any arcing nor is there a pincushioning. Since I recently took all the CRTs out I am going to reseat the connectors I can reach. I reseated all the high voltage leads since they were obvious ones though I am not sure they are routed exactly as they were originally. Any area to check?
I look forward to heating up my soldering iron and joining you on the circuit board noise abatement crusade.
If you ever get to N. California I owe you some very good wine Smile
Barry
oliverg
Posted: Sun Sep 16, 2007 3:56 am    Post subject:
Ile is a genius. I owe him some wine too. He has sent me so much information that has ended up being so helpful.
An asset to the CRT community.
Kind regards
Barry
Posted: Sun Sep 16, 2007 5:21 am    Post subject:
Ile,
I watched it tonight and the jumping was on the vertical only....hmmmmmit is a jump in the vertical amplitude so I doubt it is on the sync....
Barry
Ile
Posted: Sun Sep 16, 2007 12:26 pm    Post subject:
Barry wrote:
Ile,
Moving 2-pole magnet pin or rotating it moves raster, so it's possible it have chanced little.
Fast test to see if astig is close:
Chance mid point focus from menu and see if raster is moving. If it's not moving it's close spot on.
In Barco it wont hurt anything to use bigger raster than the face plate. That's only way to get maxed out picture.
Use blanking to mask that overlapping unused raster.
You can't adjust just picture size from projector, raster is always chancing along. Source porch settings determinates how much there is unused raster in sides of picture. Barco likes pretty big porches, if you use too small porches you get "raster ringing" vertical bars to picture left side.
How much it moves?
I had small vertical movement with stock input card with high resolutions, it's maybe 1-2 mm in 2 m wide screen. I try to find cure for it when I get projector running again.
If it's bigger movement it could be ground loop or something.
Barry
Posted: Sun Sep 16, 2007 4:30 pm    Post subject:
How much it moves?
There are two erratic movement patterns:
Picture vertical amplitude jumps of about 10cm on a ~150cm vertical are for a fraction of a second and mainly noticeable when the set is cold. They occur randomly at about 30 sec to 3 minute intervals.
Horizontal jumpiness affecting small parts of the picture (like 3-15 cm vertical space). They usually are completely random coming in spurts of activity then going away. The horizontal displacement can be 1-4cm. I tried switching to the port 5 input to see if that would change it and it didn't seem to significantly. These I suspect are sync noise. This morning I went in and pulled a bunch of the boards to compare their part numbers with the 1208 that I have. After I plugged them back in I fired up the PJ and the only jumping I saw was occasional on the vertical axis of about 10CM. The horizontal seems to have quieted down. (will observe more tonight) Perhaps reseating the boards made a difference. Also, it seems that ll the boards I pulled so far (some are a pain to pull because of cross connections) are the same between the PJs so I can swap to compare their effects. Any suggestions on which are the best candidates? Now I will have a spare set if I want to mod them for noise reduction etc.
After looking at the 7 board upgrade at Eisman Theater and the pics of the boards before and after, I am wondering if I should start by buying a LOT of caps and mass replacing them.
On the issue of picture width, I did exactly what you suggested for all the reasons that you mentioned. I just wanted to know that Ile had blessed it Smile I had too observed the ringy ends of the Barco porch. Of course I wondered if it was normal and you gave me the info I needed.
One more thing...I saw the DIY article on your hush box and it is so over the top cool!
Barry
Ile
Posted: Sun Sep 16, 2007 6:31 pm    Post subject:
Never heard of similar problem, but vertical deflection board would be good place to start.
Funniest thing is that I got greatest effect to PQ by removing caps completely from peaking circuit. Very Happy It was unrealistic to realize that every time I removed components I got better picture...
Barry
Thanks, it was fun project back then. Cutting mould for that was like sculpting statue or something. I'm now considering if I should modify that same hushbox "little" bigger and use it with BG1200. Very Happy
My other option is to build BG1200 inside lowered ceiling. Both plans contain idea to take cooling air from next room and lead it also back there.
Barry
Posted: Sun Sep 16, 2007 8:06 pm    Post subject:
Hmmm....have you a picture of which ones are in the peaking circuit? Since the boards are the same for the 1208 and 1209 for the most part and I have a full 1209/8 service manual in pdf form, I can probably find the area that you altered. I looked through them and didn't find an area specifically labeled "peaking". I am wondering what function the caps had in the circuit you removed them from and what effect did you see on the picture. If they are decoupling caps they may be leaking and thus causing the problem.
I am going to swap out the vertical board and see if I see a change in the jumping.
BTW, if you want a copy of the manual I can email it to you. It is fairly large.
Barry
Ile
Posted: Mon Sep 17, 2007 11:48 am    Post subject:
Barry
Those are peaking circuits for transistors, probably manufacturer have tried to compensate some poor performance transistors with those circuits. (I'm not EE so I don't actually have a clue. Very Happy )
For example I have removed C303 and C307 from drivers green line (second stage) and chanced that crappy BSX20 to better one.
Those peaking circuits are causing this small white chosting/fussiness little right after text with high resolutions. (1080p72)
http://img46.imageshack.us/img46/2361/dscn1565xb6.jpg
I'm pretty sure that after I finish testing I have removed probably all 1-50 pF sized caps from rgb signal way. I'm not sure how just removing those caps work, because I have also chanced transistors that need peaking to better ones.
Thanks, but I already have those service manuals and I have used those to mod my BG1200. Everything in rgb signal path is same as in 1208/1209.
Spotmatic
Posted: Mon Sep 17, 2007 11:52 am    Post subject:
A question: in my 1209s (and also 909) there's a menu option "Peaking" in the menu. Disabling this for a given input frequency causes the peaking (adding a whiter side to darker objects, to make them stand out better) to disappear. Is this menu option also available in the 1200 or only on later models?
Barry
Posted: Mon Sep 17, 2007 12:00 pm    Post subject:
Ile,
I am an Electronics engineer but mainly digital. I will try to figure out what those transistors do. But don't count on it Wink
I was wondering what peaking meant. I figured it was circuitry to peak the frequency response on the high end....perhaps that is what it is doing.
Barry
Spotmatic
Posted: Mon Sep 17, 2007 12:05 pm    Post subject:
Peaking should be visible in the internal Barco menus/letters. If there's no peaking, the green letters have a perfectly consistent green color. If peaking is added, then the transition from green to black will have a white/lighter colored border... This adds "sharpness" to the signal, but in fact is nothing more than a degradation of the picture.
Edit: on the 909, peaking is always on, for all inputs and all input frequencies. You have to set it to off manually.
Edit 2: removed a very bad error Very Happy
Ile
Posted: Mon Sep 17, 2007 12:21 pm    Post subject:
No such thing in 120*, that feature is only in s- and Cine series.
My BG1200 have only sharpness adjustment that is renamed as BW limiting or something. Rolling Eyes It works also to rgb inputs so it's little different what sharpness in my 801s which work only for composite and s-video. That should always be turned off.
Ile
Posted: Mon Sep 17, 2007 12:31 pm    Post subject:
Barry
That is what it should do, but it have those "slight" side effects. Very Happy
Removing those circuits doesn't make high end response any worse, probably because I also chanced those transistors to better ones.
Barry
Posted: Mon Sep 17, 2007 12:34 pm    Post subject:
Which transistors did you substitute? Were they higher BW transistors?
Ile
Posted: Mon Sep 17, 2007 1:27 pm    Post subject:
I chanced all 12 BSX20 (switching transistors, 500 MHz) in driver and in neck cards to BFQ262 (video transistors, 1.4 GHz). That would make everything before VPA13 end stages +1 GHz and it makes details sharper.
2SC4271 (video transistors, 2.2 GHz) is one option, but I couldn't find those from europe.
But you US guys should get those least from www.bdent.com
Switcher need also six of those and some other transistors. But that is something I haven't done or tested yet...
This far I have only tested driver and neck cards with MP mini board as switcher.
Posted: Mon Sep 17, 2007 1:32 pm    Post subject:
How many % sharper Mr. Green
DVDO VP-50
New hobby, Rally
Page 3 of 4
