XG-FULLHD: NEC XG HDMI 1.3 Input Card
Goto page Previous  1, 2, 3, 4, 5, 6 ... 21, 22, 23  Next
Posted: Tue Jan 15, 2008 5:26 pm    Post subject:
I'll confirm with Moome what the ETA is.
Posted: Tue Jan 15, 2008 5:56 pm    Post subject:
I've updated the FAQ in the first post:
FAQ
Can you set different gamma correction for the two HDMI inputs?
No - there is one gamma adjustment setting. It is used for both inputs.
How do I adjust gamma on this card?
See this Gamma Tuning Guide for Moome products. The short answer: The gamma pot on the card is used to set the 'max' gamma boost value and the gamma up/down buttons on the remote then step over 20 levels of boost from off to max.
How will most people hook up their HDMI sources to this card?
A few common ways are used:
(1) Less than 3 sources and receiver without HDMI: Source 1/2 -> HDMI cables -> XG-FULLHD card.
In this method you would then connect your source devices via SPDIF or Toslink to your receiver. Only the older compressed Dolby Digital/DTS sound formats are supported over SPDIF/Toslink.
(2) More than 3 sources and receiver without HDMI: Source 1/2/3/etc -> HDMI cables -> HDMI swicher -> HDMI cable -> XG-FULLHD card.
In this method you would then connect your source devices via SPDIF or Toslink to your receiver. Only the older compressed Dolby Digital/DTS sound formats are supported over SPDIF/Toslink. Only one of the two HDMI inputs on the XG-FULLHD is used.
(3) Newer receiver with HDMI: Source 1/2/3/etc -> HDMI cables -> Receiver -> HDMI cable -> XG-FULLHD card.
In this method the newer Dolby Digital/DTS high bit rate and lossless audio formats can be carried over HDMI to the receiver and decoded. The video then continues on to the XG-FULLHD card. Only one of the two HDMI inputs on the XG-FULLHD is used.
What about the SPDIF audio output on the XG-FULLHD? How do I use that?
None of the methods mentioned above uses the SPDIF audio output on the XG-FULLHD as frankly, it's not needed. SPDIF audio output is included as it comes for 'free' with most HDMI chipsets (including the one used in the XG-FULLHD) so it's included as a method to extract audio from the HDMI stream for those that may want to use it for testing. We can't see anyone seriously using it in a regular setup as usually most source devices are close to the receiver/preamp so it makes sense to connect the devices up directly, not looping through the XG-FULLHD. If you have less than 2 sources, and your receiver is close to your projector, and your receiver does not support HDMI, then it may make sense to use the SPDIF output on the XG-FULLHD card as follows: Source 1/2 -> HDMI cables -> XG-FULLHD card -> SPDIF cable -> Receiver.
I only need one HDMI input. Can Moome make a cheaper version with only 1 HDMI input?
Most HDMI chipsets (including the one used in the XG-FULLHD) support 2 HDMI inputs. Removing one of them would not greatly reduce the cost involved in building the device. You would basically only be saving the cost of the one HDMI connector.
What about the "Phone" audio output jack? What's it for?
It's a headphone jack you can use for 2-channel listening. Again, not something that most people would ever used but some may want to use it for testing.
How do I use the remote?
Buttons 1 and 2 select between HDMI inputs 1 and 2. The Gamma Up/Down buttons increase and decrease gamma.
KennyG
Posted: Wed Jan 16, 2008 1:29 am    Post subject:
Wonderful...now all we need is the card.
dropzone7
Posted: Thu Jan 17, 2008 2:22 pm    Post subject:
I just hope I don't need new tubes by the time this card is available. Always on the lookout for a parts machine anyway.
I guess Kal is still waiting to hear back from Moome on an ETA. The suspense is killing me...
dropzone7
Posted: Sun Jan 20, 2008 3:25 pm    Post subject:
I'm going to have to unsubscribe from this thread because I can't stop checking back here! Laughing Any word from Moome yet Kal? I know you said he gets tons of emails every day but do we even have a guess about ETA at this time?
KennyG
Posted: Sun Jan 20, 2008 4:24 pm    Post subject:
Experience tells me you shouldn't worry about the release date of this card...in late June Moome asked me to wait two months...then it was two months more...then it was possibly before Christmas.
I believe there was a problem with the finished product, a couple of non-spec'ed parts were installed at the manufacturer, and that's all I should say.
So this is not Moome's fault.
It'll will be released when it is correct, and that's all we can ready ask for.
Believe me, we're all in the same boat, I have about 15 blu-rays I'm not watching until I get this card...they are very dark movies that need correct black level and gamma. (Dracula, Sunshine, Blade Runner, 2001, etc.)
So you might want to take that burning money out of your pocket and set it aside, because without correct gamma and black levels, this image just looks like crap (to me anyway) a sub is nice (easy for me to say, I have two subs with three 12" drivers per cabinet) but image is EVERYTHING!!!!!!!!!!
Posted: Sun Jan 20, 2008 5:00 pm    Post subject:
Update: The (hopefully) final prototype is built and Moome has it in his test setup (he owns an XG135) and he's doing tests to ensure good noise performance. He figures that he can get this orders into the factory in February with shipping in March.
I basically have everything ready to start taking pre-orders. I'm considering putting up this pre-order page in the next few days but not really announcing it or posting it on the main site listing for another month so that people in the forum can get their orders in and be first in line. What do you guys think?
EDIT: Oh yes, price. You guys are definitely going to ask about that... Smile It'll be $15 more than the other cards, so $450. So for $15 more you basically get the same as the other Sony/Marquee cards, but (1) better DACs, (2) better opamps, (3) 100% HDMI 1.3 compliance (not 1.2), and (4) Two HDMI inputs instead of 1. Of course, you lose the component input but IMHO two HDMI's are better than 1 HDMI and 1 component.
dropzone7
Posted: Sun Jan 20, 2008 7:20 pm    Post subject:
That's great news Kal! I think we all want Moome to take his time with the testing and make sure it's good to go before production. It's just good to hear that there is light at the end of the tunnel on this. I'm sure all of us XG owners would appreciate a little advance notice of the preorder so that we might be part of the first round of shipments. You just tell us when and where dude. Smile
MikeEby
Posted: Sun Jan 20, 2008 11:59 pm    Post subject:
I work for a small electronic manufacture in Indiana. We specialize in small run electronics for the RV industry. We have automatic surface mount machines that are way under capacity right now. Do you think Moome would be interested in licensing the assembly of boards to the US? We have our cost very much under control, probably not as low as Taiwan but very competitive and can respond very quickly. Several of our employees are former Crown (high end amplifiers) employees.
Looking at the design of the Gen 1 board, guess would be the most costly part of the board would be the tooling for the connector panel.
Just a thought.
Posted: Mon Jan 21, 2008 12:01 am    Post subject:
Well Moome's in Taiwan so I'd say it's more convenient for him. You could always ask...
Posted: Mon Jan 21, 2008 12:03 am    Post subject:
Yup. Ask, but as AnalogRocks mentioned, Moome just goes down the street to get his boards done, he knows the people. and they speak the same language.
Posted: Mon Jan 21, 2008 8:45 pm    Post subject:
Okidoki guys, pre-orders for the Moome NEC XG-FULLHD card are now available.
See: http://www.curtpalme.com/NEC_XG_FULLHD.shtm (Or use the link in the first post of this thread).
This is a hidden page as we want to give the forum regulars the first places in line to order. There's no link to this page on the main site.
Note that I mentioned that it ships in April 2008. This is pessemistic. I've added over a month 'padding'. Moome has indicated that he will send the order in at the end of February with shipping in March. This initial batch size is unknown. He'll likely decide a month from now before placing the order.
Thor
Posted: Tue Jan 22, 2008 8:33 am    Post subject:
Just to be sure before I order, I can use 1080i 72 Hz and 1080p 48 Hz with Powerstrip, even that it's not mentioned in the "support mode table", right?
Posted: Tue Jan 22, 2008 6:16 pm    Post subject:
Yup. I don't see why not. Moome's cards are able to do any resolution/refresh rate as long as you stay below a certain maximum pixel clock rate. I would bet it's the same with this card. The resolutions you mention are lower than ones he mentions in his manual so it's likely fine.
yonexsp
Posted: Sat Jan 26, 2008 9:56 pm    Post subject:
April, and $450. Crikey, an XG will be worth less than that by then. I love CRT but at that price it starts to get hard to justify.
Posted: Sun Jan 27, 2008 9:06 pm    Post subject:
True. It's not exactly cheap, but then, the other Moome HDMI cards (Marquee/Sony) are $435 and are not HDMI 1.3. So I find it surprising that people thought that a better card with better parts would be cheaper.
dbaisey
Posted: Sun Jan 27, 2008 11:31 pm    Post subject:
The value of a large screen video display device shouldn't be determined by what is on E-Bay sold as-is. You either respect CRT quality and upgrade to new sources or buy something that will make you happier with the same quality. I have no problem with SD DVD superbit 'The Fifth Element' as long as the media stays the same for all SD but thats not going to happen. I think Moomes on the edge of what is 'new' for our CRTs so that will usually not be discounted to 'as is' E-Bay pricing. Doug
KennyG
Posted: Thu Jan 31, 2008 1:46 am    Post subject:
Unfortunately I've gotten spoiled with BD...I started to watch one of my SD disc a couple days after I bought my BD player..got through it, but haven't watched one on the big system since. (I've had the BD players for about 6 months now)
We have started watching SD on the 60"er though, so that's kinda cool, until then, I hadn't watched a movie in my living room in 6 or 7 years!
Nor should it ever be discounted by Moome...unless it's a close out item.
If we want it, we gotta pay the price, after all, this isn't some sort of mass produced item...we don't get the luxury of mass sales...if you want to take crt to it's apex, this really isn't that much to spend.
The nice thing is, this should be the end of our input matching problems, it's slightly painful once, then it should be over for my lifetime. (this assumes HDMI will be the standard for the next 20-30 years) OR until I finally move to a digital projector.
JuzWerkz
Posted: Wed Feb 20, 2008 6:16 pm    Post subject:
Okay so it's been a month since you posted this, and I was just curious how many pre-orders have been taken. (I know I was one of them.) Any idea on how many cards will be ordered and when the order will be placed? I'm certainly not trying to rock the boat at all, and I know we'll have to be a bit more patient, but now that I've read about it, I'm starting to notice even more how much I "need" the gamma correction. Plus I've already had to pay the visa bill for this card... Wink
cj
Posted: Wed Feb 20, 2008 9:00 pm    Post subject:
14 pre-orders so far, Moome thinks the batch size will be about 50. No other news from Moome other than that. Sorry.
Page 5 of 23
